![]() Join Date: Jul 2017 Location: Houston
(Thread Starter) | Not Ranked : 0 score I've provided a 4th gear WOT pull on this tune. If someone can tell me what's going on and if I need to check anything out in the engine bay that would be really helpful. MAF and MAP are already calibrated. I don't see it being the BPV leaking as it was holding 21 PSI no problem on my stock K04. Mod list: -Corksport Turbo -Corksport Stage II SRI + TIP -Corksport HPFP Internals -Corksport 3-port EBCS -Corksport 3.5 bar MAP -3" SS Catless DP -3" Straight Pipe Google Docs link to WOT datalog: https://docs.google.com/spreadsheets...it?usp=sharing |
(Thread Starter) | Not Ranked : 0 score So I've checked the BCS lines, none of them blew off or anything. The IC piping looks good, everything is tight. So I'm not sure what's going on. |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Talk to your tuner....
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | Amnesiac (07-28-2018) |
(Thread Starter) | Not Ranked : 0 score I talked to him, he said according to the math at 40% WGDC it should hit 20 PSI, but he said the math doesn't always check out, each car is different. I just gotta keep my expectation lower until the final end tune it seems. I was really expecting 20 PSI but like he said the turbo may just be lazy until you really increase the WGDC. Much more reassuring, I thought I had a boost leak or a broken BPV or something. |
![]() Join Date: Apr 2016 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Lazy turbo? Hmm. I'm no engineer, but based on what I remember about MAF math I think your MAF g/s at 100° at sea level would be like 600 CFM. The CS Stage 2 intake is a 2.5" intake with a 2.6" MAF, which only supports like 400 CFM. Are you sure your tuner didn't pull the MAF cal for the CS Power Series 3" intake? Edit: On a side note, you really should be running a 3" or larger intake with that turbo for exactly that reason. |
Could you explain to me what exactly a larger intake means? Does it prevent the MAF from being maxed out and not being able to read any higher or what? Edit: I kind of understand. The MAF voltage represents the g/s of air, I'm already 4.7-4.8V at 300g/s, from what I've gathered the max is 5V. So my intake will only read up to 345g/s, I'm sure it will be pulling a lot more air at 25 PSI than at the 16 PSI I did the pull at. So would a 3" intake be ideal? What's the largest I can go without having to get a smaller battery or ECU relocation? | |
You're not maxed out on your intake because your voltage isn't maxed, but you're pretty darn close and your turbo isn't even hitting boost targets. Like I said, I'm no engineer. Your tuner might have it calibrated right and my math may be totally wrong. I'm simply observing that 100° air is FAR less dense than cooler air, so 300 GRAMS (mass, not volume) per second at that temperature seems like an awful heck of a LOT for that little tube. That figure comes directly off your MAF calibration. | |
| Not Ranked : 0 score See image. This is what I'm talking about. That's like 575 CFM. |
It may seem like a lot simply because the turbo flows a lot better than the K04. | |
| Not Ranked : 0 score Don't forget you're also putting stress on the turbo by having a small inlet pipe. Just imagine your turbo is you, and the air is a Wendy's Frosty. How would you feel if I gave you a little ass straw to suck up the frosty? Not very happy, am I right? |
(Thread Starter) | Not Ranked : 0 score I don't think it's that drastic, the inlet pipe is still larger than the actual turbo inlet. Either way a new intake is in order. |
| Not Ranked : 0 score Ya, you could add a 10" intake, but the turbo inlet is still tiny. The intake you choose would depend on what your goals are. I went with a 3.5", the only downside is making it fit. The CS turbo can outflow a 3" but will NEVER outflow a 3.5", so I'll never have to buy another intake until I change turbos.
I've been talking to a guy on FB, should be able to get CXRacing piping + TR6 + HTP 3.5" for like $450 if I play my cards right. Side note, my tuner sent me the third map revision, it hits 18.5 PSI now so I'm for sure not leaking boost or anything. He just really cranked up the WGDC, at close to redline I'm sitting at 80% WGDC. Should be able to increase the WGDC overhead once I go FMIC since it will flow a lot better. | |
| Not Ranked : 0 score I had to pull a lot if WGDC when I switched to a better TMIC. An FMIC will have the same effect.
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score Will is a great tuner. I'm sure he'd tell you to get a larger intake if you asked him. I was pulling about 4.8v with 3" intake on my CS in cool weather, so i swapped it out for a 3.5". ain't gonna outflow that with this turbo on a stock block. definitely something you should look into.
__________________ Genpoo stuff |
| Just got a AP V2. Not hitting target boost. | DasItMane | MazdaSpeed 3/6 - Turbo Induction | 3 | 07-12-2016 06:42 PM |
| Not hitting Target Boost | grade247 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 18 | 09-12-2014 02:13 PM |
| Not hitting my target boost | TheProYodler | 2010 MS3 - ECU Computer Tuning | 26 | 08-11-2014 09:02 PM |
| Not hitting target Boost. PLZ HELP | mgramata | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 04-22-2014 09:01 PM |
| Not hitting target boost | btrend | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 34 | 04-14-2013 09:28 PM |
