| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
(Thread Starter) | Not Ranked : 0 score COBB Tuning announces the latest version of AccessTUNER for all MAZDASPEED vehicles offering significant enhancements. This new version of AccessTUNER incorporates COBB Tuning’s proprietary Boost Tuning capability for 1st and 2nd Gen MAZDASPEED3s, Launch Control and Flat Foot Shifting for 2nd Gen (2010-2011) MAZDASPEED3s, as well as Fast Data Logging, improved 3D Graphing and many new tables for all MAZDASPEEDs! Boost Tuning AccessTUNER has been extensively updated to give MAZDASPEED AccessTUNER users greater control over boost control. Our latest Boost Tuning logic is now available for all 2007-2011 MAZDASPEED3 vehicles, allowing users to use this new boost control strategy on any calibration created with AccessTUNER. All previously released BETA Wastegate and Boost Control tables have been upgraded to final release as well. For a complete list of new and previously released tables, visit the AccessTUNER Update History page. COBB Tuning has also just released a huge number of maps featuring calibrations for the most popular intakes and bolt-on parts for the 2007-2009 MAZDASPEED3 with Boost Tuning already enabled that can be used as base maps for custom calibrations. For a complete list of calibrations visit the 2007-2009 MAZDASPEED3 or 2010-2011 MAZDASPEED3 Online Map Databases. A new V2.0 Tuning Guide is also included to assist users in tuning using the new Boost target logic. Launch Control and Flat Foot Shifting Launch Control and Flat Foot Shifting has been enabled for 2nd Gen (2010-2011) MAZDASPEED3 vehicles with this release, bringing these popular features to the entire MAZDASPEED line-up. All MS3 v2.00 and MS6 v1.07 COBB Tuning Off The Shelf calibrations are LC/FFS-ready. Launch Control limits engine RPM to a user-set value when launching to build boost and increase launch consistency. Flat-Foot Shift allows the user to maintain wide-open-throttle during gear changes, keeping partial boost between shifts and improving acceleration post-shift. The recent 1.6.4.2-2553 firmware release enables Launch Control and Flat Foot shifting on 2nd Gen MAZDASPEED3’s and sets the limits at the factory rev limiter. This release of AccessTUNER software allows the Launch Control and Flat Foot Shifting limiters to be adjusted and saved in the map. Fast Data Logging This update also includes Fast Data Logging for all MAZDASPEED AccessPORTs. Faster datalogging means more resolution in data logs, allowing users to see how the engine is behaving during high-speed and high-load conditions in greater detail. The Fast Data Logging feature is built into the latest maps for the MAZDASPEED3 and MAZDASPEED6 are available now for download. This feature applies to both v2 and v2b AccessPORTs. Improved 3D Graphing MAZDASPEED AccessTUNER software has received a 3D graphing facelift in the latest release. Both solid and wire 3D graphing styles have been improved. Solid 3D graphing is enhanced with a grid overlay and more intuitive color gradient. Wire 3D graphing is improved with finer wire drawing and higher contrast colors that are easier to view. Here are some before and after examples of 3D graphing in the AccessTUNER software: Post FFS Lean Condition and WOT Stutter Fixes for MAZDASPEED Vehicles New fueling tables allow the users that are experiencing a lean condition following FFS (MAZDASPEED3/6) and the WOT Stutter (MAZDASPEED6) to make adjustments in these tables and resolve these issues. The following tables can be used to tune out this momentary lack of fuel to fix both the lean condition and the associated misfire or stutter:
Additional table exposure and fixes:
The new MAZDASPEED3 v2.00 calibrations do not have these fixes implemented in them, the next round of calibrations will include these by default. The upcoming MAZDASPEED6 v2.00 calibrations will have this fix implemented. Expanded Table Definitions AccessTUNER Race has been expanded with more tables for better fueling, ignition and idle control. In addition, High Pressure Fuel Pump tables have been added that will allow users to scale the fuel pressure sensor allowing for the installation of very high-flow pumps. These new tables allow AccessTUNER users unprecedented control over their vehicles enabling unparalleled exploitation of “Big Turbo” setups and potentially, bio-fuel tunes. To see the entire list of table updated, visit the AccessTUNER Release Notes History. Compatibility Update An incompatibility exists between previous versions of our maps and the latest AccessPORT firmware release for the MAZDASPEED vehicles, which will lead to improper readings through the AccessPORT’s Live Data and/or Data Log features. In order to resolve this issue, please be sure to follow the steps below for the scenario that most closely matches your situation. To use these latest calibrations your AccessPORT must be updated to Firmware Version 1.6.4.2-2553 or later. If you are using calibrations made with older versions of AccessTUNER or wish to use an older Off The Shelf calibration please update your calibrations using the following steps. Please be sure to download and install the latest version of AccessPORT Manager 2.0 before following any of the steps listed. Maps must be open and saved with AccessTUNER version 1.8.6.0-2517 or later to resolve compatibility issues. * Updating when utilizing the latest Off-The-Shelf (OTS) calibrations
We would like to stress that if you are using an old version of one of our OTS calibrations or an AccessTUNER Race custom tune with a new AccessPORT firmware revision, you can resolve this Data Log/Live Data issue by re-saving your map through the latest version of AccessTUNER Race, then flashing the newly saved map to your vehicle. For a complete listing of new tables and features, please visit the MAZDASPEED AccessTUNER Release Notes History page. Additional help documents can be found on the COBB Tuning Forums or visit the AccessTUNER Tuning Guide. For more information on AccessTUNER or to download your copy of AccessTUNER Race, visit our AccessTUNER Race Information Page or go directly to the Download Request Form to get your copy today!
__________________ ![]() MAZDASPEED EXPERT GROUP - ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW ![]() COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE Last edited by Cobb Tuning; 09-01-2011 at 08:29 AM. |
| The Following 8 Users Say Thank You to Cobb Tuning For This Useful Post: | dachtler (09-02-2011), f-castrillo (09-02-2011), G26 (09-01-2011), harryclay (09-01-2011), myt_tuf1 (09-01-2011), Nliiitend1 (09-02-2011), ruthless013 (09-04-2011), WillyH (09-01-2011) |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score So those Ignition min timing limit tables will also get rid of the ecu pulling timing to reduce stress on the drive-train correct? @David@COBB
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score my ms6 wants boost tuning |
-David@COBB | |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Boost tuning has been public beta for months and works well. I had it until I went MBC with the BT. Will probably go back to it with the Grimmspeed EBCS someday.
__________________ |
| Not Ranked : 0 score oh ok so i just need to update the beta? |
| Big Updates for AccessTUNER Race for All MAZDASPEED Vehicles | Cobb Tuning | MazdaSpeed 3/6 - ECU Computer Tuning | 30 | 09-06-2011 05:12 PM |
| AccessTUNER Race - MAZDASPEED USDM 2010 MAZDASPEED3 - Can't update | WillyH | Cobb Tuning | 3 | 06-13-2011 10:23 AM |
| Firmware and AccessTUNER Updates for MAZDASPEEDs Available Now! | Travis@Cobb | 2010 MS3 - ECU Computer Tuning | 6 | 05-09-2011 04:57 PM |
| AccessTUNER and Firmware Updates Available Now for ALL MAZDASPEEDs! | Travis@Cobb | Cobb Tuning | 1 | 05-06-2011 10:43 PM |
| MAZDASPEED3/6 AccessPORT and AccessTUNER Updates Now Available! | Cobb Tuning | Cobb Tuning | 6 | 12-03-2010 04:51 PM |
