4Likes ![]() |
![]() Join Date: Jan 2015
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 30 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score I am getting my CS turbo fitted in a few days and had a question for those who are running it. I am aiming for between 300 - 350fwhp. I am officially out of money (and out of time to add more parts) so I am stuck with my COBB SRI being my main restriction (stock intake size?). The rest is fairly good as in my sig. Achievable with the COBB? I will replace it one day, but I do like the design etc and only got it a few months ago and can't justify right now (and it wouldn't deliver in time anyway) after the many AU thousands I have spent on the car. Thanks Last edited by nas711; 06-05-2015 at 05:44 AM. |
![]() Join Date: Jun 2013 Location: Millersville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
(Thread Starter) | Not Ranked : 0 score What about with a different intake, but on pump fuel?
__________________ 2010 Gen 2 - "SPOOOL" (VIC/AU) - Fully bolted COBB AP3 | CORKSPORT TURBO | COBB DOWNPIPE | COBB REM | AUTOTECH HPFP | CORKSPORT TRUE 3" BIG MAF INTAKE | CPE TMIC | CUSTOM HEADERS | COBB 3 PORT EBCS | 3 BAR MAP| PEDDERS COILOVERS | DBA T4 SLOTTED ROTORS | CORKSPORT EYELIDS| FORGE V1 BPV| | MAGNAFLOW | VELOCITY RED | PEARL WHITE 2PAC STOCK RIMS | TUNED BY HP-F |
(Thread Starter) | Not Ranked : 0 score I'm talking maf limits with the Cobb...hp limit it can flow before cut?
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score I have heard the cobb airbox is restrictive but I may be wrong. You should do some logs with and without it just to see. Even with the cobb maf being about oem size the tih is only 2.25" so that is more of a restriction at the moment vs the maf.
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| Not Ranked : 0 score Freek said you can make ~350whp before running out of MAF volts on a stock ID short ram. It may help with spool due to higher velocity and then impede it at higher rates of flow, just like any other small vs large orifice on the intake and exhaust side.
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Interesting, I always assumed the opposite- bigger the intake the faster the spool. |
| Not Ranked : 0 score It's an interesting concept and I don't know for sure. The VTCS in your IM is there to increase low flow air velocity for a stable idle, and tubular exhaust manis either spool faster for small ID piping or flow more up top with larger diameter piping, so I'd imagine there has to be some correlation.
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score I'm going to have to disagree @JgamB; A higher airflow velocity is going to have a lower pressure associated with it, so the turbo will have to make a larger pressure differential for the same boost pressure (relative to atmospheric).
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
| Not Ranked : 0 score I would need proof. Same way I hunted for a year that a larger intake produced more power on the K04 before making my purchase for a BNR S3 instead. (inflated g/s but no 60-100 improvement logs aside)
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." | |
| Not Ranked : 0 score I'll tell ya soon in my thread. Stock intake tune wrapping up. 3.5" intake to come in next week. ImageUploadedByTapatalk1433546262.429626.jpg |
| The Following 5 Users Say Thank You to Raider For This Useful Post: | chaser27 (06-08-2015), JgamB (06-05-2015), littleloogy (06-06-2015), speed23 (06-05-2015), Thepedigree13 (06-06-2015) |
__________________ I hugged rfinkle2 | |
I am looking at the CS website and they have a CS TIH listed, is this any bigger than the COBB one? Can't see a sizing...
__________________ 2010 Gen 2 - "SPOOOL" (VIC/AU) - Fully bolted COBB AP3 | CORKSPORT TURBO | COBB DOWNPIPE | COBB REM | AUTOTECH HPFP | CORKSPORT TRUE 3" BIG MAF INTAKE | CPE TMIC | CUSTOM HEADERS | COBB 3 PORT EBCS | 3 BAR MAP| PEDDERS COILOVERS | DBA T4 SLOTTED ROTORS | CORKSPORT EYELIDS| FORGE V1 BPV| | MAGNAFLOW | VELOCITY RED | PEARL WHITE 2PAC STOCK RIMS | TUNED BY HP-F | |
| Not Ranked : 0 score Unless otherwise noted the tih and tips are all 2.25" diameter which is basically stock sized but round instead of pancake
(Thread Starter) | Not Ranked : 0 score COBB is rated at 2.25" (57mm) and CS is rated at 60mm (2.36") ...Doesn't seem like a 400AU + shipping investment to me... Is there a recommended intake in another brand that is bigger?
| Not Ranked : 0 score Jbr or htp even cs has a 3" you need to look around man we have a vendor section which all make great products check them out they will hook you up
(Thread Starter) | Not Ranked : 0 score CS has a 3" turbo inlet hose?
