![]() | | #81 | ![]() |
Groans: 143
| Not Ranked : 0 score I ran the economy tune for a while but abandoned it pretty quickly after the rev limiter scared the shit out of me a few times. I'd get anywhere from 9-12 psi max depending on the day.
![]() | | #82 | ![]() |
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
Cobb further states that we can only hit double the actuator spring’s tension. My K04 hits 22.73 psi at sea level on 95 RON without KR, which I hold, then taper. Double my “virtual” (if I may) actuator’s spring of 12.47 is 24.94. So, 22.73 psi is possible according to Cobb’s actuator pressure axiom, but the area under the K04’s curve suggests that 22 psi is the max (yes, perhaps a Unicorn). My follow-on question is that when purchasing a BT, shouldn’t one choose (or adjust if external) the highest waste-gate actuator spring setting offered?
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass | |
![]() | | #83 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score finally got around to checking this out. its not a big deal, but the Knock Decay Magnitude and Decay rate are labeled as "delay magnitude" and "delay rate".
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
| The Following User Says Thank You to udntknw For This Useful Post: | Inquisitive (01-26-2015) |
![]() | | #84 | ![]() |
__________________ | |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hey, thanks, it is still a journey for me too. I have since discovered some more hybrid secrets perhaps more aptly called blending, of the beast (more power) and beauty (more economy), but I am unsure where to put this ignition and AFR info. Maybe a new section would be appropriate. It appears that we can have our cake and eat it too.
I suspect that with a sufficient volume of data and known environmental variables (Enki), a proportional proxy could be determined and laid against the actual spring pressure, but to what purpose?
| The Following User Says Thank You to Inquisitive For This Useful Post: | MD1032 (01-26-2015) |
![]() | | #86 | ![]() |
| The Following User Says Thank You to Enki For This Useful Post: | MD1032 (01-26-2015) |
| The Following User Says NO Thank You to Enki For This Un-useful Post: | Z32_MS3 (01-28-2015) |
![]() | | #87 | ![]() |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score No you should pick your spring to be 1/2 to 3/4 of your targeted boost so you'll still have some control with your ECBS.
| The Following 2 Users Say Thank You to shamie For This Useful Post: | Inquisitive (01-26-2015), MD1032 (01-26-2015) |
![]() | | #88 | ![]() |
Thanks, good catch, corrected for next version
![]() | | #89 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks, this is exactly what I was looking for.
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score ATR User Manual for Hybrid Tuning Version 1.01.r • KR (knock retard) saves motors. (Putin 2.3T) in Ignition Advance • Added problem / solution table, plugs,TP coolant bypass and spill valve to Knock • Added note on not being able to transfer data-logs with file size N/A in How to Datalog • Moved Normal Progression of Modifications (Stages) and Abbreviations / Acronyms / Glossary and Mazda 3 OBD Codes to separate documents • Added Sections: Decelerating KR, Spreadsheet MAF Calibration, Blended (Power / Economy), Compression and Leak-Down Tests • Finished results table to Econ-7 and interpretation in More Economy • Typo corrected: changed Delay to Decay in Knock Tables > Knock Retard - Decay Magnitude and Rate A & B (udntknw) Normal Progression of Modifications (Stages) Version 1.00.l • Sample size stabilising / stabilised • Quantified heat soaking in Intercooler (MSMS3) • BPV / BOV intros enhanced (irishking03) • Added to Cat-less intro (MS3-a(sore)ASS-rex) • Added “stock or BT” fitment to Corksport DP • Added TurboXS, Vibrant, HKS, XForce to CBE • Expanded Ziggo’s EGR Delete explanation • FJ Motorsports (previously PG) in IC and PMM (not available) • Added part number for Ford RMM • Warning issued for Minervra Motorwerkz TMM • Added DIY SRI / TIP and Battery Trays to accommodate wide Intake Kits Sections • Added AWR & Damond Motorsports to PMM • Added AWR & TRZ to TMM • Added AutoExe to ABE • Added Bypass Valve Hose Section and three vendors: JBR, CP-E and CS • Added bending of Wiseco oil squirters, Molnar, Posifab and Manley to Forged Pistons • Added DCR VVT, Lucas Break-in oil • Added Treadstone, DOC Race and Boost Junkyz to Upgraded Exhaust Manifold • Added SpeedPerf6manc3 to BSD • Added ARP types with warning and SpeedPerf6manc3 L19 Head Studs to Main Studs • Added Molnar to Con Rods • Added new section: Main Bearings with Clevite Bearings • Added new section: Rod Bearings with King & Clevite Bearings • Added SpeedPerf6manc3 and note CS discontinued to Camshaft & Valve Springs • Added Kozmic Motorsports K27 5th and 6th Port Injection Kits and InjectorRX to Larger fuel injectors • Added descriptions (and “How it works” links) to Bars, Rear (and Front) Sway Bars, End-links, Front Strut, Rear Camber Arms, Mid-Chassis Brace, Front Traction Bars • Added Racing Beat and Hotchkis to Front Sway-Bar • Added Steeda and Racing Beat to End-links • Added Performance Autowerksracing Chassis Brace to Mid-Chassis Brace • Added GTSPEC, Autoexe and Ultra Racing to Front Traction Bars • Added CorkSport, TB Performance and Ultra Racing to Rear Strut Bars • Added new section: Front Adjustable Camber and CorkSport • Added Skid Plates section and CorkSport • Added GTSPEC