> 2010 MS3 - Turbo Induction
  • 1 Post By smoogs12
 Old 07-29-2012, 12:20 PM   #1
azer's Avatar
Posts: 5   (View Stats)
azer is an unknown quantity at this point
Default installed corksport intake, not hitting full boost.
hey hows it going im new to this forum just got my 2011 ms3 about 2 weeks ago. i recently installed CORKSPORT Stage II Power Series Short Ram Intake. and ever since then ive noticed that i havent been hitting the peak boost on my stock gauge. can anybody help on why it might be happening? im going to uninstall it this tuesday and put it back on maybe i left something loose or i forgot something, any info on this is appreciated.
thank you everyone in advance.
azer is offline   Reply With Quote
 Old 07-29-2012, 12:23 PM   #2
irishking03's Avatar
Posts: 2,136   (View Stats)
Do you have AccessPort.. Im not to fimilar with gen 2 but if you had a AP you could do some loggin and post up for everyone to see where its going wrong.. GL
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
 Old 07-29-2012, 12:26 PM   #3
azer's Avatar
no i dont have AP.
 Old 07-29-2012, 12:28 PM   #4
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
you're first mistake is reading your stock "boost Gauge" as anything more than an On-Off light.
You need an aftermarket boost monitoring source (manual or electronic Boost Gauge) to tell if you're in fact not hitting 15-16psi.
If you're not, then the first step would be checking all connections on the intake so you can rule out air leaks (because that's what the problem would be). You can go ahead and do that now anyway, for peace of mind. Spray silicone around all connections for extra peace of mind.
The top bar on the stock gauge will always flicker on and off...the Gen2 wont hold max PSI throughout the entire RPM range without a third party tune.
cesaros is offline   Reply With Quote
The Following User Says Thank You to cesaros For This Useful Post:
azer (07-29-2012)
 Old 07-29-2012, 12:33 PM   #5
mike0122's Avatar
Posts: 448   (View Stats)
mike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the worldmike0122 is the leader of the world
Not much that you could of left loose, but if it worked fine before the install just recheck all the clamps. What are your boost numbers at?
Just some car stuffs. Zip 87120
mike0122 is offline   Reply With Quote
 Old 07-29-2012, 12:36 PM   #6
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Check the hose connecting to the boost control solenoid.
smoogs12 (07-29-2012)
 Old 07-29-2012, 12:40 PM   #7
azer's Avatar
i know its not a reliable source on telling me the psi, but before the intake it would at least show it went all the way to 15psi. im going to recheck all the clamps.
the boost it shows is maybe 1 or 2 squares before it hits the max 15 psi., and when i was in high rpm's last night i saw the boost drop a little when i was aroung 5k
 Old 07-29-2012, 12:44 PM   #8
08.5MS3's Avatar
Groans: 89
I'm not sure what the stock boost levels look like, but I would not be the least bit surprised if it tapered towards red line. All that hot air and nothing to cool it.
 Old 07-29-2012, 12:47 PM   #9
azer's Avatar
im going to check all hoses and clamps on tuesday, make sure everything is in place. thank all of you for the input really appreciate it.
 Old 07-29-2012, 01:00 PM   #10
mike0122's Avatar
Yeah I'm sure its just something little you missed. Good luck.
 Old 07-29-2012, 01:24 PM   #11
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Without logs it's impossible to say, but seeing as the stock tune is load targeting and not boost targeting, you could just be hitting your load targets at a lower psi for whatever reason.
Tapa
Atticaz likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 3 Users Say Thank You to smoogs12 For This Useful Post:
08.5MS3 (07-29-2012), Atticaz (04-10-2015), SPEEDRAC3R (08-09-2012)
 Old 08-09-2012, 05:04 PM   #12
The Nut's Avatar
Posts: 1,571   (View Stats)
Everyone on here has given you great advice. A leak in one little spot could cause it, but far more likely, since you haven't tuned the ECU with an AP to tell it it's getting more air and to adjust the f/a ratio, the ECU is just trying to meet the factory tuning parameters. The K04 (and every turbo) is computer controlled and doesn't know what to do with all the extra air it's getting. This will keep it from spooling up properly and your entire system will run like shit. As you'll come to read all over this and every forum, an AP is the first thing you want to get before starting ANY upgrades. Once you do, do some logs so that experienced tuners on here can show you what is going wrong..
Your ECU will do some adjusting on its own as it goes through the "adjustment period" to a certain degree. So you may find it improves a bit on its own. But without logging, your running the risk of a complete fail if it doesn't, at very least, have an OTS flash to tell it it's getting more air. You also haven't upgraded your internals and the factory ones may not be able to keep up. This is a very dangerous fail if your running lean. Search and read and don't go boom!
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 08-09-2012, 06:16 PM   #13
sxshep's Avatar
Posts: 155   (View Stats)
sxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the worldsxshep is the leader of the world
I had the same problems on my 09, would only hit 12psi on occasion (monitoring on AP)... would only happen so often. I was also getting a stuttering problem.
First place I would look is inside the filter, see if the little air straightener has fallen or shifted out of the MAF. Mine was rattling inside the filter and under partial accel it would get sucked in sideways into the MAF and cause all kinds of chaos, preventing the turbo witchcraft from occurring to its full potential. Check there before you start ripping the whole thing out.
COBB ACCESSPORT JBR RRM CORKSPORT SRI/TIP JBR SSP/BUSHINGS
sxshep is offline   Reply With Quote
The Following User Says Thank You to sxshep For This Useful Post:
Dmurray06 (08-09-2012)
 Old 08-09-2012, 06:24 PM   #14
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
Just a thought. I know pu's are more probe to fuel pump issues. Is it possible adding an intake is causing fuel/boost cut? Also, is this intake only or intake and turbo inlet? If you got the tip too, check and make sure the nipples are not clogged. My sure intake had hot clue stuck in one and only let me hit 10 psi.
Stage 2... Not hitting full boost 2010Speed3 2010 MS3 - Troubleshoot/Diagnostics 27 06-14-2018 07:47 PM
HELP!!!!Not Hitting full boost anymore!!!! dadon1985 2010 MS3 - Troubleshoot/Diagnostics 22 04-10-2011 09:19 PM
now im not hitting full boost.. grrr TheFranchizeSLB 2010 MS3 - Turbo Induction 9 11-29-2010 02:21 PM
Not hitting full boost Post pwned 2010 MS3 - Turbo Induction 10 11-28-2010 01:22 PM
Not hitting full boost on Hypertech Cobb flash JohnMS3 MazdaSpeed 3/6 - ECU Computer Tuning 22 07-22-2010 04:33 PM
Page generated in 0.33779 seconds with 28 queries
