> 2010 MS3 - Suspension & Brakes
 Old 02-04-2020, 06:03 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Default Brake help needed!
i recently installed Ferodo DS2500 front pads on my car and resurfaced rotors. Also re-lubed all moving parts but still getting annoying squeaking noise. The car stops awesome, this pad has great bite and very firm strong pedal feel but squeals like a mother*****!
I'm thinking on ebc yellows or stoptech pads but wanted to know from any of you how has been your experience with these 2 pads.
I've read through past posts but couldn't find a comparison between these 2. I don't track my car. I mainly do aggressive street driving and spirited driving. I'm wondering if i can find a pad that has good initial cold bite and that won't fade and obviously no squeaking noise.
Please need help because these pads are driving me crazy with this squealing. Thanks in advance for your help
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 02-04-2020, 08:26 PM   #2
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
You said you lubed all moving parts, did you apply any "anti-squeal" (or whatever it is called) grease to the back of the pad? I have yellows with the corksport calipers on TS2 rotors and will probably never change them.............but I hate having to clean my wheels every 2 days and man this setup EATs rotors.... Hey we can't have it all LOL
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following User Says Thank You to Novej For This Useful Post:
MSMS3 (02-05-2020)
 Old 02-05-2020, 03:37 AM   #3
eliwwjd's Avatar
How is the squealing and noise on these ebc yelloys?
 Old 02-05-2020, 06:44 AM   #4
MSMS3's Avatar
Posts: 2,826   (View Stats)
Came here to say the same thing. That thick, dark grease should cover the entire back side of each pad. Do that if it wasn’t done.
If you want a different pad, I had really good results with Hawk HPS pads. Properly installed, they were super quiet.
 Old 02-05-2020, 07:43 AM   #5
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
Some agressive pads make noise and there is nothing to do. You can try the kind of stuff mentioned, it dry a bit like silicone and prevent the vibration of the pad when louse but if the noise is coming from the pad surface and sound like a bus or a 10/12 wheels truck, there isn't much you can do with them...
It is like tires, you cannot get a very soft compound that would last long so you cannot get dust free and quiet pads that will brake hard....
I did try hawks HPS on my speed3 and i agree about quiet, heat resistant and dust free but after 500km i removed them because for my use, the initial bite was terrible on cold weather/rain.
I replaced them with hawks HP+ and it was the complete opposite, agressive bite with minimal pressure, was almost dangerous to brake too fast and being hit in the back by the car behind... but that buss noise even after trying everything and so much metal dust that it would hurt the wheel paint...
I would also look to find something in between for my heavy 6 now. not willing to accept again that track racing noise but would like something that could handle a bit better spirited driving than the cheap one i run now...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-05-2020, 07:17 PM   #6
eliwwjd's Avatar
I have 2 options to attack my problem
1st-Swap back oem rotors to see if its a compatibility problem between my stoptech slotted rotors and ferodo pads or
2nd-Go with stoptech street pads with my stoptech rotors
If i go 2nd option, I think I'll be going with stop tech street part number 308.09152. I heard really good things about this pad, good initial bite, less fading than oem, least dust.
If anybody has had experience with this pad on this car?
Front brake spring clip needed? mattwood1221 MazdaSpeed 3/6 - Suspension & Brakes 2 06-17-2015 03:46 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
Page generated in 0.26879 seconds with 23 queries
