 Old 03-18-2012, 09:32 PM   #1
speed d3mon's Avatar
Posts: 302   (View Stats)
speed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the world
Default Another 'check my logs please'
I've been getting a little knock lately and I don't like seeing that show up!
any help is much appreciated. and sorry the logs might not be done correctly but its all i have until tomorrow.
datalog29- stage 1 93 sf
datalog28- stage 1 sf. can't remember if this was 91 or 93
datalog27- stage 1 91 sf
cobb sf intake
at fuel pump internals
OTS map stage 1 sf 91/93
speed d3mon is offline   Reply With Quote
 Old 03-18-2012, 09:55 PM   #2
CJM
CJM's Avatar
Posts: 231   (View Stats)
CJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the world
Groaned at 5 Times in 2 Posts
Seeing as you're running fairly rich, and not on very much boost, my guess is that bad gas is the culprit for your knock problem. However, aside from a few spots above 1 degree of KR, the knock is still fairly insignificant from what I could catch with a quick glance at your logs. Be sure to go to somewhere reputable (Exxon works really well for me - 12.5 AFR and 22psi with no knock at all) for your next fill up and report back.
2010 LSM Speed3
Twinscroll .82 A/R GT3071 | Boost Junkyz Mani | 44mm TiAL MV-R
CXRacing/RPM Piping + TR8 | HTP 3.5" Intake | AT Internals | Forge V1
Premier Auto Modified ATP Long DP | JBR RSB | Other Miscellaneous Shit
Tuned by Me
CJM is offline   Reply With Quote
 Old 03-18-2012, 10:02 PM   #3
BP is the only station nearby with 93 =/
maybe ill try 91 at a different place and see how that goes
 Old 03-18-2012, 10:06 PM   #4
CJM
CJM's Avatar
Okay, but be sure to use the 91 map with it. Or, you could add octane booster.
Last time I filled with BP, my car ran really funny, but I didn't have my AP at the time so I'm not sure why. If that's any consolation.
2010 LSM Speed3
Tuned by Me
Anybody wanna check my logs? ADlBOO 2010 MS3 - ECU Computer Tuning 39 11-21-2011 10:29 PM
Check my logs please kabobulate MazdaSpeed 3/6 - ECU Computer Tuning 11 05-01-2011 02:01 PM
Check out my logs pls arielmalespin MazdaSpeed 3/6 - ECU Computer Tuning 8 03-28-2011 10:22 PM
Yo! check my logs plz. mr_mazda329 MazdaSpeed 3/6 - ECU Computer Tuning 22 02-26-2011 09:57 AM
Can someone please check my logs? ColoradoMS6
Cobb ATR Support
5 07-18-2010 09:53 PM
Page generated in 0.25161 seconds with 22 queries
