> 2010 MS3 - Turbo Induction
Like Tree417Likes
 Old 04-28-2014, 12:43 PM   #521
Just got off the phone with Bryan. Some suggestions were to run the compressor (restricted) nipple to the WGA top port only, remove the EBCS from the equation. Considering I think my WG flapper is hosed and maybe even my WGA not working properly, I don't like that idea.
The other suggestion which I will do is remove the arm from my flap and get her up to temp and see if it's sticking. I probably do have a two-fold issue, we'll find out.
And I made mention that it *appears* the single barb units aren't having as many issues - awaiting further details, and pending my results we'll be swapping me to a single barb when I visit his shop Saturday.
IMO, fuck that. If anything you would run an unrestricted source to the gate.
can you get a compressor and t a gauge in to the high pressure source? You'll need someone to watch the arm.
2.0t03speed likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
2.0t03speed (04-28-2014), JgamB (04-28-2014), JTMS3 (04-28-2014), Kyle Undefined (04-29-2014), nindoja (04-28-2014)
 Old 04-28-2014, 12:49 PM   #522
nindoja's Avatar
Posts: 2,395   (View Stats)
If you're running 3 port, don't use the compressor port as a boost source. Use your BPV line/manifold or off your charge piping.
I actually recommend trying with the 2 port setup and run this turbo exactly like OEM with the 2 port EBCS. Two port (bleed style) boost control is more forgiving than 3 port and you can keep your Dynamics tables pretty much stock. I recommend dropping your WGDC table in the 20s and working your way up.
We tried teeing off of the IM/BPV hose originally but we still had the issue.
I may have @JgamB; bring his 2 port controller over and have us try that out. @rfinkle2;, if we go this route, can you shoot us a base map for that?
I have a compressor, the T we used for the IM/BPV, and can get this done. Unfortunately, it may have to wait due to a high probability of tornadoes in the area tonight.
I'll post back results when we get a chance to do them.
Wouldn't putting the compressor nipple directly to the waste gate just keep the gate open at whatever preload pressure was? If the waste gate is broken, how is this proposed setup any different than having an EBCS in the loop? If the waste gate functions, you'd just see spring pressure without the possibility of EBCS mucking with anything.
Or are you talking about the option of having the arm disconnected from the flapper? I would think that would just result in 0 boost since the flapper would press open relatively easy.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Last edited by nindoja; 04-28-2014 at 12:49 PM. Reason: MSF Database - Automerged Doublepost
JgamB (04-28-2014)
 Old 04-28-2014, 12:50 PM   #523
Always go back to the base, lowest boost, least complicated setup. In this case it is spring pressure. Make sure that is under control before even attempting to add an EBCS.
If it's not use a hand pump to make sure the WG actuator is opening and closing without catching on anything with the car off and after it's cool.
There should be a few mm of preload on the arm - 2-4mm is a good starting point.
 Old 04-28-2014, 12:52 PM   #524
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
For those that don't have excel readily accessible, here is a web version of the log - AP log viewer
I see what you did there
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 04-28-2014, 12:57 PM   #525
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
Try Edge? I put in an order for one after catching up in this thread this morning.
I'm not completely sure but I think they are a drop order from stratified. I could be wrong
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
 Old 04-28-2014, 12:58 PM   #526
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
The history of BNR S3 turbo boost control goes like this:
1. The original S3 had a single barb WG actuator. It had very good boost control unless you were catless
2. After this, while still using the K04 exhaust side a number of S3s started coming out with the two port actuator. This had really poor boost control where fluctuations in boost and creep were very hard to control. This one also has the upgraded compressor housing with the port on the side but NO restrictor in the port.
3. The new V2 S3 has a restrictor in the compressor housing port. This is so you can run this with your OEM 2 port EBCS. It appears that most of them also come with the dreaded 2 port WG actuators. The other variable is the new housing and how well matched the WG door is.
Start with spring pressure only and see how it responds to punching it at different RPMs. The two port actuators would spike at higher RPMs and undershoot when at lower RPMs on spring pressure.
