> 2010 MS3 - Turbo Induction
 Old 09-25-2016, 08:15 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Corksport BPV
Just writing to ask those of you who have installed a corksport bpv, have you guys had any problems with the valve?
My story is this, I had to take apart my bpv because of 2 things, first, it needed maintenance because it has been more than 6 months since the last maintenance and cs recommends every 6 months inspection and so forth. Second, a few screws from the top cover are damage and I can't take apart the valve so in order to deal with these 2 problems I decided to take out and install back oem bpv. After installing the oem bpv, I took my car for a drive just to see everything was working fine and I noticed my car so different, more power, I could feel the car pulling harder and wheels going crazy.
I'm like what is this? with the cs bpv, the car is suppose to run better than oem.
I read a review on the cs site about a guy's spring was broken inside the valve. Since I can't get it apart, I'm still yet to find out if anything else is worng. I'm also having my doubts that the valve is leaking although i'll be performing a boost leak test on Tuesday.
Anybody has com across with something like this???
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 09-25-2016, 11:02 PM   #2
BenderIsGreat's Avatar
Posts: 11   (View Stats)
BenderIsGreat has a spectacular aura aboutBenderIsGreat has a spectacular aura about
Just sounds like yours is damaged to me. Are you hitting your boost targets in your data logs?
I'm running one, and it's been fine. But, I guess I haven't compared it to another bpv in a long time. I may throw the stocker back in too temporarily, just to see how it feels.
BenderIsGreat is offline   Reply With Quote
 Old 09-26-2016, 02:30 PM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
The spring inside my CS BPV broke after owning it for a year, it was purchased used from someone on here, no idea how long they had it. I hit up CS, they replaced the spring for me for free, and haven't had a problem since.
I also replaced the screws on top with stainless screws, just because.
 Old 09-26-2016, 02:41 PM   #4
welp, i probably need to check mine. i haven't checked it in a while.
 Old 09-26-2016, 03:19 PM   #5
g00s3y's Avatar
Groans: 438
I only noticed minor weird issues above 22psi on the S3, and decided to check it. Spring was was still "together" inside, still holding boost decently, but broken into 3 pieces when I turned it upside down and let it fall out.
 Old 10-23-2016, 04:06 PM   #6
Malbosia's Avatar
Posts: 67   (View Stats)
Malbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these partsMalbosia is infamous around these parts
Groaned at 85 Times in 26 Posts
I have serviced mine religiously. Went to clean and lube the valve today and found my spring broken in half. Hoping I can get a replacement quickly.
Malbosia is offline   Reply With Quote
The Following User Says Thank You to Malbosia For This Useful Post:
dvswimer (01-02-2018)
 Old 10-25-2016, 09:04 PM   #7
ryguy 3's Avatar
Posts: 353   (View Stats)
You can add me to the list.
 Old 10-26-2016, 07:01 AM   #8
TORQUERULES's Avatar
Posts: 283   (View Stats)
Wow, I guess I need to check mine now. I hope this gets resolved.
2017 Mazda CX-3 Meteor Gray
 Old 12-20-2016, 04:14 PM   #9
Janks's Avatar
Posts: 12   (View Stats)
Janks has a spectacular aura aboutJanks has a spectacular aura aboutJanks has a spectacular aura about
Havn't had mine on for more than a summer but it was definetly more efficient than the stock BPV, I did have a sealing problem but that was due to the previous owner stripping the threads I agree I hope this is resolved!
Don't be upset with the result you didn't get with the work you didn't do
'11 Speed 3
Built motor (Manley h beams mahle pistons no headwork) Gt3582r Stock intake/exhaustTr8 Cs bpv Aem meth (1000cc)
Neo coils Jbr 3.5 intake Jbr trans mount cpe rmm corksport pmm Ss lines Hp+ pads Bm spec aero tuned by Nishan
Let's see what it'll do build
'85 Rx7 Gs
Gsl rear end full exhaust, rb header vibrant reso/ muffler, fc front subframe swap in the near future, keep it classic cruiser
Janks is offline   Reply With Quote
The Following User Says Thank You to Janks For This Useful Post:
 Old 12-20-2016, 05:19 PM   #10
g00s3y's Avatar
Groans: 438
I wonder if that's the reason they released a new kind of BPV. Hopefully nothing in that one will break, as I'll be buying that once the motor is together.
 Old 12-20-2016, 05:55 PM   #11
TheSixthSpeed's Avatar
Posts: 131   (View Stats)
TheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to behold
I'm also going to do maintenance on mine.
My stock BPV couldn't hold more that 18psi of boost without leaking.
I had purchased a fake HKS for $120, it had everything need to do recic, but after I set everything up and closed the hood the nipple didn't clear the hood intake so it broke off and I had to return it.
I got the CS because it was the cheapest real BPV option and also because of it's fast recirculating. I was able to run almost 21psi thanks to it.
TheSixthSpeed is offline   Reply With Quote
The Following User Says Thank You to TheSixthSpeed For This Useful Post:
 Old 12-21-2016, 03:41 AM   #12
frothy's Avatar
Posts: 1,067   (View Stats)
Not the first time i've heard of this.
I had two holes strip out upon first disassembly. I found those short bolts to have very little thread engagement. I wasn't impressed. I ended up tapping all the holes out slightly and replacing the hardware with longer M4-0.7 x 12mm socket cap screws.
 Old 12-21-2016, 06:27 PM   #13
Jonb82's Avatar
Posts: 416   (View Stats)
What were the symptoms of the stocker not holding? Anything other than viewing datalogs?
Sent while probably pooping
 Old 12-21-2016, 06:41 PM   #14
Well, I just ever made anywhere close to my target boost levels, even load(since I load tune).
The car just never made the power that I tuned it for. I thought I had a boost leak... well technically the BPV was leaking boost but since it recirculates, it doesn't screw over the AFR, so the ECU doesn't see anything wrong I guess. That's why your not really going to get any messed up symptoms. If you had VTA BOV, you would definately run really reach during WOT and not just while coming off the throttle.
 Old 12-22-2016, 11:30 AM   #15
Jonb82's Avatar
Awesome thank you. Looks like I will be getting some rice for a Christmas present. Tuner said I might have a boost leak. Found one and tapped the threads of the nozzle on my TIP. Still was there. Funny though through my searching I seems like the stock one holds well up to 22psi
 Old 12-22-2016, 04:55 PM   #16
Yeah, it's pretty mixed. Some people say the stock valve doesn't need to be replaced and you are a ricer if you do. However some people say the stock valve leaks. There is actually a thread around here I read some time ago that supposedly says the stock valve is "designed" to leak above a certain boost pressure. That same thread showed how to modify the stock BPV to make it hold more boost by closing of the small hole on the bottom with something, I don't know if it was epoxy.
All I know is that my valve was limiting my power without a doubt, because as soon as I swapped in the CS, it was boosting around 19psi and even spiked at 22psi. My stock valve never even spiked near that.
Product Release!! CORKSPORT 2010+ Mazda 3 Skyactiv Air Box for CorkSport SRI CorkSport CorkSport 0 07-11-2013 04:00 PM
CorkSport Announces Release of New CorkSport Stub Antenna CorkSport CorkSport 5 10-03-2012 09:31 PM
CorkSport Product Release! ? Introducing the New CorkSport Radiator Cap CorkSport CorkSport 0 08-05-2011 06:30 PM
Page generated in 0.35450 seconds with 31 queries
