> 2010 MS3 - Turbo Induction
  • 1 Post By g00s3y
  • 1 Post By eliwwjd
 Old 04-11-2018, 07:20 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Switched to Forged bpv v2
Just recently changed to forged bpv v2
and just wanted to know from those who have this valve at this very moment, what has been the perfect spring combination. It only came with blue and red spring but I have 2 shims that I can install to start with.
I read through this thread but still wanted to ask being it an old thread
Forge bpv. Which Spring/shim?
I thought of starting with blue and 2 shims but wanted to see as today what is the consensus. Don't know if these new springs are still underrated. I'm practically fully bolted tuned by freektune on 93 pump gas with a boost of 21 psi at peak. Can look at my signature mods. Thanks for your inputs
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 04-12-2018, 06:15 AM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
blue 2 shims
KiwiFlavor likes this.
KiwiFlavor (04-12-2018)
 Old 04-12-2018, 06:18 AM   #3
eliwwjd's Avatar
blue 2 shims
What mods you have? how much boost you run?
Where you take apart this bpv to switch springs?
dam they seal the thing
 Old 04-12-2018, 07:35 AM   #4
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
blue 2 shims
This.
Running this set up on my car with BNR S3 and 23 psi boost.
One of the ends is a threaded cap. If im not mistaken, it's the end where you connect the TIP hose. That cap is on there good. Trust me you are going to mar and nick your BPV lol. I have to use slip joint pliers every single time lol. I grab it by the hose nipple and just turn the damn thing open.
2012 NASA Spaceship Gray MS3
 Old 04-12-2018, 02:42 PM   #5
eliwwjd's Avatar
This.
Is there a way of unscrewing this cap without scuffing or nicking the valve?is there a possibility of doing it with plastic slip joint pliers?
Second, on what part or side of spring goes the 2 shims? i read on a threat here that wrong chim installment can cause compressor surge
 Old 04-12-2018, 03:16 PM   #6
KiwiFlavor's Avatar
You can. Go to the gym and strengthen those hands. Lol
Yeah probably it will work. Just need something to grab onto it.
I for some reason cannot remember where the shims go. This reminds me to give my bpv a good lubing lol.
 Old 04-12-2018, 03:20 PM   #7
eliwwjd's Avatar
hahahaha! yeah need to go to the gym!
Listen man, lube your bpv asap so you can clarify me where the shims go
 Old 04-12-2018, 03:36 PM   #8
KiwiFlavor's Avatar
Lol! I think the shim goes like this
Valve > Shim > springs
https://youtu.be/IZ0D-Elnyu4
That’s the V1 but the principle stays the same
Last edited by KiwiFlavor; 04-12-2018 at 03:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-13-2018, 05:09 PM   #9
eliwwjd's Avatar
Hey kiwi i remember reading that forged valves were made in billet, is this really true?
 Old 04-14-2018, 07:05 AM   #10
KiwiFlavor's Avatar
TBH, I have no clue..
Switched to Motorcraft XT-M5-QS alien_sporez 2010 MS3 - Engine, Transmission & Driveline 141 01-30-2016 07:56 AM
Can Seats Be Switched? 802_Anthony Mazdaspeed3/6 General Discussion 6 05-22-2014 01:09 PM
Powder forged rods versus drop forged. Lex MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-24-2009 06:27 AM
VW up! could be switched to FWD Haltech Automotive News 0 07-18-2008 11:20 AM
Page generated in 0.31778 seconds with 23 queries
