> 2010 MS3 - Turbo Induction
 Old 11-03-2019, 11:34 AM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Question on cams
Well ill be upgrading my turbo to corksport turbo and ive been searching to see what has been the experience when upgrading to cs cams taking into consideration turbo spool time. I’ve been researching and there is so many debate on this, some state that large profile duration cams affect spool time, others state it helps! so im looking for those of you who can share some light here whether when upgrading to cs turbo, doing cams will help in spool time directly or non-directly. Any thoughts or help will be appreciated.
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
Valve Spring Question on CS Cams eliwwjd 2010 MS3 - Engine, Transmission & Driveline 1 10-11-2019 06:35 AM
PT-P regrind cams story -- need Web weld & regrind cams MazdaGaragePat MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-10-2016 03:46 PM
Hot cams TJSpeed6 MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-14-2013 05:28 AM
What Do Cams Do? kingpin748 MazdaSpeed 3 - Engine, Transmission & Driveline 37 02-16-2009 08:25 PM
Page generated in 0.21796 seconds with 20 queries
