> 2010 MS3 - Turbo Induction
  • 1 Post By Lex
 Old 03-19-2013, 12:20 PM   #1
RxHeadkicks's Avatar
Posts: 13   (View Stats)
RxHeadkicks will become famous soon enoughRxHeadkicks will become famous soon enough
Default Stupid broken boost solenoid.
While installing my TIP last week I snapped off the nipple that everybody else seems to have a problem with. I shoved the end of the hose Corksport provides onto the open piece and put a clamp on it. I'll upload a picture of what I did in a bit, but I have a problemo. I'm down on power, and I don't think it's a boost leak anywhere else. I double checked all of the couplings around the IC and BPV. I'm getting~11 psi and the occasional spike at 12. I'm just curious about what exactly the nipple I broke off goes to. It's the one that connects directly to the TIP. One person on another forum told me it's a bleed off from the wastegate, and it isn't important. Others have told me it goes into the WG and controls boost. What did I break, and is it most likely what's affecting my boost? I did a datalog, and noticed that the WG is open a lot...like A LOT. Is that normal? With my foot on the floor in 3rd gear at 60mph my boost is at 11.11%, throttle is at 75% and WG is at 73%. Could that tiny hose really be the culprit? I feel like if pedal position is at 99% shouldn't throttle position be the same?
RxHeadkicks is offline   Reply With Quote
 Old 03-19-2013, 12:32 PM   #2
It does sound like your solenoid needs a replacement. What it does is bleed pressure from the line going to the WG. The higher the duty cycle the more it bleeds the lower the pressure at the WG the higher your actual boost.
If you can't find a replacement locally, we have a solution for you that is plug and play and you don't have to worry about breaking it as easily.
http://www.stratifiedauto.com/index....roducts_id=222
bertrand_CX_7 (03-22-2013)
 Old 03-19-2013, 12:42 PM   #3
How difficult is it to tune with the ATR software? I'm still learning the basics of all this.
 Old 03-19-2013, 12:43 PM   #4
The EBCV can be put in 2 port mode and no tuning is needed - it will act like OEM.
 Old 03-19-2013, 12:57 PM   #5
So in 2 port mode I should be hitting my boost targets? If I hadn't broken the stock solenoid the tune I have was set for 17psi.
 Old 03-19-2013, 01:07 PM   #6
Can't speak for your tune but the solenoid will get the job done.
 Old 03-19-2013, 02:05 PM   #7
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Default Re: Stupid broken boost solenoid.
If the end of that hose going into the tip is crushed or blocked in any way, it will prevent the ebcs from actually bleeding pressure away from the wastegate. You will only get spring pressure like you are seeing. I would start with the simplest thing, which is your broken part, since it likely needs replaced anyway.
Edit: did you break the nipple on the tip or the ebcs?
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (03-19-2013)
 Old 03-19-2013, 02:31 PM   #8
Not the tip, I broke the nipple on the ecbs. I wasn't foolish enough to break the one on the tip. I'm uploading a picture of the rig I set up now.
The Following User Says Thank You to RxHeadkicks For This Useful Post:
phate (03-19-2013)
 Old 03-19-2013, 02:59 PM   #9
I broke the outer nipple off. It looked like l_ instead of the two vertical nipples looking like l_l, so I shoved the hose on the end hoping it would work. So the one I broke was bleeding air INTO or FROM the wg?
 Old 03-19-2013, 03:09 PM   #10
Eth Fiend
phate's Avatar
It bleeds pressure from the wastegate diaphragm. You need a new solenoid lol.
-06 MS6
 Old 03-19-2013, 03:23 PM   #11
I figured I might. Ive got around $100 to spend on a new one. I'm NOT buying an OEM because I never want this to happen again, and eventually I'm sure I'll need an aftermarket one. So what are my options? I've seen the grimmspeed one, and the one Lex posted. Anything else worth mentioning? I like the one Lex mentioned because it'e mounted in a more easily accessible spot, and it's a little cheaper. They can both be run in 2 port mode right? And how difficult is it to tune in 3 port mode? Sorry for all the questions, I'm still learning.
 Old 03-19-2013, 03:31 PM   #12
Yes they can all run in 2 and 3 port. The one we sell comes with an elegant thread on plug for the unused port while the GS solenoid and COBB solenoid (they are the same) you will have to install a cap. Also the barb size on those solenoids is a little on the small size for the stock lines.
RxHeadkicks likes this.
RxHeadkicks (03-19-2013)
 Old 03-19-2013, 03:52 PM   #13
I think you just sold me Lex. I'm gonna tell my buddies about ST. I hadn't heard of you guys before today. How about some free express shipping so I can get back out there sooner? heh, heh?
Keep Calm and PSSHHHHHHHH CHOOOOOOO!
 Old 03-19-2013, 04:15 PM   #14
Just ordered the Stratified ECBS! I really hope this solves the problem, will let you guys know when I install it.
Lex (03-19-2013)
 Old 03-22-2013, 10:49 AM   #15
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
It'll do the trick in 2-port mode nicely and give you options for the future.
I busted the FWD nipple off mine and was able to bandaid it back together with JB Weld until my GS arrived. Unfortunately, Lex's option wasn't available when I broke mine, it looks nicer and I like the plastic ports rather than the metal ones on the GS.
BTW...Lex your install diagrams are the best yet!!! Very nice offering.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 03-26-2013, 06:35 AM   #16
Caveman4684's Avatar
Posts: 221   (View Stats)
Caveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the worldCaveman4684 is the leader of the world
Groans: 53
Groaned at 56 Times in 18 Posts
I did the same thing when I removed the stock TIP. I thought I had everything disconnected and ripped the nipple right off the selonoid. Luckily COBB suregline is close to me and I took the wifes car to get there 3 port.
2012 MS3 VR
COBB AP /// Autotech Internals /// CP-E Nano SRI /// CP-E TIP /// JBR Dogbone RMM /// JBR OCC Stage 2 /// RichTune
Caveman4684 is offline   Reply With Quote
 Old 10-14-2018, 04:36 PM   #17
Brendan_klassen's Avatar
Posts: 2   (View Stats)
Brendan_klassen is an unknown quantity at this point
Default Gen2 ms3
I did the same thing just broke it last night and I pushed the line over the same part on the ebcs and I need a new one but will the gen1 work on the gen 2?
Brendan_klassen is offline   Reply With Quote
 Old 10-14-2018, 06:45 PM   #18
MSMS3's Avatar
Posts: 2,830   (View Stats)
Yes. EBCS is the same. Don't waste money on OEM. You will just break another nipple.
You will need to set it up in two port mode if aftermarket. I got the Grimmspeed one. Instructions are very clear. Just leave the old one in place and mount the GS on the front of your battery box. it will come with new vacuum lines and a cap for the unused port.
FWIW, its good you searched first before posting. Kudos.
 Old 10-14-2018, 07:44 PM   #19
Could that be the reason I’m only pushing 9psi? Also my bov doesn’t sound the same used to sound hard
 Old 10-14-2018, 10:25 PM   #20
MSMS3's Avatar
Sound hard???
One thing at a time. Replace the EBCS with one with metal nipples. Then check boost.
Then do a boost leak test.
Boost Solenoid mildsalsa MSP - Turbo Induction 0 05-20-2012 06:52 PM
Where is the Boost solenoid ??? camdensms6 MazdaSpeed 3/6 - Turbo Induction 2 12-13-2009 09:25 AM
Page generated in 0.39088 seconds with 27 queries
