![]() | | #41 | ![]() |
![]() Join Date: Nov 2010 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,935
__________________ '10 Velocity Red Mica MS3 with Tech ![]() Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2 Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs! |
![]() | | #42 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score daft doesn't working for me , the application highlight all the COLUMN |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
I think it would be easier to link the log to virtual dyno. Post a screenshot of your DaFT settings + one of the logs it creates.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | ||
![]() | | #44 | ![]() |
| Not Ranked : 0 score Hello ! i'm using default setting of Daft . I only erase filters throttle position : minimum 68.00 . i get error : invalide minimum value ''68.00''! Daft versione 1.1.2 |
![]() | | #45 | ![]() |
Also, if you want to clear a filter, you simply need to make the "Column" blank using the drop-down. Thanks, Brennan
__________________ '10 Velocity Red Mica MS3 with Tech ![]() Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2 Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs! | |
| The Following User Says Thank You to Brennan For This Useful Post: | mr.speedy3 (03-17-2013) |
![]() | | #46 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Just downloaded. Gonna give it a try tonight. |
![]() | | #47 | ![]() |
![]() Join Date: Mar 2012 Location: merrimack, nh
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score bumping an old thread because of the awesome app. DaFT is fantastic. I sent an email suggestion for trims including a few cells before and after ones that meet criteria if selected |
| Report: Honda trimming U.S. workforce with voluntary buyouts | Haltech | Automotive News | 0 | 03-20-2012 06:50 AM |
| Playing with trimming | mrdouble99 | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 12-14-2011 01:50 PM |
| File recovery | USMCEvan | Computers & Technology News | 12 | 08-19-2011 02:47 PM |
| Standback Tuning Software, Drivers, and Logging Software | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 24 | 04-24-2011 11:49 AM |
| Report: Toyota trimming global production goals for 2011 | Haltech | Automotive News | 0 | 12-07-2010 08:40 AM |
