> 2010 MS3 - Turbo Induction
  • 1 Post By MSMS3
 Old 09-02-2018, 10:38 AM   #1
Tru3's Avatar
Posts: 46   (View Stats)
Tru3 is on a distinguished road
Default TMIC Question
All my mods are listed below in sig, will it benefit me to get an aftermarket TMIC now or should I first remove a cat, I plan to get a race pipe, not a down pipe any time soon.
Are aftermarket TMICs good power mods? Thanks!
2010 MS3 // CS TIP - CS SRI - CS BOOST TUBES - CS MZR BPV - CS HPFP - COBB AP
Tru3 is offline   Reply With Quote
The Following User Says NO Thank You to Tru3 For This Un-useful Post:
g00s3y (09-04-2018)
 Old 09-02-2018, 10:55 AM   #2
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
The TMIC would be more beneficial to answer your question. Then get a protune. You can get good gains with upgraded TMIC thru the hood scoop. The downpipe would help a lot tho.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 09-02-2018, 11:44 AM   #3
MSMS3's Avatar
Posts: 2,830   (View Stats)
I never upgraded my TMIC or went FMIC. See mods below in sig. You can max out the stock turbo with intake, tune and just a racepipe. If you are road course racing or doing a lot of long sustained running at WOT you can heat soak and benefit from an intercooler upgrade. But, for most general spirited driving the stock TMIC does surprisingly well.
FWIW I am at 300-310 whp, 0-100 mph in the 10.5 second range, quarter mile is 13.2 at 107, and I live in the hot Mississippi Gulf Coast climate. I've owned this car since I drove it off the showroom floor new in the Spring of '08, most mods including catless 3" dp/rp, CAI and tune were added in the first year.
I think intake, tune and exhaust mods, including upgraded high pressure fuel pump internals can come first and certainly did for me. If I was going big turbo, like BNR Stage 3 or 4, or running exotic fuel blends, then yes, I'd upgrade the intercooler.
 Old 09-02-2018, 11:47 AM   #4
Tru3's Avatar
I never upgraded my TMIC or went FMIC. See mods. elow. You can max out the stock turbo with intake, tune and just a racepipe. If you are road course racing or doing a lot of long sustained running at WOT you can heat soak and benefit from an intercooler upgrade. But, for most general spirited driving the stock TMIC does surprisingly well.
FWIW I am at 300-310 whp, 0-100 mph in the 10.5 second range, quarter mile is 13.2 at 107 and I live in the hot Mississippi Gulf Coast climate. I've owned this car since I drove it off the showroom floor new in the Spring of '08, most mods including catless 3" dp/rp, CAI and tune were added in the first year.
I think intake, tune and exhaust mods, including upgraded high pressure fuel pump internals can come first and certainly did for me. If I was going big turbo,like BNR Stage 3 or 4, or running exotic fuel blends, then yes, I'd upgrade the intercooler.
Thanks for the detailed response! So maybe I should look into a race pipe first? Cheaper to...
 Old 09-02-2018, 02:31 PM   #5
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Go VIP and buy mine. I'm not biased.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 09-02-2018, 04:15 PM   #6
MSMS3's Avatar
1. HPFP upgrade. Especially if Gen 2. OEM is marginal to begin with.
2. Intake, SRI or CAI.
3. Tune (need this or some type of monitoring and logging capability, especially for rail pressure, boost, afr, fuel trims.
You already have 1-3, but do you know how to log, and do you have a tune installed?
4. Then racepipe, if your logs are looking good, then tune for the rp's increase in flow.
 Old 09-02-2018, 04:36 PM   #7
Tru3's Avatar
How much?
Yeah I know how to log and I have a Freektune OTS plus map,
The Following User Says Thank You to Tru3 For This Useful Post:
MSMS3 (09-02-2018)
 Old 09-02-2018, 06:56 PM   #8
Bingo's Avatar
How much?
It's a 3 inch UR test pipe I'll take $90 for. But again, if bought through MSF you need to be VIP.
 Old 09-02-2018, 07:03 PM   #9
Tru3's Avatar
$90 shipped? How much do you have to donate to become VIP?
 Old 09-02-2018, 10:31 PM   #10
Bingo's Avatar
$25. You can read about what all it includes in your welcome PM.
TMIC question mazdaspeed333 Gen2 MS3 General Discussion 23 08-20-2014 12:28 PM
CPE TMIC Question Gen 1 vs Gen 2 Pololo_MS3 MazdaSpeed 3/6 - Turbo Induction 3 01-20-2014 02:01 AM
TMIC the BIG Question (Where, How, Why) ganque MazdaSpeed 3/6 - Turbo Induction 11 11-15-2010 03:19 PM
Question about ETS TMIC SLOMS3 MazdaSpeed 3/6 - Turbo Induction 16 11-13-2009 08:42 AM
Page generated in 0.30669 seconds with 23 queries