and Ultra Racing to Other Bars Abbreviations / Acronyms / Glossary and Mazda 3 OBD Codes Version 1.01.r • Added Boost Junkyz, DCR, DOC Race, King, LuK Clutch, Manley (available from), McMaster-Carr, Molnar, Piasini, Steeda, tuned to Glossary I’ve been busy, see below, but gleaning from the experience helped to update this OP. New Threads: The Official Turbo Manifold Thread - Exhaust Manifold, Port & Polish and Intake Manifold The Official Turbo Manifold Thread Official Suspension Bars and Braces Thread - Bars, but not the thirst-quenching kind, & Braces, but not the kind that hold up pants Official Suspension Bars and Braces Thread The Official Engine Build Components Thread - Blown Engine? The Official Engine Build Components Thread Updated the following: The Motor Mount Thread The Motor Mount Thread Moved to OP The Motor Mount Thread THE OFFICIAL INTAKE THREAD!! THE OFFICIAL INTAKE THREAD!! Moved to OP THE OFFICIAL INTAKE THREAD!! BOV/BPV Thread BOV/BPV Thread Moved to OP BOV/BPV Thread The Official Gen 1/2 Mazdaspeed 3 Intercooler Thread The Official Gen 1/2 Mazdaspeed 3 Intercooler Thread Moved to OP The Official Gen 1/2 Mazdaspeed 3 Intercooler Thread The Official Downpipe/Test Pipe/Race Pipe Thread The Official Downpipe/Test Pipe/Race Pipe Thread Moved to OP The Official Downpipe/Test Pipe/Race Pipe Thread Official Gen One MS3 CBE Thread!! Official Gen One MS3 CBE Thread!! Moved to OP Official Gen One MS3 CBE Thread!!
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 04-22-2015 at 11:00 PM. |
| The Following 4 Users Say Thank You to Inquisitive For This Useful Post: |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Stuck and KB made http://www.mazdaspeedforum.org/forum/foru...s-early-187756 adding to list of FAQ Threads http://www.mazdaspeedforum.org/forum/foru...ow-make-99362/ |
| The Following 5 Users Say Thank You to Raider For This Useful Post: | btstarcher (04-29-2015), Enki (04-28-2015), Inquisitive (04-28-2015), Rich990 (05-25-2015), udntknw (04-28-2015) |
![]() | | #92 | ![]() |
![]() Join Date: Feb 2016 Location: Arizona
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score This is my 2nd time on the Forum. (I can't seem to get into my old paid member account from 2014) but the one problem I've always had when it comes to tunning a speed3 is the internet "code" language. I've been wrenching on cars since the 90's and have had everything from an turbo 140 '65 corvair to a laid out '81 C-10 with a big block, I even had a Skyline (when I was stationed in Okinawa) for a few months. I'm still in the Military served all over the place, I'm married with kids, and since I moved into this little hot-hatch I've noticed there isn't the local "speed shop" vibe when it comes to cars anymore. Learning this new language is the biggest challenge I've had. I've been searching everywhere for this glossary of terms. Thanks!
__________________ -Keenan 2013 Mazdaspeed 3 with some stuff done. |
![]() | | #93 | ![]() |
If you need help getting into your old account. Contact @SofaKingAwesome; sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | ScreaminKeenan (02-13-2016) |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Thanks for the help! I ended up creating this account just to get some help on my AP tune.
![]() | | #95 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Keenan, What's your old account under?
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
![]() | | #96 | ![]() |
![]() Join Date: Mar 2015 Location: Norcross, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score @ejb2112; here is what i was talking about. |
| The Following User Says Thank You to Dommo14 For This Useful Post: | ejb2112 (03-07-2016) |
![]() | | #97 | ![]() |
![]() Join Date: Mar 2014 Location: Decatur, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
__________________ Mods on my 2013 white pearl with tech: Corksport HPFP internals Damond RMM HTP 3.0" intake CP-E TMIC NGK Iridium IX Ultimate Racing test pipe with high flow cat Ultimate Racing axleback exhaust Cobb Accessport v3 Freektuned and loving it | |
![]() | | #98 | ![]() |
![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi folks. Newbie here in ATR tuning. And a big big thanks to you for sharing these precious guides to guide newbies like us. I am from malaysia, and drives a Speed6 (Mazdaspeed Atenza). Nice to meet u all.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/atr-user-manual-hybrid-tuning-noobs-early-170894/ | ||||
| Forum Mazda Performance Series - Zobacz temat - Dywagacje odno?nie e-tuningu | This thread | Refback | 10-06-2015 12:44 PM | |
| How do I AccessPORT? [xpost /r/Mazdaspeed] : mazda | This thread | Refback | 05-18-2015 12:28 PM | |
| Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 01-19-2015 02:56 AM | |
| MPS 6 new owner - Cobb flash stage 1 not hitting target boost - Page 2 | This thread | Refback | 12-19-2014 02:13 AM | |
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 11-29-2014 12:56 PM | |
| Enginge Mods MPS3 2007 | This thread | Refback | 10-29-2014 08:48 PM | |
| paulabreu's logs | This thread | Refback | 07-31-2014 02:11 PM | |
| Cobb Access Port FAQ - Page 11 | This thread | Refback | 05-26-2014 04:02 AM | |
| A noobs guide to MSF etiquette. | smoogs12 | Start Here | 4 | 09-19-2012 11:01 AM |
| can someone send me link or pdf or whatever of that cobb ATR user guide, that shows how to calibrate your mafs?? | Wenis Prinkle | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 08-05-2009 04:17 PM |