![]() | | #19 | ![]() |
![]() Join Date: Oct 2014 Location: sugar land, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score they offer both 3" and 3.5" intake systems. CorkSport Power Series 2007-2013 Mazdaspeed 3 MAF 3" Intake Mazdaspeed 3 Power Series 3.5? Intake System edit: i should note that i'm note sure if they offer a "true" 3 inch inside diameter on the inlet pipe. but they do note a 3" inlet pipe on their page. they're gearing more toward the bigger maf housings on these.
__________________ guzzlin' a guinness stout. |
| The Following User Says Thank You to acousticdefbot For This Useful Post: | Easter Bunny (06-06-2015) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Mazdaspeed | CorkSport Mazda Performance Parts Www.hitunedperformace.com James Barone Racing, Aftermarket Performance
| The Following User Says Thank You to speedfreak44 For This Useful Post: | Easter Bunny (06-06-2015) |
![]() | | #21 | ![]() |
Only thing I can see on the corksport page for gen 2 3's is the 3" and over intake system. They do list a power TIH (only 1, in alum) , but it says 60mm, which is stock size. Turbo Inlet Pipe | Mazda Intake only TIH listed on corksport website. Guess i'm gonna have to go another brand..
__________________ 2010 Gen 2 - "SPOOOL" (VIC/AU) - Fully bolted COBB AP3 | CORKSPORT TURBO | COBB DOWNPIPE | COBB REM | AUTOTECH HPFP | CORKSPORT TRUE 3" BIG MAF INTAKE | CPE TMIC | CUSTOM HEADERS | COBB 3 PORT EBCS | 3 BAR MAP| PEDDERS COILOVERS | DBA T4 SLOTTED ROTORS | CORKSPORT EYELIDS| FORGE V1 BPV| | MAGNAFLOW | VELOCITY RED | PEARL WHITE 2PAC STOCK RIMS | TUNED BY HP-F Last edited by nas711; 06-05-2015 at 07:55 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #22 | ![]() |
| Not Ranked : 0 score that is only the inlet pipe. the three inch one comes with their system (maf housing, couplers, and clamps included). you could always call or email them to see if they can set you up with the inlet pipe only. you won't contract any diseases by asking.
![]() | | #23 | ![]() |
I couldn't find any metrics showing a round turbo inlet pipe was more than cosmetic either, lol. I'm just full of piss and vinegar tonight.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following User Says Thank You to JgamB For This Useful Post: | chaser27 (06-08-2015) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score speedweirdo44 gave you htp's link. they offer a three inch inlet pipe by itself, powder coated in black.
__________________ guzzlin' a guinness stout. Last edited by acousticdefbot; 06-05-2015 at 09:46 PM. Reason: whack grammar. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Thanks -_-
| The Following User Says Thank You to speedfreak44 For This Useful Post: | acousticdefbot (06-05-2015) |
![]() | | #26 | ![]() |
| The Following User Says Thank You to acousticdefbot For This Useful Post: | speedfreak44 (06-05-2015) |
![]() | | #27 | ![]() |
I wish that I had the time to design a 3 or 3.5 inch equivalent tip that was modeled after the stock. With an equivalent flow area and squashed to get by the ecu I think it would appeal to a lot of people. Shit even just sitting on an available aluminum one would probably get you close.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | JgamB (06-06-2015) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score @Easter Bunny; Didn't it just impact the spool time of the k04 like reducing it by a little? Like basically nothing to worry about on a k04. But OP supposedly has a cs turbo which may benefit from a large 3"-3.5" tih.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Its been too long to remember all of the details, just that changing the tip was more of a why not do it while your there. Now larger size full intakes (filter to turbo) have shown gains on all turbos even if you aren't maxing the maf
| The Following User Says Thank You to Easter Bunny For This Useful Post: | chaser27 (06-08-2015) |
| Corksport turbo question | nas711 | CorkSport | 30 | 06-05-2015 09:28 AM |
| Serious Question Guys | Teejhorse | Mazdaspeed3/6 General Discussion | 27 | 07-26-2013 03:38 PM |
| Question for you BT Guys | ManiacMx3 | Mazdaspeed3/6 General Discussion | 18 | 04-16-2012 07:22 AM |
| Question for guys with KR | mtlms3 | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 12-05-2008 10:02 AM |
