> 2010 MS3 - Turbo Induction
  • 1 Post By MSMS3
 Old 04-19-2019, 06:11 PM   #1
Nick0530's Avatar
Posts: 13   (View Stats)
Nick0530 is an unknown quantity at this point
Default Forge BPV v1 / v2 confusion
So i just purchased my forge bpv, which i was thinking was a v2. After talking to my buddy he is pretty sure it's a v1.
My question is why are there so many part numbers that are different and why would they sell the v1 on most sites when the v2 apparently fixes a lot of the issues? (zelda sword)
The one on Edge: https://edgeautosport.com/forge-moto...wrx-2008-2014/
And then the one on SU: https://www.streetunit.com/Forge_ByP...fmdvmaz3-s.htm
Now I'm pretty sure the Edge one is considered a v1, and SU would be a v2. However, did they possibly come out with an updated v1 that got the same benefits the v2 did? Or did I just order a v1 lol
Thanks for the help
Nick0530 is offline   Reply With Quote
 Old 04-25-2019, 07:50 PM   #2
Nick0530's Avatar
For anyone wondering or for future use, I was able to get in contact with a few people and found out what's going on.
The "v1" that they sell now is actually a second generation v1. Updated with some minor adjustments to fix some of the issues the OG v1 had.
You can still find the v2 some places, but the v1 gen 2 bpv is mostly sold and they supposedly like that design better and found a workaround.
 Old 05-21-2019, 07:44 PM   #3
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
I have version 2 pull type(no sword clashing sound) and i like it better! it holds boost much better than push type.I bought it directly to forge motorsports.
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 11-08-2019, 08:31 PM   #4
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
I got that exact one on edge, pretty confident that it was a v2, and it clinks like shit. I can't do it. $166 paper weight.
If anyone has a part # for the STEALTH forge bpv, please end this and share it. Thanks.
Sent from my Pixel 3 using Tapatalk
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 11-08-2019, 08:40 PM   #5
MSMS3's Avatar
Posts: 2,826   (View Stats)
FWIW the OEM bypass valve has been shown to hold boost about 2 psi better than Forge at up to a bit over 20 psi according to Grass Roots Motorsports Magazine. And since 20 psi is above the efficiency map of the K04 at higher rpm, you are just buying a noisy paperweight unless you are going big turbo.
And for God’s sake you engine will thank you to run any valve in recirc mode. This is a MAF controlled engine and metered air needs to go back into the engine, not farted to atmosphere.
Sonofnothing likes this.
Oil pan confusion Hatchbackluva 2010 MS3 - Engine, Transmission & Driveline 3 05-30-2018 07:31 PM
LC/NLS Confusion Fstrnyou VersaTune 2 01-31-2017 04:52 AM
Forge v1 BPV confusion! nas711 2010 MS3 - Turbo Induction 1 03-31-2015 04:42 AM
Maf cal Confusion neil123456 MazdaSpeed 3/6 - ECU Computer Tuning 3 07-25-2013 12:39 AM
Page generated in 0.25794 seconds with 24 queries
