 Old 06-12-2011, 11:12 PM   #1
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
Default back to back logging
Ok so today I ran 4 logs back to back, all 3rd gear pulls. Car was at operating temp. I was looking at KR so I can adjust my timing tables to eliminate it at WOT. Problem is, the mother fucking KR is not consistant, lol.
So question is, what log would you use?
Ive posted an excel spread sheet with comparison of each run, in order of course.
2011 Liquid Silver
Corksport SRI/TIP/AIRBOX
Ultimate Racing catback
JBR stage 2 shift kit
SURE RMM
Ex_WRX_driver is offline   Reply With Quote
 Old 06-12-2011, 11:19 PM   #2
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
IMO, all of them.
Reducing KR is all the same - back off on timing or make your AFRs richer until you don't see any knock. What AFRs are you running? I'd reduce your timing advance by 1* where you're seeing knock and if it doesn't go away then start either keep backing off timing or making your requested AFRs richer, until you see ~.35 KR or less.
What is important isn't so much the amount of knock you're seeing, it's where you're seeing it - that being said knock is very bad and you need to address it if you're seeing it consistently. You need to do what I said earlier - back off of timing or make your requested AFRs richer, and not just in that one area - both should be smooth curves, timing from 0 @ VE to ? @ RL, and AFRs from leanest @ onset of boost to richest @ RL.
 Old 06-12-2011, 11:25 PM   #3
AFR targets are 11.5, Ill just make adjustments to my timing tables in the morning.
2011 Liquid Silver
SURE RMM
The Following User Says Thank You to Ex_WRX_driver For This Useful Post:
Speed3eak (06-12-2011)
Help just got my car back! bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 0 11-26-2010 04:21 PM
Which HKS Cat-back is better? dead-zone MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-06-2010 08:39 PM
Report: SEAT withdraws from WTCC after back-to-back titles Haltech Automotive News 0 01-15-2010 06:20 AM
Just got the car back 8.5MS3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 11 06-07-2009 12:28 PM
Page generated in 0.24781 seconds with 22 queries
