(Thread Starter) | Not Ranked : 0 score I recently picked up a magnehelic gauge for measuring pressure zones when i start ducting my track miata. Series 2000 | Magnehelic® Differential Pressure Gage | Dwyer Instruments What this basically does is allows you to measure the pressure differential between either two points, or a point and atmosphere. Since i am still a few months away from really getting serious with the miata, i decided to play around with the (gen2) stock TMIC ducting. I know for a long time its been stated that you need a shroud because it helps with cooling, and if you don't have it you will bleed tons of pressure into the engine bay and all that, so i figured why not put that theory to the test. I will admit that my results are not as strictly scientific as possible, but i feel they are close enough to not matter. Basically i got a Gen2 with the stock TMIC and shroud and rigged up the gauge a few inches inside the hood scoop to get a pressure reading on top of the core. Units of measure are Inches of water: Definition: https://en.wikipedia.org/wiki/Inch_of_water roughly 27.5" of water = 1 psi. Thanks @Tomas; for setting me straight on the units there. Part 1: TMIC testing with shroud, measured on top of core in the scoop. 40 mph - .5" of water 50 mph - .75" of water 70 mph - 1.25" of water 80 mph - 1.5" of water There were slight swells as the driver accelerated, but i was trying to just measure steady state since i felt that was a more controlled environment, i'll try seeing if we actually get some "ram air pressure" when WOT at a later time. The next step was taking my ETS equipped car with no shroud (like i said, not apples to apples) and doing the same test on the same stretch of road. Part 2: TMIC testing without shroud, measured on top of core in the scoop 50 mph - .5" of water 60 mph - .75" of water 80 mph - 1.5" again It would appear that the shroud does provide some purpose at lower speeds, but at higher speeds the affect seems to become less apparent. This leads me to believe one of two things is happening: Either the pressure does a shockingly good job of staying on the core, or the engine bay itself is becoming pressurized, which i somewhat doubt. The next step in this test will be measuring engine bay pressures on either side of the radiator with FMIC and TMIC cars. A radiator wants the highest pressure in front of, and lowest pressure behind of, it as possible. With a FMIC you're basically lowering the pressure in front, and since the TMIC ducting is open to the engine bay, raising the pressure behind the radiator. I'd like to see what that data says. Part 2: TMIC car / under tray installed / weather stripping in the cowl installed Pre radiator: 55 mph - .35" of water 60 mph - 1.15" of water 70+ mph ~1.5" of water Post radiator: 50 mph - .1" of water 55 mph - .2" of water 60 mph - .3" of water 80 mph - ~.5" of water Cowl with weather stripping installed: 40 mph - .5" of water 50 mph - .7" of water 60 mph - 1.2" of water 80 mph - 1.6" of water Part 3: TMIC car / Under tray removed / Weather stripping on cowl installed 30 mph - .1" of water 40 mph - .2" of water 50 mph - .3" of water 60 mph - .4" of water 60 mph was as fast as i was able to get, but clearly the under tray serves an important purpose. If anyone can think of ways to make these tests more accurate, or tests they would like done as well, please let me know. I figured there may be a better way to go about this, which is why i went ahead and created the thread before i had all my data.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. Last edited by Voltwings; 07-03-2015 at 07:06 PM. |
| The Following 10 Users Say Thank You to Voltwings For This Useful Post: | Code Monkey (06-23-2015), Easter Bunny (06-23-2015), FistPump20fo7 (06-23-2015), Gr8Speed (06-30-2015), JgamB (06-30-2015), JSmith (11-21-2016), phate (07-03-2015), torquemaniac (06-23-2015), Yanahdi (07-04-2015), zenit (09-02-2015) |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Test with and without the under trey on the same car when you do the radiator test.
__________________ |
| The Following 5 Users Say Thank You to Spec For This Useful Post: | Code Monkey (06-23-2015), Easter Bunny (06-23-2015), torquemaniac (06-23-2015), Voltwings (06-23-2015), WetzMS3 (06-23-2015) |
(Thread Starter) | Not Ranked : 0 score Yes, that would be a really good one, thanks Ray.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| Not Ranked : 0 score You can also test with and without the rubber gasket along the rear of the hood.
| The Following 2 Users Say Thank You to Easter Bunny For This Useful Post: | torquemaniac (06-23-2015), WetzMS3 (06-23-2015) |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| I'd be very curious to see what the results were with a hood-scoop extension like Corksport's too.
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | Easter Bunny (06-23-2015), speedfreak44 (06-23-2015) |
Basically if i measure say .5" in the engine bay and .6" in the cowl, i can assume the cowl will be putting air into the engine bay instead of removing it, correct? Whereas if i measure .5" in the engine bay, and ... really anything less than that, especially negative pressure, we can assume it will pull pressure from the engine bay?