If you determine the actuator is the problem and even on spring pressure alone you are getting different boost responses at different RPMs, adjust the preload. If you are getting spiking, lower the preload. If you are underboosting, increase the preload.
The actuator from my discussion with Bryan should be around 13-14psi so this is what you're shooting for on spring pressure.
Blahhh.
Why does this have to be so damn complicated? @rfinkle2; I honestly dont know how I should hook my EBCS up. I have the 2 port WG Actuator.
Silver 2007 Speed3 GT
 Old 04-28-2014, 01:00 PM   #527
nindoja's Avatar
Blahhh.
Can you wait until this weekend is over? Or even later this week? @JgamB; and I will be working this throughout the week and will post up our findings here.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
Easter Bunny (04-28-2014), Kyle Undefined (04-29-2014)
 Old 04-28-2014, 01:01 PM   #528
Blahhh.
The setup I mentioned before will work for both dual and single wastegate nipple cause I'm only using one correctly. Someone else should try it and see if it work for them.
2012 Mazdaspeed3
Columbus, Ga
 Old 04-28-2014, 01:03 PM   #529
I don't know what Bryan is proposing, but see no reason why he would propose using a restricted source to the wastegate if you guys are experiencing creep.
You want the signal line to the wga to send full boost to the wga.
 Old 04-28-2014, 01:03 PM   #530
This weekend is the only weekend that will work to put the turbo in. I will check when I get home to see if I have the 2 port WG actuator...i'm pretty positive I do though.
 Old 04-28-2014, 01:05 PM   #531
If you are going to use a 2 port, have Lex tune it.
2.0t03speed (04-28-2014), killer-ms3 (04-29-2014)
 Old 04-28-2014, 01:06 PM   #532
chaser27's Avatar
Groans: 42
I think he just wants to rule out the EBCS. The restrictor will still allow full boost to the WGA, it will just take slightly longer for it to happen if restricted.
Sent from my XT1080 using Tapatalk
ECU: self-tuned
 Old 04-28-2014, 01:09 PM   #533
I'm not planning on using a 2 port as I feel like the 3 port will be better.
But, since theres such a contrast between the 2 and single port WG Actuators I just have no idea how to hook up my EBCS since I have the 2 port WG Actuator. lol I was planning on compressor housing, cap the other port on the WG actuator, WG actuator other nipple, and the intake. But now people are saying that I will creep like crazy with the 2 port WG actuator running this setup..... head is spinning a little lol
 Old 04-28-2014, 01:09 PM   #534
I am not going to participate in this "experiment" any longer, because quite frankly, you guys are playing with a mechanical problem and fire.
There is no reason that everyone's BCS would fail on JTMS3's turbo, Jgam's turbo etc.
Testing all of these things on more than one car is proving to be too much of a liability for me tbh.
The Following 13 Users Say Thank You to rfinkle2 For This Useful Post:
2.0t03speed (04-28-2014), bstover17 (04-28-2014), cbunn79 (04-30-2014), chaser27 (04-28-2014), Easter Bunny (04-28-2014), HawkeyeGeoff (04-28-2014), JgamB (04-28-2014), JTMS3 (04-28-2014), killer-ms3 (04-29-2014), Kyle Undefined (04-29-2014), maisonvi (04-28-2014), nindoja (04-28-2014), Quigs (04-28-2014)
 Old 04-28-2014, 01:10 PM   #535
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Can someone just tell me if running 3 port (GS configuration) would be "safe" since I have only 1 nipple on the wga? I am just confused now and don't quite understand turbo tech talk. lol
 Old 04-28-2014, 01:12 PM   #536
A 3 port and 2 port have no influence on creep.
If the wastegate is allowed to open without driving the bcs, such as in the logs posted, it doesn't matter if you have a 10 port bcs.
I would run only spring pressure / no solenoid.
To do this, you would run the high pressure source straight to the wga.
2.0t03speed and HawkeyeGeoff like this.
