> 2010 MS3 - Turbo Induction
Like Tree9Likes
 Old 12-12-2015, 09:06 AM   #1
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
Default Oil return line is leaking
Hi guys,
my BNR S1 is leaking oil at the oil return line underneath the turbo. Two months after installing the S1, it looked like this:
I cleaned everything up and installed a new upper gasket at the oil return line (when installign the BNR S1, I re-used the old gasket). It seems that there is now less oil leaking but it still leaks somewhere underneath.
Any help or hints appreciated. According to my Mazda dealer you dont have to use any kind of sealant for the screws.
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
HPFP Fuel Line Leaking Jtaylor MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 10-03-2016 06:52 PM
leaking break fluid from clutch line need help Roofis119 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-20-2014 11:37 PM
Oil Feed line leaking 7mileshome MazdaSpeed 3/6 - Turbo Induction 3 05-30-2012 01:40 PM
Leaking clutch line bova MazdaSpeed 6 - Engine, Transmission & Driveline 3 12-23-2011 10:09 PM
KO4 TURBO ON MS6 LEAKING OIL RETURN LINE GAMISTAD Mazdaspeed3/6 General Discussion 9 01-27-2011 01:06 AM
Page generated in 0.61381 seconds with 27 queries