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
__________________ I hugged rfinkle2 | |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Voltwings (06-23-2015) |
| The Following User Says Thank You to Spec For This Useful Post: | Voltwings (06-23-2015) |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Testing the pressure over a gen1 TMIC could be nice also...front of the car usualy has higher pressure reading, so the gen1 could see more pressure over the TMIC since its feed from the front of the car (upper grill area)
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| The Following User Says Thank You to torquemaniac For This Useful Post: | Voltwings (06-23-2015) |
(Thread Starter) | Not Ranked : 0 score I now realize this is going to be a very large amount of data, so I cleaned up the OP to hopefully make it easier to read, and added the following data from tonight: Part 2: TMIC car / under tray installed / weather stripping in the cowl installed Pre radiator: 55 mph - .35" of water 60 mph - 1.15" of water 70+ mph ~1.5" of water Post radiator: 50 mph - .1" of water 55 mph - .2" of water 60 mph - .3" of water 80 mph - ~.5" of water Cowl with weather stripping installed: 40 mph - .5" of water 50 mph - .7" of water 60 mph - 1.2" of water 80 mph - 1.6" of water
| The Following 3 Users Say Thank You to Voltwings For This Useful Post: |
| Not Ranked : 0 score Did you mean ''cowl with weather stripping unistalled''?
(Thread Starter) | Not Ranked : 0 score Nope, installed, as it comes from the factory. So if im looking at this right, the cowl at the base of the windshield is basically a high pressure zone, and compared to the post-radiator readings, removing that weather stripping would be pumping air into the engine bay.
| The Following 4 Users Say Thank You to Voltwings For This Useful Post: | Easter Bunny (06-30-2015), JgamB (06-30-2015), SuckSqueezBangBlow (06-30-2015), torquemaniac (06-30-2015) |
![]() Join Date: Nov 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I have taken that weather striping on and off so many times, I wonder if I should take it off again.... I am having a hard time interpreting the date (and nice job on the testing!) I guess I will wait and see if it is beneficial or not.
__________________ 2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan |
(Thread Starter) | Not Ranked : 0 score In my mind, the number on the cowl is higher than the number in the engine bay. Pressure moves from high to low, which leads me to believe it would flow into the engine bay.
![]() Join Date: Oct 2013 Location: BFE, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 455
| Not Ranked : 0 score I'd really like to see some results with the under tray removed as well. I noticed my BAT's really dropped after I removed mine. However, I removed my EGR and TB coolant lines at the same time. I'm sure that was the main reason they dropped, but would like to know if there is any benefit to not having an under tray.
__________________ 2013 VRM with Cobb AP V3/ CS SRI/TIP/SS/TP/ CP-E RMM CP-E TMIC Autotechs JBR TIG/IMG/EGR delete Stratified OTS tune |
the positive effect may be minimal (i.e. unmeasurable) lol
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
1. We're swapping water cooling effectiveness for air cooling effectiveness in that case. 2. We're assuming its already at a point where the stock radiator cant keep up and we will see a negative impact in cooling by raising the pressure on the backside of the radiator. 3. while there is a rather large amount of pressure on the base of the windshield, i suppose without more testing its hard to quantify how much actually makes its way into the engine bay. Im just trying to collect the data, someone smarter than me can decide what to do with it
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | Easter Bunny (07-01-2015), torquemaniac (12-13-2016) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Yes, too many variables and you'd need to define what your goal is. 1) reducing engine bay temps 2) reducing ECT the two may be necessarily mutually exclusive in some scenarios like the strip removal. I think something like the scoop deletes the scoobie guys install is great for letting heat out AND should (just a guess) decrease the pressure in the engine bay so also would aid in lowering ECT. Who's up for cutting a giant hole in the back of their hood?
| The Following 2 Users Say Thank You to Dano For This Useful Post: | torquemaniac (12-13-2016), Voltwings (06-30-2015) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score @Code Monkey; Dont talk about it, be about it.
![]() | | #21 | ![]() |
| Not Ranked : 0 score A giant hole? My peen would get all banged up against the walls.
![]() | | #22 | ![]() |
![]() Join Date: Sep 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
| Not Ranked : 0 score You want the vents to be in LOW pressure zones, not high pressure zones. Ramming air (even if it's ambient temp) into the back of your engine bay is a bad thing. Reduces the air moving through the radiator by increasing the pressure behind the radiator. A vent on the low pressure portion of the hood will reduce underhood pressure, allowing hot air to be pulled out, and allowing more air to pass through the radiator. Example: http://i.ytimg.com/vi/wjjOgX_C5g0/maxresdefault.jpg The air should be flowing out of the vents (as seen), not into them
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD |
| The Following 6 Users Say Thank You to Tyhackman15 For This Useful Post: | Code Monkey (06-30-2015), Dano (06-30-2015), Easter Bunny (07-01-2015), phate (06-30-2015), torquemaniac (07-01-2015), WetzMS3 (07-02-2015) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score I took the cowling (the plastic that has the windshield wiper squirters in it) out of my car and when I sit in traffic I can see the heat waves coming out in front of my windshield. Doesn't seem to hurt the normal operation of my IAT or BATs |
![]() | | #24 | ![]() |
Of course all this is application specific talk.
