> 2010 MS3 - Turbo Induction
Like Tree8Likes
 Old 06-17-2016, 11:04 AM   #1
Xtrinsic1337's Avatar
Posts: 32   (View Stats)
Xtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to behold
Neutral  :  -1 score
Default Blown Corksport Turbo
Running 27 max but regular aggressive tune at a daily 24 because this turbo likes to spike to 27 psi at high rpms. Straight pipe exhaust large FMIC and and bunch of other shit but here's the pics! Bearings aren't the best quality. Ran for 10k miles and had it since December
Corksport has not said anything about warranties yet but I guess we will see! Everything else I've purchased from them has been great but my turbo charger shop said this turbo can't be ran for very long in the mid to high 2.0 bar range
Time to start my build thread for a 200sxe big turbo swap
Xtrinsic1337 is offline   Reply With Quote
The Following 7 Users Say Thank You to Xtrinsic1337 For This Useful Post:
Code Monkey (06-17-2016), Easter Bunny (06-23-2016), InkedInspector (06-17-2016), MD1032 (07-14-2016), mxlplx71 (06-17-2016), Neverlift (06-17-2016), [R]usty (06-17-2016)
 Old 06-17-2016, 11:09 AM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
That's too bad. Do you track at all?
2010 Mazdaspeed3 w/tech
 Old 06-17-2016, 11:29 AM   #3
nindoja's Avatar
Posts: 2,395   (View Stats)
That sucks man. You should come up to Huntsville for a meet sometime. I'll make a thread soon, but probably next Sunday.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
MD1032 (07-18-2016)
 Old 06-17-2016, 11:43 AM   #4
I don't track her too much I'm a top speed junky. Vdyno had me at around 415 HP and 450 FT lb's of torque on the aggressive tune running 100% e85. Changed my Timing curve to drop my torque load and high boost at around 5K and eventually made a safe 375hp 350 ft lb's on smoothing 3.0 scaling. This was also a 50/50 e85 gas setup
Will be selling my stock exhaust manifold, OBX (reinforced welded) long pipe with no cats, Cobb Turbo Inlet and SF Intake here soon once I tear down and get some pictures put up on the for sale forums. Also have some stock front calipers laying around. Need monies for this build. Everything custom fit and welded right down to the manifold and it's an upgraded s200sxe we will see where this takes us
Last edited by Xtrinsic1337; 06-17-2016 at 11:43 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-17-2016, 11:55 AM   #5
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
You may have a piece of history in your possession, the first ever blown CS turbo. I haven't heard of anyone else blowing theirs yet...
So if they replace under warranty are you still going bigger turbo?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 06-17-2016, 12:20 PM   #6
Yes and no lol ... Big turbo = 2 months downtime for part fabrication and 3 extra grand. This is my daily but I do work from home .. meaning I would love a replacement to get me by a few months so I can take my time and go for a second engine.
It was a good turbo though and it drops in easily ... would I buy it again ? No .. the only advantage to this over the K04 is reduces EGT's due to bigger exhaust housing and the fact that it pulled hard until redline. I took her into the 170's & 180's a time or two
 Old 06-29-2016, 06:15 PM   #7
06speed's Avatar
Posts: 96   (View Stats)
06speed will become famous soon enough
Groaned at 25 Times in 7 Posts
I have had my CS turbo for about two months and im sure mine went bad. oil coming out the intake and compressor side. havent been to the track or done any high speed pulls. lately i have been driving the car between VA, SC, and GA. going 80MPH.
06speed is offline   Reply With Quote
 Old 07-12-2016, 05:08 PM   #8
Jetfire's Avatar
Posts: 39   (View Stats)
Jetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to beholdJetfire is a splendid one to behold
Mine is like #5 or something like that and I am worried she might be toast, just blew through 3 quarts of oil in 400 miles. On a completely rebuilt engine that just got broke in.
