> 2010 MS3 - Turbo Induction
  • 1 Post By aaronc7
 Old 06-30-2018, 11:45 AM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default BNR S4 on Stock Motor
Hey all
Roll raced a 5.0 yesterday, ended up blowing the seals on my shitty K04. So I can't drive the car until I get a new turbo.
Mazda wants $1,290 for a new OEM turbo, I'm not paying that much for another K04. So I'm going big turbo and was thinking of the BNR S4, since it's the same price as an OEM new and comes with all the hardware I need.
I understand it will make more power with less boost and keep pushing at higher RPMs, perfect for beating the 5.0 I was racing (it was a close race already, if I had more top end I would've had him). I'm just not sure if the stock block will be able to take it. I will have it retuned of course so perhaps I'll be good. I don't really plan on rebuilding, so I'm not sure if the S4 if worth it or if I should just get the S3.
Also, I had one more question, it says it has a 3.5" inlet. Will I need to get a new intake too or will my Stage II SRI from Corksport still fit? I'm not sure how much the K04's inlet was.
achulz is offline   Reply With Quote
 Old 06-30-2018, 12:37 PM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
You need a bigger inlet or at the very least a coupler to 3.5, the stock intake is 2.5-6ish. You'd be fine on stock block as long as the tuner knows what he is doing... That turbo would appreciate a new 3inch downpipe too
 Old 06-30-2018, 01:11 PM   #3
achulz's Avatar
Yes I am going TR8 FMIC and 3" catless downpipe. What intake would you recommend that's 3.5"? Does Corksport offer a 3.5"?
 Old 06-30-2018, 01:26 PM   #4
kTaLgsTo's Avatar
jamesbaroneracing, corksport, htp....
https://edgeautosport.com/search.php...=Intake&page=1
 Old 06-30-2018, 02:02 PM   #5
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
To me, S4 is slightly much on stock block... you'll lose a good amount of spool and not be able to fully utilize it's potential. S3 will spool faster, closer to stock, and have more topend than k04. or CS, which is what i went with, spools closer to S3 but with topend closer to S4. great stock block option, IMO.
Genpoo stuff
 Old 06-30-2018, 02:05 PM   #6
kTaLgsTo's Avatar
To @sharksinspace; point, I went s3, only because I knew I wouldn't be able to max the s4 reliably
 Old 06-30-2018, 04:46 PM   #7
achulz's Avatar
Sounds like I should go for the S3 since I won't be rebuilding. Saves me some $$ too.
 Old 06-30-2018, 04:48 PM   #8
Groans: 126
There happens to be an S3 for sale on the forums for $800 if you go VIP...
Genpoo stuff
 Old 06-30-2018, 04:57 PM   #9
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
achulz likes this.
 Old 07-01-2018, 10:28 AM   #10
Djohns's Avatar
Posts: 3,944   (View Stats)
I went with an s4 and am very pleased with my results but I do also plan on building one day.
2010 black mica speed3
Soon:built motor
Stock Motor GT2871R Swinger13 MazdaSpeed 3/6 - Big Turbo Builds 383 02-23-2014 12:10 AM
Highest RPM stock motor can be rev'd to... ?? all4bspinnin MazdaSpeed 6 - Engine, Transmission & Driveline 17 08-31-2009 02:49 PM
Motor Mounts in stock? TheDoc Mazdaspeed3/6 General Discussion 1 07-09-2008 12:50 PM
Page generated in 0.29556 seconds with 24 queries