Last edited by rfinkle2; 04-28-2014 at 01:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-28-2014, 01:12 PM   #537
If the wastegate is allowed to open without driving the bcs, such as in the logs posted, it doesn't matter if you have a 10 port bcs.,
Roger that. Sticking with the initial plan then.
 Old 04-28-2014, 01:14 PM   #538
SneakySin's Avatar
Posts: 780   (View Stats)
SneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the world
Groaned at 7 Times in 4 Posts
Originally Posted by JTMS3 View Post
@SneakySin; input??
Sent from my EVO using Tapatalk
I'm in the midst of a Freektune right now. On my first revision since my base map and having zero issues. This turbo is stout. No creep issues and boosting peak about 20psi. Everything is golden thus far just waiting on my next revision to see how things look but so far so good. Very impressed with my car so far.
2008 Speed 3
CS 3" Intake//BNRS3v2//GS EBCS//3BAR MAP SENSOR//AT FP Internals//ATP DP catless//Custom FMIC//JBR Stage 3 SSP//CP-e Stage 2 RMM//MD OCC w/Sight Tube//EGR Del//NGK Iridium IX Plugs//Cobb AP//FreekTuned!!!!!
SneakySin is offline   Reply With Quote
The Following 6 Users Say Thank You to SneakySin For This Useful Post:
HawkeyeGeoff (04-28-2014), JgamB (04-28-2014), Jonathanhair07 (04-28-2014), JTMS3 (04-28-2014), Kyle Undefined (04-29-2014), spals (04-28-2014)
 Old 04-28-2014, 01:14 PM   #539
Be safe.
2.0t03speed (04-28-2014), Kyle Undefined (04-29-2014), nindoja (04-28-2014)
 Old 04-28-2014, 01:15 PM   #540
You running the 2 port WG Actuator or the single nipple?
In fact, it really pisses me off that there would be TWO DIFFERENT FUCKING VERSIONS on the same turbo.
neganox likes this.
The Following 5 Users Say Thank You to HawkeyeGeoff For This Useful Post:
bstover17 (04-28-2014), JTMS3 (04-28-2014), Kyle Undefined (04-29-2014), neganox (04-28-2014), nindoja (04-28-2014)
 Old 04-28-2014, 01:18 PM   #541
chaser27's Avatar
Groans: 42
I don't blame you. People are too often looking for someone to blame when something goes wrong. More often than not, the tuner...
To me, the fact that @JgamB; is hitting 13psi with 0 WGDC, but then after he does a few WOT pulls is hitting 27, tells me it isn't the EBCS, not the WGA, but instead something in the flapper assembly binding after the metal is given time to expand.
Subbed for results.
rfinkle2, kornybun and JgamB like this.
ECU: self-tuned
Last edited by chaser27; 04-28-2014 at 01:20 PM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to chaser27 For This Useful Post:
BackRoads (04-28-2014), HawkeyeGeoff (04-28-2014), JTMS3 (04-28-2014), kornybun (04-29-2014), Kyle Undefined (04-29-2014), rfinkle2 (04-28-2014)
 Old 04-28-2014, 01:21 PM   #542
2 guys have 2 distinct metallic noises coming from this turbo. I should have recognized an issue right there and called it quits.
JTMS3 and Jgamb both report this metallic sound and had boost issues.
I may not be an engineer, I may be prideless and fly by night, but this ain't the first car I tuned and understand boost control as well as anyone, imo.
The Following 16 Users Say Thank You to rfinkle2 For This Useful Post:
2.0t03speed (04-28-2014), bstover17 (04-28-2014), cbunn79 (04-30-2014), chaser27 (04-28-2014), dale_gribble (04-28-2014), JgamB (04-28-2014), JTMS3 (04-28-2014), killer-ms3 (04-29-2014), kornybun (04-29-2014), Kyle Undefined (04-29-2014), maisonvi (04-28-2014), ms3blackmica (04-28-2014), natieb (04-29-2014), nindoja (04-28-2014), pharaoh313 (04-28-2014), Tokay444 (04-28-2014)
 Old 04-28-2014, 01:25 PM   #543
JgamB's Avatar
Posts: 2,566   (View Stats)
This is why I'm a shitty candidate for troubleshooting EBCS setups - I'm 99% certain I have a mechanical problem and no amount of hoses and nipples is going to fix it, although we could have an orgy.
