![]() Join Date: Mar 2017 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
Groaned at 18 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score Corksport TIP --- Cobb TIP Neither are installed as I need to do hpfp before installing a bunch of stuff I have waiting. I have an uninstalled Corksport intake, thinking I should pair CS parts with CS parts. But if the Cobb TIP and CS intake work together better for some reason I'll do that since I'll have both? Y'alls thoughts?
__________________ Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop JBR: rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter To install: downpipe, Damond EGR delete |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Sometimes similar brand parts match up better. Years ago I bought a corksport tip and it only worked with the corksport intake, which I did not have...they have since made their parts more universal though I believe. As long as they match up together though, it doesnt really matter what brand you use. For intake purposes wider is better though |
| The Following User Says Thank You to speed23 For This Useful Post: | Bexar (08-18-2017) |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Sell both and buy a 3" or bigger intake. If you don't want to do that, use the Cobb it is silicone and gives you 167 more horsepower than the metal CS one. You know due to heat and what not.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| Not Ranked : 0 score Silicone will give you a false sense of pride.
Groans: 64
| Not Ranked : 0 score It was sarcasm Topic has been beat to death, then resurrected, just to be beat to death again, hence 167 more horsepower. All factory sized intakes, really just come down to brand preference. They fit/function basically the same.
| Neutral : +1 score I was making a rather strange correlation to how silicone implants make you think you're better.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Thepedigree13 (08-20-2017) |
| What you really need is titanium intakes Sent from my Nexus 6P using Tapatalk
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | Code Monkey (08-22-2017), Thepedigree13 (08-20-2017) |
(Thread Starter) | Not Ranked : 0 score Okay I ended up mating the Cobb TIP to Corksport Intake. They fit fine together and work as expected. I'm getting the Corksport TIP 24k gold plated for better electrical conductivity, should provide more horsetorques
| The Following User Says Thank You to Bexar For This Useful Post: | speed23 (08-21-2017) |
| Not Ranked : 0 score Copper mesh inside the tube purifies the air for more torquepowers. Exhaust will smell great too.
![]() Join Date: Jun 2010 Location: Fort Worth, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Ebays for da win! unless you like spending money, at the end of the day it is just a pipe. shoot, some home depot fabulous PVC would probably work just as well. |
| The Following 2 Users Say NO Thank You to darkmx-6 For This Un-useful Post: | g00s3y (08-25-2017), Thepedigree13 (08-21-2017) |
![]() Join Date: Aug 2017
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Are u looking to sell the other TIP? Do the Speed6 and speed3 share the same TIP? Sent from my iPhone using Tapatalk |
in the future possibly
__________________ Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop JBR: rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter To install: downpipe, Damond EGR delete | |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score Intakes are the same between MS3/6
__________________ Genpoo stuff |
| Not Ranked : 0 score Different mounting locations (mounts holding up intake) between 6 and 3 though depending on intake brand. |
If it's fits I'm certainly interested, bought a 07 Speed6 a few weeks ago and looking to start modifying it. Wanna do a intake, TIP, HPFP, and Cobb APV3 all in one shot. If I'm not mistaken the TIP dosent have any mounting brackets it's just the intake itself correct? Sent from my iPhone using Tapatalk | |
| Not Ranked : 0 score CS part number for the TIP is the same for 3, 6, and CX7.
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | Bexar (08-23-2017), drive_sideways (08-22-2017) |
(Thread Starter) | Not Ranked : 0 score Update: I now have a CP-E turbo inlet pipe which appears to be bigger than the Cobb Maybe I'll do a side-by-side of my turbo inlet pipes to comparison
![]() | | #19 | ![]() |
Groans: 438
| Neutral : +1 score It doesn't matter what one you use, unless you have an actual tune on there, you aren't gaining anything. Why do you have so many TIP's?
| The Following User Says Thank You to g00s3y For This Useful Post: | Thepedigree13 (08-26-2017) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score If u are interested in selling the CS PM me. I'm located in upstate NY Sent from my iPhone using Tapatalk |
| The Following User Says NO Thank You to drive_sideways For This Un-useful Post: | Thepedigree13 (08-26-2017) |
![]() | | #21 | ![]() |
Groans: 64
| Not Ranked : 0 score This thread is full of fail. Why so many TIPS? Either you have no idea wtf you're doing, or you are stealing parts. Either way this thread is dumber than antifa!!
![]() | | #22 | ![]() |
Would have been easier to go full. Sent from my Nexus 6P using Tapatalk
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Thepedigree13 (08-27-2017) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score I buy and sell parts. Many times I will offer to buy out all parts they're selling as a package deal and then I sell what I don't need.
![]() | | #24 | ![]() |
Groans: 126
![]() | | #25 | ![]() |
What makes this thread dumb? It's a legitimate question. Why wouldn't it be possible for 2 parts made by 2 different companies give different results. that happens all the time. | |
| The Following User Says Thank You to darkmx-6 For This Useful Post: | Bexar (08-30-2017) |
