 Old 05-26-2018, 06:00 PM   #1
CleverOne's Avatar
Posts: 49   (View Stats)
CleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of lightCleverOne is a glorious beacon of light
Default Tune review
Anything in this tune that would prevent me from being able to achieve commanded boost?
I have gone through testing ebcs and wastegate and both are functional, i did a boost leak test though the intake pre-maf. Details can be found in this thread.
I uploaded the tune and a 4th gear log, only thing that changed is i routed my catch can differently which i explain in the linked thread above.
JBR 88d RMM~CorkSport 3" CBE~CNT 3" DP Catted~JBR True 3" Intake~JBR EBCS~CX Racing FMIC/ Pipes~CorkSport Injector Seals~JBR TIG~BNR S4~EGR Delete~Synapse Synchronic DV~Cobb AP~Koni Str.t Struts
CleverOne is offline   Reply With Quote
 Old 05-30-2018, 12:11 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
If you aren't hitting boost targets, then you have some load targets in place that are getting referenced. Your WGDC decreases throughout the run.
Can't open your tune on this computer.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 05-30-2018, 12:31 PM   #3
CleverOne's Avatar
I thought that might be the case as well but I have gone over any load problems.
I linked to another thread where I was asking is my catch can could cause a boost leak, I did a leak down premaf and had sent air coming from the catch can.
I have a new one in order from jbr, I'll update after I install it Thurs or Friday.
 Old 05-30-2018, 12:51 PM   #4
Eth Fiend
phate's Avatar
Your ECU is trying to lower your boost. Catch can isn't going to fix that.
Post up screenshots of your Wastegate Duty Load Dynamics and Wastegate Duty Load Error Comp tables.
-06 MS6
 Old 05-30-2018, 01:05 PM   #5
CleverOne's Avatar
 Old 05-31-2018, 09:55 PM   #6
CleverOne's Avatar
So I checked for leaks after changing the can, it doesn't leak from the can anymore but still not boosting over 20lb.
I'm at a loss and don't know what else to check hardware wise. I powered the ebcs and it clicked and air passed through the correct outlet.
I've done a compression test which was good, I've done a boost leak test, no leaks, I've pressed air into the wastegate actuator and heard and saw the lever move.
If it's the tune I'm just going to get a freaktune most likely, I just want to get everything good before that.
Not hitting boost targets, not boost leak ADHDAdditiv MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-18-2014 02:18 PM
Boost Targets pawlwawl06 2010 MS3 - ECU Computer Tuning 31 01-13-2013 06:37 AM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.25325 seconds with 22 queries