JTMS3 likes this.
The Following 8 Users Say Thank You to JgamB For This Useful Post:
bstover17 (04-28-2014), chaser27 (04-28-2014), Easter Bunny (04-28-2014), HawkeyeGeoff (04-28-2014), JTMS3 (04-28-2014), kornybun (04-29-2014), Kyle Undefined (04-29-2014), rfinkle2 (04-28-2014)
 Old 04-28-2014, 01:32 PM   #544
You can run both 2 port and 3 port on any of the WG actuators.
If you are running 3 port, DO NOT use the compressor housing port as a boost source.
If you are running 3 port on a 2 port WG actuator, simply cap off the bottom WG actuator port and the compressor housing boost source port.
Use the manifold boost source.
Attached is a log of a 3 port ran as described above on a new S3 V2 with the two port WG actuator. It does creep a little for my liking but is manageable on his fuel.
However, always test with spring pressure only. If boost is not under control then, an EBCS won't help no matter how you hook it up.
The Following User Says NO Thank You to Lex For This Un-useful Post:
 Old 04-28-2014, 01:33 PM   #545
I would just pull the turbo send it back to bnr reinstall the ko4 until it gets fix. Or just go ewg imo
2012 Mazdaspeed3
Columbus, Ga
 Old 04-28-2014, 01:39 PM   #546
This is before I was trying to kill the creep with the throttle plate (unsuccessfully).
If I request any less timing, there is a good chance of cooking an valve.
*rev limiter set to 5800 rpm.
This log was created using the manifold as a high pressure source.
Again, this car has a distinct metallic sound.
I would assume the log Lex posted had no metallic sound.
New BNRS3 Housing
2.0t03speed (04-28-2014), Easter Bunny (04-28-2014), Kyle Undefined (04-29-2014), Vansquish (04-28-2014)
 Old 04-28-2014, 01:43 PM   #547
nindoja's Avatar
Default New BNRS3 Housing
Appreciate all the ideas and support everyone. It does sound like a possible manufacturing/assembly issue when multiple people on different setups are having the same symptoms.
I'm going to go back over all the ideas posted here and think them all over. I think right now I have 4 or 5 different options and I want to lay them all out before proceeding.
@rfinkle2; I respect your desires to not be part of the experiment, although we will gladly take input from you. Neither myself or @JgamB; will blame you for this mechanical failure or any future failures relating to our diagnosis.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 6 Users Say Thank You to nindoja For This Useful Post:
Easter Bunny (04-28-2014), JgamB (04-28-2014), Kyle Undefined (04-29-2014), natieb (04-29-2014), rfinkle2 (04-28-2014), Vansquish (04-28-2014)
 Old 04-28-2014, 01:43 PM   #548
SneakySin's Avatar
2008 Speed 3
The Following User Says Thank You to SneakySin For This Useful Post:
 Old 04-28-2014, 01:45 PM   #549
Can you confirm or jgamb that using the manifold as a high pressure source still resulted in creep?
 Old 04-28-2014, 01:49 PM   #550
Police - Grammarhead
Vansquish's Avatar
New BNRS3 Housing
Sidebar:
I'm still waiting on my S3, but from what I could hear in the video posted earlier in this thread, it sounded like there was turbine/housing interference, and a bit of a "scraping" noise. Is that what you're referring to when you say there was a "distinct metallic sound?"
 Old 04-28-2014, 01:49 PM   #551
JgamB's Avatar
Every log I've sent you to this point was off the manifold. We just swapped to the compressor housing yesterday, and it was no bueno. The sample you posted with creep was port 1 TIP port 2 WGA port 3 BPV/TB Tee.
