  • 1 Post By wolly6973
 Old 11-08-2011, 09:07 PM   #1
2011_bluespeed3's Avatar
Posts: 24   (View Stats)
2011_bluespeed3 has a spectacular aura about2011_bluespeed3 has a spectacular aura about2011_bluespeed3 has a spectacular aura about
Default 4 days of tuning
Okay well i have been tuning for the past few days because out of curiosity i always wondered how could a stock tuned ms3 with same mods vs (me) stage 1 AP OTS map with same mods lose time and time again. I thought it might be driver mod lol but, maybe a little.
We both are running CS Intake/ CS TIP/ 2nd cat delete/ 3" exhaust from down pipe back.
2011 ms3(me) and 2012 ms3(friend)
Only thing different was i have AP and he didnt. Soon there entails my quest for mo POWAA and learning how to tune this fun little car on the weekends.
First couple of logs just lil changes.
2011_bluespeed3 is offline   Reply With Quote
 Old 11-08-2011, 09:19 PM   #2
Started to move more things around Fueling tables, WGDCS, Load Cal , AFR, everything following Alibors guide and help from jason from this forums. These are the next logs trying to smooth out the graph some and actually tune to hit my boost targets.
 Old 11-08-2011, 09:26 PM   #3
Final logs with actually almost hitting my boost targets and trying to smooth graph out best i could. I believe these are where im going to leave it not much kr really to worry about and no maxed out wgdcs like the ots maps like to run high. The only thing i dont know much about is how to tune timing to improve power. So thats the last thing on my agenda.
I was trying to target about 16.5 PSI tapering down to 16.0 bye redline. I have above mods listed and trying to keep stock fuel pump in check. 11.8 AFR pretty solid. I am always looking to improve as I am addicted to tuning now and well continue to do so crosses fingers with things improving so far. Please let me know where do go from here thanks.
 Old 11-08-2011, 09:38 PM   #4
Mac21's Avatar
Posts: 128   (View Stats)
Mac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond reputeMac21 has a reputation beyond repute
Forgot the donate mod... Get that done and you'll see the whiz kids start coming in here. That is when the learning really starts.
Cobb AP on a stage 2+ tune, Cobb SF SRI, Cobb TIP, CNT racing DP, KMD internals, KW V2 coilovers, JBR SSP, JBR shifter bushings, JBR chrome-moly RMM, JBR heavy shift knob, JBR PMM, Exonic in-dash TV, PowerBass 10", SoundStream Picasso 550w amp 18x8.5 +38 Work Emotions on order.
Hold on a second, I just gotta check my "fuck you" map.
Mac21 is offline   Reply With Quote
The Following User Says NO Thank You to Mac21 For This Un-useful Post:
CCC (11-09-2011)
 Old 11-09-2011, 06:05 AM   #5
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Why not up the boost to 18 psi? That is plenty safe and you have tons of wgdc left to play with. Should net you some decent gains as well.
The Following User Says Thank You to wolly6973 For This Useful Post:
rfinkle2 (11-09-2011)
 Old 11-09-2011, 10:44 AM   #6
sheldonross's Avatar
Posts: 189   (View Stats)
sheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the worldsheldonross is the leader of the world
Groans: 131
Groaned at 30 Times in 9 Posts
I think because he doesn't have an upgraded CDFP.
JBR SSP - JBR RMM - AP Stage 1 91 OTS
sheldonross is offline   Reply With Quote
 Old 11-09-2011, 10:47 AM   #7
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
He can keep upping boost until he starts to see fuel pressure drop. I believe GenPu's have been able to hit 18PSI or so on the stock pump like I did on my GenJuan.
Tapadatass
rfinkle2 (11-09-2011), wolly6973 (11-09-2011)
 Old 11-09-2011, 02:18 PM   #8
harryclay's Avatar
Posts: 685   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
I was running 18psi on my stock pump but it was only for a few months. It kept up pretty good, just depends on how shitty his pump is
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Michelin Pilot Super Sports 235/40/18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline   Reply With Quote
The Following 2 Users Say Thank You to harryclay For This Useful Post:
 Old 11-09-2011, 03:47 PM   #9
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Looking good so far bro...keep up the good work and turn up that boost.
 Old 11-09-2011, 06:18 PM   #10
Wow thanks guys for the all the replys, I really love how this community helps out it fellows in training. I guess ill shoot for 17 psi now to redline and see what i come up with on that. If its still okay ill do 18 max because i cant get internals till december. Btw, did 2 more logs today just to keep checking.
