> 2010 MS3 - Turbo Induction
 Old 02-12-2019, 01:25 PM   #1
Coltzxli's Avatar
Posts: 45   (View Stats)
Coltzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to behold
Default Is this interrupt configuration on Cobb BSC?
Hi all. I am being tuned by Will at PD. He suggested I get a 3 port EBCS. I bought a Cobb and while looking at the installation instructions it does not specifically say "interrupt" and I want to make sure this is the correct diagram before I install and take the car out for a datalog.
Screen Shot 2019-02-12 at 12.33.00 PM by z, on Flickr
Coltzxli is offline   Reply With Quote
 Old 02-12-2019, 02:34 PM   #2
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
Yes if the #2 is the common port, #3 is NO and #1 is NC.
Having the BPV in the picture is a bit confusing has it is 2 separated device....
Keep your hose as short as possible and using the bottom port instead of the top permit the use of a larger hose too.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-12-2019, 03:12 PM   #3
Coltzxli's Avatar
Thanks for the reply.
Cobb does not have the ports labeled, but I think this is correct, I did email cobb today but I have not heard back yet.
 Old 02-13-2019, 09:31 AM   #4
Jeff23spl's Avatar
you can confirm it by checking where the air pass thru.
Common into Normally Open (NO) should be open without power (normal state)
Common into Normally closed (NC) would become open when 12v is applied. (with 12v, the NO would be blocked)
just be careful not to mix common and NO because it will still seem to work with a bad response.
Wife drive 2010 CX7
Grimmspeed 3 port interrupt mode-Stock K04 mrmonk7663 2010 MS3 - ECU Computer Tuning 115 08-13-2014 10:40 PM
3 port solenoid (GrimmSpeed or COBB) interrupt and bleed connection diagram Lex Stratified Automotive Controls 6 08-27-2012 02:31 PM
Resin shortage could interrupt production, supplier says Haltech Automotive News 0 04-13-2012 01:30 PM
Dp/tp configuration options jack_hammer Mazdaspeed3/6 General Discussion 26 01-25-2012 12:21 PM
grimmspeed in interrupt TWOptSL0W MazdaSpeed 3/6 - ECU Computer Tuning 6 09-25-2011 01:42 PM
Page generated in 0.24870 seconds with 21 queries