2008.5 Mazdaspeed3
|JBR 3 inch intake|Corksport turbo |Corksport EBC|CS injector seals|Cobb TBE|
|CPE TMIC|Turbosmart BPV|Koni Yellows|FatCat BumpStops|Eiback Prokit springs|JBR OCC|SPC rear camber arms|DBA4000 rotors| Hawk HPS pads|JBR mounts x3|3 BAR MAP|
|CS adjustable shifter|CS steering wheel|CS Sways, links and mid chassis brace
Cobb AP v3
Autotech HPFP internals
Jetfire is offline   Reply With Quote
 Old 07-12-2016, 06:28 PM   #9
08speed's Avatar
Posts: 147   (View Stats)
08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of
Does CS have any kind of warranty on their turbo?
08speed is offline   Reply With Quote
 Old 07-12-2016, 06:33 PM   #10
Jetfire's Avatar
Yes, though I cannot recall the specifics of what was on my warranty sheet I filled out. I think it was 1 or 2 years.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 07-12-2016, 08:19 PM   #11
Jetfire's Avatar
How did you notice yours was going? I just started occasionally puffing blue smoke, pretty worried I am in for a replacement already with only 15k on the turbo, the K04 got me 130k so I hoped for at least as good a performance.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 07-13-2016, 02:29 PM   #12
08speed's Avatar
But were you pushing your K04 as hard as you were the cs?
 Old 07-13-2016, 02:37 PM   #13
Jetfire's Avatar
I was running stage 2 19 psi tunes on the K04 for about 3 years. I never even got my CS tuned. It was on safe mode spring pressure up until about 2 months ago. I had it tuned up to 21 psi on just a few revs and did maybe a dozen Wot logs, other than that didn't really push it much. I hit 24 psi once or twice for a millisecond in overboost, but CS says tuning to 30 psi is the limit so I don't expect that did it in. Just got it setup in 3 port and the last wot log was immaculate at 17 psi. If I had been beating it I could see it going in 1 year and about 15k miles but she's been babied.
Won't know for sure what's up until I check the compressor housing out but definitely concerned.
Jakeypoo likes this.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 07-13-2016, 03:06 PM   #14
macdiesel's Avatar
Posts: 825   (View Stats)
Will cork sport warranty a disassembled turbo?
 Old 07-13-2016, 06:23 PM   #15
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
would you?
94 M
MS6
IS350
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
Easter Bunny (07-13-2016), MD1032 (07-14-2016), WetzMS3 (07-14-2016)
 Old 07-13-2016, 07:14 PM   #16
08speed's Avatar
That's what i was wondering as well... We will find out soon though.
I'll be curious to hear what they find for the cause of failure. I wouldn't take it apart yourself unless you are told it's out of warranty.
Last edited by 08speed; 07-13-2016 at 07:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-14-2016, 05:24 AM   #17
macdiesel's Avatar
would you?
Nope.
Sent from my iPhone using my stinky little fingers
WetzMS3 and MS3Shadow like this.
The Following 2 Users Say Thank You to macdiesel For This Useful Post:
MS3Shadow (07-14-2016), WetzMS3 (07-14-2016)
 Old 07-22-2016, 07:48 PM   #18
Jonb82's Avatar
Posts: 416   (View Stats)
Any update on this? I'm still waiting for my TBE to be ready and am already looking for a BT next. I am pleased with Corksport so far, and would love a plug and play option as I am still learning to wrench as I go. Did they fix the problems from the earlier ones? A BNRs3 is also on my radar. Good luck nonetheless
 Old 07-22-2016, 09:20 PM   #19
Jetfire's Avatar
I have been working with them on mine, I am very happy with the customer support and it sounds like they have not been contacted with any blown turbos so far. If there are issues it sounds like they will likely rebuild it under warranty so once I have it swapped for my new CS turbo I'll send the existing one back to them to examine. I have a feeling the CHRA must have worn unevenly on the hot side but until I pull it I cannot really say what is going on other than lots of oil in the exhaust.