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD | |
| The Following User Says Thank You to Tyhackman15 For This Useful Post: | torquemaniac (07-01-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score I think that removing the weatherstripping on the back of the hood would only be beneficial for drag racing
| The Following 2 Users Say Thank You to Easter Bunny For This Useful Post: | Code Monkey (07-01-2015), JgamB (07-01-2015) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score That is all I needed to hear. I knew I clicked the "subscribe to thread" for a reason.
![]() | | #27 | ![]() |
| Not Ranked : 0 score IMO, removing the weather strip will only improve heat removal when sitting in traffic Im 100% with @Tyhackman15;
| The Following 2 Users Say Thank You to torquemaniac For This Useful Post: | Easter Bunny (07-02-2015), Voltwings (07-02-2015) |
![]() | | #28 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score hmm well it looks like ducting in the rad on the sides and on top is the way to go... then duct ur intercooler in.
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #29 | ![]() |
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score I'm going to try and experiment with a duct between my fmic and the radiator as that should be fairly simple to mock up and fit with the bumper off. I haven't yet decided whether I should just duct the top and sides and allow some air to go under the IC, or go all the way around. After that would be figuring out ductwork from the bumper cover to direct more air into the core and subsequently through to the rad. In these temps (80s/90s) unless I'm just cruising my ECT is living between 205 and 214 constantly |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Mazdaspeed6 for road racing this thread on the last couple pages have great info on ducting even tho its a ms6
![]() | | #31 | ![]() |
| Not Ranked : 0 score You need fan controller mod. I only ever see 195 From pablos group. Sp36 whatever. Tappin
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (07-02-2015), MSP611 (07-02-2015) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I need to get one of those when I order my block... another thing to add to the list.
![]() | | #33 | ![]() |
| Not Ranked : 0 score my post was in response to @kidlifecrisis; but yeah that is a must have mod once you up the HP to say beyond 350-400WHP IMO. edit: but generally a good mod at any HP level. cooler is always better if you aren't concerned with emissions.
![]() | | #34 | ![]() |
| Not Ranked : 0 score True, but with that kit my fan would basically just be on 100% of the time. Step 1 is to try and redirect the air that's currently going around everything, then depending on my results I can make the call on the fan controller |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Updated OP with the following information after removing the under tray 30 mph - .1" of water 40 mph - .2" of water 50 mph - .3" of water 60 mph - .4" of water 60 mph was as fast as i was able to get, but clearly the under tray serves an important purpose.
| The Following 7 Users Say Thank You to Voltwings For This Useful Post: | Code Monkey (07-04-2015), Dano (07-04-2015), DaUberSchwebel (07-04-2015), Easter Bunny (07-06-2015), JgamB (07-03-2015), phate (07-03-2015), torquemaniac (12-13-2016) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Thanks for the results. My under tray is going back on today.
![]() | | #37 | ![]() |
![]() Join Date: Nov 2010 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 167
| Not Ranked : 0 score As far as air flow one way I've seen people test it is to just tape a bunch of paper strips at multiple points on the car. PITA and looks goofy as shit but it does work. Obviously no quantifiable data but it can serve as a way to confirm data from pressure testing. Best results would need another car with a camera man to drive alongside. Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to Yanahdi For This Useful Post: | Easter Bunny (07-06-2015), Voltwings (07-05-2015) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score where was this measurement taken?
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score about 1/2" behind one of the little flappers on the passenger side to allow it a chance to open. I didnt want to put it behind the fan because i wasnt sure if that would skew the readings.
| The Following User Says Thank You to Voltwings For This Useful Post: | Easter Bunny (07-06-2015) |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok, so I got a FMIC from a local that I installed today and will be doing more testing. I'll try to lay this out as orderly as I can, but I think what all I am going to test is: 1. Under tray attached. All cowl ducting in place. All stock TMIC ducting in place. FMIC installed. - Pressure in front of the FMIC core. - Pressure behind FMIC core (in front of condenser) - Pressure behind radiator (in engine bay) 2. Under tray removed. All cowl ducting in place. All stock TMIC ducting in place. FMIC installed. - same tests as part 1. 3. Under tray attached. Cowl weather stripping removed. All stock TMIC ducting in place. FMIC installed. -pressure behind radiator (in engine bay) -Pressure in cowl area (at base of windshield) 4. Install @JSmith;s hood scoop ducting. Cowl weather stripping attached, under tray attached, FMIC installed. - Same tests as part 1. 5. Install Jsmiths hood scoop ducting, remove cowl weather stripping, under tray attached, FMIC installed. -pressure in cowl area (base of windshield).
| TMIC Sprayer/Improved Ducting | Gr8Speed | MazdaSpeed 3/6 - Turbo Induction | 36 | 08-20-2014 12:31 PM |
