 Old 06-22-2012, 09:00 PM   #1
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Windows 7 x64:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'logs' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, DirectorySecurity dirSecurity)
at System.IO.Directory.CreateDirectory(String path, DirectorySecurity directorySecurity)
at DaFT.Logger.getWriter()
at DaFT.Logger.logError(String msg)
at DaFT.DaFTForm.browseButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Fra...7/mscorlib.dll
DaFT
Assembly Version: 1.1.0.0
Win32 Version: 1.1
CodeBase: file:///C:/Program%20Files%20(x86)/DaFT/DaFT.exe
Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...dows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...em.Drawing.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...ystem.Core.dll
System.Data
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_64/S...ystem.Data.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...System.Xml.dll
Microsoft.Office.Interop.Excel
Assembly Version: 14.0.0.0
Win32 Version: 14.0.4756.1000
CodeBase: file:///C:/Windows/assembly/GAC_MSIL...erop.Excel.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
 Old 06-22-2012, 10:08 PM   #2
Brennan's Avatar
Posts: 220   (View Stats)
Brennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the world
Try running DaFT as an administrator. The "logs" folder it tries to create would be "C:\Program Files (x86)\DaFT\logs" on an x64 machine. It looks like the user you were logged in as did not have permission to create that directory for whatever reason (i.e. did not have write access to the "C:\Program Files (x86)\DaFT" folder).
Very likely this would correct the issue: check the "Security" tab on the "C:\Program Files (x86)\DaFT" folder properties, and enable write access for the user/user group you wish.
Could this just be a result of choosing to install "Just for this user" as opposed to for "Everyone"? Maybe. Perhaps I should change the default to "Everyone"...
In any event, please let me know if that works for you. I hadn't tested anything with multiple user accounts/permissions. Thanks.
'10 Velocity Red Mica MS3 with Tech
Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid
Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2
Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers
Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs!
Brennan is offline   Reply With Quote
 Old 06-23-2012, 03:36 AM   #3
memin's Avatar
Posts: 994   (View Stats)
i got the same message and i selected everyone on the set up!! I did those steps but same outcome, not working for me on winows 7.
 Old 06-23-2012, 08:52 AM   #4
Brennan's Avatar
@memin
@honda etr
Well, that blows nuts. Try the attached version. A "DaFT\logs" folder should now be created in "C:\Users\<userrname>\Documents" as recommended.
The odd thing is that I tested DaFT on Windows 7 x64, though it was under an administrator account.
Anyway, please let me know how this works out. Should only take a few seconds to test. Thanks!
Edit: Removed attachment to attach in the original first post. See first post for v1.1.1.
The Following User Says Thank You to Brennan For This Useful Post:
CosmicArkie (06-23-2012)
Report: Honda trimming U.S. workforce with voluntary buyouts Haltech Automotive News 0 03-20-2012 06:50 AM
Playing with trimming mrdouble99 MazdaSpeed 3/6 - ECU Computer Tuning 5 12-14-2011 01:50 PM
File recovery USMCEvan Computers & Technology News 12 08-19-2011 02:47 PM
Standback Tuning Software, Drivers, and Logging Software www.cp-e.com Custom Performance Engineering (cp-e.com) 24 04-24-2011 11:49 AM
Report: Toyota trimming global production goals for 2011 Haltech Automotive News 0 12-07-2010 08:40 AM
Page generated in 0.30096 seconds with 24 queries