I see no reason not to put in a CS Turbo unless you have higher power goals.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 07-23-2016, 01:48 AM   #20
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
ninja edit, you could always order a Td05 rebuild kit, as long as the wheels didnt touch it should be ok
were you using an oil restrictor with this turbo?
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
 Old 07-23-2016, 09:10 AM   #21
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Seems to be a few of these failures/problems on the CS turbo doesn't seem right. Just hope this doesn't turn out to be another "lug nut/cams/HPFP internals"-like case again.
 Old 07-23-2016, 09:13 AM   #22
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
It already is. Tons of people with CS turbos are having problems with boost creep, and the problem is inherent to the hot side design. Now on top of that we're also looking at durability issues. I think the product should be re-engineered.
2007 Mazdaspeed3 GT
 Old 07-23-2016, 10:10 AM   #23
g00s3y's Avatar
Groans: 438
That's unfortunate to hear. I really like CS as they are one of the few to really keep supporting this platform.
I was going to go with a CS turbo instead of the S3v2 initially. Only thing that stopped me was the fact that it can't be clocked so I couldn't use my HTP piping. Seems I avoided quite the headache.
 Old 08-08-2016, 04:47 PM   #24
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
OP is taking his 4th ban, Tyler McNutt yet again
Vansquish (09-01-2016)
 Old 08-08-2016, 05:00 PM   #25
MD1032's Avatar
Groans: 143
Do you think everything that's posted in the OP is legit in that case @SofaKingAwesome;?
2007 Mazdaspeed3 GT
KiwiFlavor (08-09-2016)
 Old 08-08-2016, 05:01 PM   #26
COCKSTRONG
Groans: 890
Guys a known scammer, but who knows.
 Old 08-08-2016, 05:20 PM   #27
nindoja's Avatar
Doubtful. He was just claiming on FB that he was pushing the turbo to 38 psi....
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 08-08-2016, 05:56 PM   #28
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Pssh what a pussy, i push mine to 45psi all day everyday
No but seriously i run 30 psi and have all year with meth and no issues at all with the turbo, its a good little snail.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 08-08-2016, 08:15 PM   #29
08cosmic3's Avatar
Posts: 2,920   (View Stats)
He posted that he hit 180 mph, has anyone every went more than 165 on the stock tranny?
 Old 08-08-2016, 08:23 PM   #30
nindoja's Avatar
Technically, if you run the engine out to 7k RPM in 6th you can hit over 180 even on stock-sized tires.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 09-01-2016, 01:14 PM   #31
Jetfire's Avatar
Results are in, mine blew up but because shop tech left a chunk of metal in the turbo/exhaust mani. Somebody is paying for a new turbo and giving my labor charges back.
smlockdown likes this.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 09-01-2016, 01:25 PM   #32
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
chunk??
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 09-01-2016, 01:31 PM   #33
Jetfire's Avatar
chunk??
Yeah, studs on the turbo had to be ground down to fit the CPE manifold. Most likely one of those stud chunks fell into the turbo. Is probably now sitting in my cat.
2008.5 Mazdaspeed3
Cobb AP v3
 Old 09-01-2016, 01:37 PM   #34
Police - Grammarhead
Vansquish's Avatar
I think there's a song about McNutty-butty.
It's called, "The (Pussy) cat came back."
That (motherfucking) cat just couldn't stay away.
monkey.bones.007 (09-01-2016), SofaKingAwesome (09-03-2016)
 Old 03-04-2019, 12:09 PM   #35
mediocrity's Avatar
Posts: 4   (View Stats)
mediocrity is an unknown quantity at this point
I see this thread is kinda dead but I figured I would post a reply anyway.