But I think you can safely toss my results in the recycling bin... WGA or flapper fail was what resulted in consecutive pulls of 17 peak PSI, then 19, then 22, then 24.
Easter Bunny (04-28-2014), rfinkle2 (04-28-2014)
 Old 04-28-2014, 01:50 PM   #552
I'd like to know this as well.
@Lex; seems to be pretty confident in not using the compressor housing as the high pressure source. I mean it shouldn't really matter one way or the other.
 Old 04-28-2014, 01:52 PM   #553
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Welp, my order was just canceled.
No offense to BNR (ok maybe a little) but this seems to be an issue with a lack of testing prior to the release.
The S3 has built it's name on being a drop in turbo with little hassle, this version appears to be neither....
The Following 3 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
Digital_Jedi (04-28-2014), Easter Bunny (04-28-2014), Kyle Undefined (04-29-2014)
 Old 04-28-2014, 01:53 PM   #554
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I want to thank the pioneers for going through this. I'm sure this will all be resolved sufficiently with a little more data and time. I feel good that Bryan will support this and make whatever right on his end he needs to.
Did anyone carefully inspect their turbos prior to install?
MINI H1 6.0 - CAR LED TAILS
Easter Bunny (04-28-2014), JTMS3 (04-28-2014), Kyle Undefined (04-29-2014), rfinkle2 (04-28-2014)
 Old 04-28-2014, 01:53 PM   #555
nindoja's Avatar
I can confirm that using the manifold source still resulted in creep.
@HawkeyeGeoff; since he was interested in answer too.
rfinkle2 and HawkeyeGeoff like this.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 4 Users Say Thank You to nindoja For This Useful Post:
Easter Bunny (04-28-2014), HawkeyeGeoff (04-28-2014), Kyle Undefined (04-29-2014), rfinkle2 (04-28-2014)
 Old 04-28-2014, 01:53 PM   #556
There certainly looks to be a lot of issues.
I would really like to be able to find a way to test for this "metal" noise before installing the turbo for those of us that have yet to make the leap.
 Old 04-28-2014, 01:54 PM   #557
Sidebar:
2 guys have now reported a distinct metallic sound to me. I have not heard it, but it is too coincidental to overlook they were both the guys who have creeped by the highest amount.
Thank you. There is no sense in confusing this situation so thank you.
Easter Bunny (04-28-2014), JTMS3 (04-28-2014), Kyle Undefined (04-29-2014), Vansquish (04-28-2014)
 Old 04-28-2014, 01:56 PM   #558
nindoja's Avatar
Nooooooo way? Fuck me, thanks for the update! Lol
Here is the sound clip you can here it begin right at the end. This was the cold start I was referring to. It obviously got worse before zzb.
BNR v2 & Full Race EM-first turn. - YouTube
That noise on throttle is exactly what we were hearing in @JgamB;'s car. @rfinkle2; this video has a noise towards the end, right after throttle input, that is what we heard.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 3 Users Say Thank You to nindoja For This Useful Post:
 Old 04-28-2014, 01:56 PM   #559
JgamB's Avatar
My completely unscientific guesstimate is the new 27mm flap has some very tight tolerances, and when it reaches full temperature it may or may not be abrading on another surface. This is my DD or I'd have already pulled the turbo to inspect.
 Old 04-28-2014, 01:56 PM   #560
I guess the real question here is....do we risk even putting this turbo on before we understand the risks?
More people=more confusion sometimes.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f424/new-bnrs3-housing-163523/
New BNRS3 Housing - Page 42 - Mazdaspeed Forums This thread Refback 09-29-2014 03:36 AM
My BNR is coming! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-29-2014 09:42 AM
MS6 BNRS3 install Stew MazdaSpeed 3/6 - Big Turbo Builds 25 06-21-2014 12:10 PM
MS6 BNRS3 kish89 Mazdaspeed3/6 General Discussion 9 08-20-2013 03:22 AM
Page generated in 0.65350 seconds with 32 queries
