![]() Join Date: Jan 2019
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score Can you guys point me in the right direction. I need to replace the rear coil spring in my 2010 Speed3. I am going to switch out the rear with stock springs but wanted to make sure I get the right set. I plan to replace both the left and right rear. I also will replace the spring seat too. The reason I am not doing a performance spring set is this is my first time working on my car and I don't want to fuss with lowering springs...which may lead to swapping suspension in the long run...and more cost at the moment. The spring I think I need is part: Moog 81693. I have tow links below and they are $30 difference and I don't know why when they are the same item. https://www.moog-suspension-parts.com/moog-81693 $81 https://www.rockauto.com/en/cart/ $50 The spring seat is part: BP4K28012A http://www.mazda-parts.com/2010-mazd...4K28012A-item/ Are the above links/items the rear coil spring for the Speed3? Thanks for any advice and help. |
| Display Modes | |
| How To: Ignition coil spring stretch mod | cld12pk2go | MazdaSpeed 3 - How-To's | 56 | 03-21-2016 02:58 AM |
| Question about different coil spring designs... | iammike | 2010 MS3 - Suspension & Brakes | 8 | 07-10-2014 11:12 AM |
| Rear coil spring spacers | JgamB | 2010 MS3 - Suspension & Brakes | 2 | 11-14-2013 11:45 AM |
| Coil Spring Spacers | dukebrown | MazdaSpeed 3/6 - Suspension & Brakes | 12 | 04-09-2011 11:05 PM |
| Donut Style Coil Spring Spacer | booya620 | Drag Racing | 2 | 02-07-2011 08:00 PM |