I am currently running a CST4 @ max 20 psi that's been in my car for about 20k miles and it has started burning oil like a MF. It's a daily so I've been looking for a reliable replacement that's more fun than the stock turbo. The new CST5 is coming out and I've thought about waiting and buying that but I'm not sure if I want to buy a CST when the CST4 blew up so easily and quickly.
Does anyone have any suggestions on a good turbo?
m8357510 likes this.
mediocrity is offline   Reply With Quote
 Old 03-04-2019, 12:44 PM   #36
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
First of all, you need to know why it blow if it isn't high mileage....
Do you let it warm or cool down correctly?
If you have a crank case ventilation problem, any turbo will end up the same way.
If you have turbo surge, it may not last longer...
I would also check compression to make sure it is your turbo.
Why would you get a larger one if you was just running that one at 20psi ? I never try a CS but i think you have some room to grow above 20....
BNR got good feedback for the price.
I personally prefer a Garrett ball bearing especially the new ones with extended R&D of the wheels.
If you were looking for real big, Precision and Borgwarner EFR seem popular choices...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 03-04-2019, 02:44 PM   #37
CesariniAP's Avatar
Posts: 26   (View Stats)
CesariniAP has a little shameless behaviour in the past
I am also curious as to the longevity of the CS turbo. It’s definitely appealing at $1099 with the 3bar. Have they stood up to the test of time?
2008 MS3, Cobb AP V3, JBR 3.5 WP, CS 3.5 BAR, BNR S3 V2, JBR RMM 88 Duro, JBR TMM 70 Duro, Cobb TBE, EBCS, autotech HPFP, E85 mixed to E30, Snow Stage 2 WMI, (Stratified Tuned "Not for WMI") ITV22's, Koni yellows.
CesariniAP is offline   Reply With Quote
 Old 03-04-2019, 02:47 PM   #38
mediocrity's Avatar
So far as I can tell one of the seals has gone bad and is leaking oil into the exhaust. The turbo builds boost well and spools fine.
It's hard for me to know exactly how well the car has been taken care of because I bought it only 7k miles ago. Idk if the previous owner beat it up and then before he sold it put an easier tune on it to make it look better then it actually was.
I've been under the car. There are no leaks from the engine and it's all healthy (as far as I can tell). Smoke has been coming out of the exhaust infrequently which hints at the turbo. I haven't dropped the exhaust and looked up into the turbo to see if there's oil yet but I plan to soon.
The turbo is most likely rebuildable but CS don't want to sell me just the seals. They want me to pay for their entire CHRA. I have the old OEM turbo. I might just end up rebuilding that and sticking it back in.
 Old 03-04-2019, 10:22 PM   #39
ThOrZwAr's Avatar
Posts: 43   (View Stats)
Default rock solid!
Daily driver - 45k miles on my CST. Running 22psi on 93 and 24psi on e25 tuned by FreekTune, burns zero oil. Only issue was some boost creep after the initial install that was solved by porting the interal wastegate outlet a bit, I have a the first version and I believe this has since been resolved with the newer ones. It's been absolutely rock solid.
 Old 03-05-2019, 06:13 AM   #40
Jeff23spl's Avatar
dropping the exaust wont help much, take engine compression and leak down instead. engine blow by will make the exaust smoke too.
IT is a bushing turbo, i would expect any good turbo shop can rebuild it and figure out the correct parts to do so.
Keep in mind the CS is larger than oem, the k04 usually choke around 17-18 psi above 5000-5500rpm
Wife drive 2010 CX7
Blown turbo acidhalo 2010 MS3 - Turbo Induction 24 10-16-2013 03:08 PM
Blown Turbo? finalems3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-24-2013 09:37 AM
Blown Turbo HawkNasty MazdaSpeed 3/6 - Big Turbo Builds 15 08-21-2012 04:51 PM
Blown Turbo????? sacredmonkey Mazdaspeed3/6 General Discussion 10 02-15-2012 01:56 PM
Page generated in 0.56276 seconds with 42 queries
