> 2010 MS3 - Turbo Induction
 Old 10-13-2018, 08:03 PM   #1
Tr33x0rs's Avatar
Posts: 6   (View Stats)
Tr33x0rs is an unknown quantity at this point
Default Whining noise in boost after reinstalling SSQV
I recently bought a purple fin for my HKS SSQV not knowing that I can't insert a fin while it's recirculating. I took the SSQV off, noticed I can't install the fin and I reinstalled it. Ever since then I have noticed a whining when I'm in boost. It never did it before which leads me to believe it's something not reinstalled correctly or it was a massive coincidence.
I checked that the gasket is still in good shape, all my bolts are tight, and my recirculating hose clamp is tight. I also made sure that the recirculating "cap" or whatever it's called is tightened well with the 4 hex bolts. I have a video if anyone can give me some ideas of things to check. I am tuned for 20lbs of boost, and am still reaching that for the most part, so I'm not sure if I have a boost leak or where to go from here. Thank you in advance for the help.
https://www.youtube.com/watch?v=yzRlB1f1dr4
Tr33x0rs is offline   Reply With Quote
Front end whining noise rocarr2 Mazdaspeed3/6 General Discussion 5 04-22-2015 07:03 AM
Whining noise when turning Castillo817 Gen2 MS3 General Discussion 25 01-27-2015 08:03 PM
Whining Noise Front End - Help?!!! jfkireland MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-24-2013 01:23 PM
Whining noise in reverse? shadowms3 Gen2 MS3 General Discussion 13 05-23-2011 08:15 PM
whining noise when cluch is out? 02stang951 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 04-01-2010 01:46 PM
Page generated in 0.23019 seconds with 20 queries
