> 2010 MS3 - Turbo Induction
  • 1 Post By Code Monkey
  • 1 Post By sheston
 Old 09-03-2016, 12:31 PM   #1
iwabo's Avatar
Posts: 51   (View Stats)
iwabo will become famous soon enoughiwabo will become famous soon enough
Groaned at 9 Times in 4 Posts
Default At what point do i build motor?
I plan on going big turbo either GT3076R or GT2871R, would this require the engine to be built? At what horse power is that necessary? Also which of these 2 turbo's would yall recommend for a daily driver?
iwabo is offline   Reply With Quote
The Following User Says NO Thank You to iwabo For This Un-useful Post:
ms6mil (09-03-2016)
 Old 09-03-2016, 01:14 PM   #2
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
No need to double post the same crap.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 09-03-2016, 01:29 PM   #3
iwabo's Avatar
sorry i wasn't sure which thread it would be more appropriate in.
 Old 12-20-2016, 04:18 PM   #4
Janks's Avatar
Posts: 12   (View Stats)
Janks has a spectacular aura aboutJanks has a spectacular aura aboutJanks has a spectacular aura about
It sounds like 2871, but what are the power goals ultimately? I'm looking at a 3076 setup because I want room to grow and I'm okay with a bit of lag. A read through the BT build section helped me big time. Theres a stock block thread too. What fuel you have access to plays a role too
Signed, That guy who mistaken bought a GT3582
Don't be upset with the result you didn't get with the work you didn't do
'11 Speed 3
Built motor (Manley h beams mahle pistons no headwork) Gt3582r Stock intake/exhaustTr8 Cs bpv Aem meth (1000cc)
Neo coils Jbr 3.5 intake Jbr trans mount cpe rmm corksport pmm Ss lines Hp+ pads Bm spec aero tuned by Nishan
Let's see what it'll do build
'85 Rx7 Gs
Gsl rear end full exhaust, rb header vibrant reso/ muffler, fc front subframe swap in the near future, keep it classic cruiser
Janks is offline   Reply With Quote
The Following User Says Thank You to Janks For This Useful Post:
sheston (12-20-2016)
 Old 12-20-2016, 04:26 PM   #5
Janks likes this.
g00s3y (12-20-2016), KiwiFlavor (12-21-2016), MS3Shadow (12-20-2016)
 Old 12-20-2016, 05:20 PM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Everything you asked can easily be found out if you know how to read.
If you drive around town more, the 28 series is a better choice. If you take long drives and are on the highway more often, the 30 series is probably a better choice.
If you wanted something in between those two, you should look into the BNR S4.
Finchee (12-21-2016), sheston (12-20-2016)
 Old 12-20-2016, 06:14 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
Any one person can't answer this question for someone else. I have a stock K04, but probably make more power than a lot of BT guys. I really love the low end torque and don't think I would do anything different. If this one blows sometime, I'll probably upgrade to the GTX28R.
One of the good questions that was asked was what fuel do you have handy. That plays a big role as well.
Mostly you should do as @Janks; said and read a bunch. You will read a lot that sounds like people are saying the opposite, but they are probably both right. The important part is to be able to tell why
Janks likes this.
Wholegrain (12-20-2016)
 Old 12-20-2016, 07:42 PM   #8
shaneski's Avatar
Posts: 506   (View Stats)
Also depends on the condition of the current engine and how it's been treated, if it's had a hard life chances are high it will break something with more power pushed through an aged engine.
 Old 12-20-2016, 08:06 PM   #9
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
yes
 Old 12-20-2016, 09:02 PM   #10
pharaoh313's Avatar
Posts: 120   (View Stats)
pharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the worldpharaoh313 is the leader of the world
Just build it now, before you blow it up.
2013 Mazdaspeed 3 W/Tech
1st trip 2 the 1/4m: 1.89 60ft 12.87@109.62 VD* 289hp- HpFp - Trilogy 70D -E85(Freek)Tune - QTPs
2nd time 1/4m: 1.91 60ft 12.49@113.59 Dynojet 335.48hp- HpFp - Trilogy 70D - E85+M(Sn@il)Tune - QTPs - 3 port - SE/TBE - TMIC - 3.5Intake
Audio: 2 x Kicker Cvr 12s, Hif 1500D, Hif 800.4, Bx-15, 4x Infinity Kappa 60.11cs rewired w/12G
@FB Allan Langston
~4 Bangin Ain't EZ~
pharaoh313 is offline   Reply With Quote
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
At what point do i build motor? iwabo 2010 MS3 - Engine, Transmission & Driveline 3 09-03-2016 07:26 PM
Motor Build Karleurope MazdaSpeed 3/6 - Build Diaries 9 10-23-2015 12:16 PM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
Page generated in 0.31740 seconds with 28 queries