Well this friday i guess i going to be doing some more fun in ATR its really addicting. I will keep you guys posted on new results just to see how much this stock HPFP will hold btw i have only 4400 miles on my car and im driving it like i stole this bad boy.
I used to be a car mechanic for 6 years before this and i loved my 98 LS1 camaro built from block up sold it to go college and now i have my first turbo car so im very conservative as not to blow up my Daily Driver. I will make the 17 psi prolly the weekend tune ^^ for saturday nights. If anyone lives in katy,tx or houston area and want to meet up we are rolling about 4 mazdaspeed 3s deep so more the merrier. Thanks all (slap)---> time to get to work.
 Old 11-10-2011, 07:53 AM   #11
wolly6973's Avatar
Groans: 386
A good way to show your thanks for the support is to donate to help keep our community running.
The Following 4 Users Say Thank You to wolly6973 For This Useful Post:
dastpe (11-20-2011), rghispanic88 (11-10-2011), RichieRichness (11-10-2011), Teethkikr (11-16-2011)
 Old 11-10-2011, 08:32 AM   #12
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
looking good. the power gains are never enough. youll always want more
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 11-10-2011, 08:34 AM   #13
Groans: 35
If you want your turbo to last taper the boost down to 16.5 by 6500 rpm. Otherwise the little k04 will be out of it's efficiency range.
 Old 11-10-2011, 08:45 AM   #14
silvapain's Avatar
Groans: 136
Originally Posted by RichieRichness View Post
If you want to be a pussy taper the boost down to 16.5 by 6500 rpm. Otherwise the little k04 will be out of it's efficiency range.
Fixed
Run it to 21 PSI I say.
Tapadatass
wolly6973 (11-10-2011)
 Old 11-10-2011, 05:38 PM   #15
More logs with 17 psi targeted with taper to 16.50 to 6500. Pretty good imo fuel pump still hanging in there.
2 3rd gear logs and 1 4th gear pull its so hard to find a open road to 4th gear runs.
 Old 11-16-2011, 11:24 AM   #16
Groans: 35
Start bumping your timing up 1* at a time and lean out your AFRs
 Old 11-16-2011, 12:16 PM   #17
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
If you want your k04 to live, leave your boost at 17psi. Start bumping timing one degree at a time until you see consistant kr at the same load/rpm, and then back it down 1~2 degrees...
The Following User Says Thank You to SSinstaller For This Useful Post:
wolly6973 (11-16-2011)
 Old 11-17-2011, 11:32 AM   #18
Okay going to try tackling timing next and look for a good guide on where to tune timing. I'm not sure where to start in rpm band maybe 3000? On up or I should probably do every 500 rpm incriments first? Going to search these forums to find a guide thanks again for the great info.
 Old 11-17-2011, 12:21 PM   #19
justinspeed3's Avatar
Posts: 161   (View Stats)
justinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the world
My fuel pump is garbage im running 16 psi and when I was doing my 3rd gear logs it was barley hanging on.
justinspeed3 is offline   Reply With Quote
 Old 11-17-2011, 12:49 PM   #20
Groans: 60
3k is a good place to start, just make sure your only adjusting the open loop areas.
Look at the graph as your making adjustments, it'll be easier to judge the relationship to the adjacent cells..
Timing transitions from cell to cell should be smooth, with an increase to redline, you don't want the timing jumping around as you transition between load points/rpm..
If you don't have an EGT to monitor temps in normal driving don't touch the closed loop timing...
This is my OL no KR timing table, the reason for the dip in the last row is the table peaks at 2.0 load.. I routinely see >3.0 load in colder temps, so I have to drop the timing sharply to compensate.
Your's will NOT look the same, my motor is far different than your's...do not try to copy this table...
 Old 11-20-2011, 08:00 AM   #21
Groans: 35
damn... you smoothed out your timing table like crazy.
 Old 11-20-2011, 08:26 AM   #22
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Yeah I want to get mine that smooth
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 177 12-03-2011 12:53 PM
My last 2 days FightaX Street Racing Stories ( Bench Racing ) 14 09-28-2011 09:30 AM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning Cobb Tuning 1 08-31-2011 07:43 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Page generated in 0.42207 seconds with 31 queries
