Like Tree10Likes
 Old 01-25-2015, 06:13 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Originally Posted by Inquisitive View Post
Thanks – I was afraid of that.
Cobb further states that we can only hit double the actuator spring’s tension. My K04 hits 22.73 psi at sea level on 95 RON without KR, which I hold, then taper. Double my “virtual” (if I may) actuator’s spring of 12.47 is 24.94. So, 22.73 psi is possible according to Cobb’s actuator pressure axiom, but the area under the K04’s curve suggests that 22 psi is the max (yes, perhaps a Unicorn). My follow-on question is that when purchasing a BT, shouldn’t one choose (or adjust if external) the highest waste-gate actuator spring setting offered?
This depends too; when talking about the K04, RPM is a factor here. With boost source at the turbo, I could only hit 17 PSI on pump gas @ 6k RPM. On 50/50, I can only hit 14.5-15 PSI depending on weather. On full corn, I could only make 12 PSI at the same RPM in the winter.
 Old 01-27-2015, 02:08 AM   #2
Inquisitive's Avatar
Posts: 220   (View Stats)
I hit 22.73 psi at 3500 rpms, which appears to be related to my OCC filling up too soon (~850 kms / 500 miles). I think the PCV Plate is going into siphon mode rather than ring failure (no black smoke with just cat-2). I am scheduling a compression and leak down test to confirm my denial. If I am proved correct, then I suspect a VTA won’t help.
Originally Posted by udntknw View Post
finally got around to checking this out. its not a big deal, but the Knock Decay Magnitude and Decay rate are labeled as "delay magnitude" and "delay rate".
Thanks, good catch, corrected for next version
Inquisitive is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/atr-user-manual-hybrid-tuning-noobs-early-170894/
Forum Mazda Performance Series - Zobacz temat - Dywagacje odno?nie e-tuningu This thread Refback 10-06-2015 12:44 PM
How do I AccessPORT? [xpost /r/Mazdaspeed] : mazda This thread Refback 05-18-2015 12:28 PM
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-19-2015 02:56 AM
MPS 6 new owner - Cobb flash stage 1 not hitting target boost - Page 2 This thread Refback 12-19-2014 02:13 AM
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-29-2014 12:56 PM
Enginge Mods MPS3 2007 This thread Refback 10-29-2014 08:48 PM
paulabreu's logs This thread Refback 07-31-2014 02:11 PM
Cobb Access Port FAQ - Page 11 This thread Refback 05-26-2014 04:02 AM
A noobs guide to MSF etiquette. smoogs12 Start Here 4 09-19-2012 11:01 AM
can someone send me link or pdf or whatever of that cobb ATR user guide, that shows how to calibrate your mafs?? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 5 08-05-2009 04:17 PM
Page generated in 0.29877 seconds with 23 queries
