Like Tree8Likes
 Old 09-14-2011, 09:38 AM   #1
blakkat's Avatar
Posts: 572   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
Default e85 kr thread
im getting lots of kr on e85, ckspeed thinks its fake, what are your opinions?
first two are before clint upped my timing and changed my wgdc, me and keith did a datalog and the first one had high kr but didnt record.
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
 Old 09-14-2011, 09:42 AM   #2
greg08's Avatar
Posts: 480   (View Stats)
lol dude what spark plugs you got?
could be your spark plugs with seeing how freakin consistant it is
try replacing those first. i doubt its anything else. may be sound to
 Old 09-14-2011, 10:03 AM   #3
blakkat's Avatar
stock plugs, but wouldnt e85 be enough that i wouldnt need colder plugs
Mods:
 Old 09-14-2011, 10:08 AM   #4
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
How much e85 are you running?
100%, a few gallons?
You said that you increased timing? You need to retard timing and see if it goes away.
stock plugs should be fine with your mods
Last edited by wolly6973; 09-14-2011 at 10:08 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-14-2011, 10:10 AM   #5
blakkat's Avatar
im running a 3gallon-3gallon so a 50% mixture.
clint aka @phate did my timing table for me, i dont know anything about timing and im kinda nervous to mess with it personally.
clint added timing and it didnt change anything at all, it didnt get worse
Mods:
 Old 09-14-2011, 10:18 AM   #6
I know that Phate knows his shit, but if he is using a gen2 base map, you may ask him to start with a intercooler upgrade map..
In my experience, there are some changes in the modeling of the timing @ spool, and it seems difficult to start with a lower stage map and increase timing without inducing knock / remodeling part of the timing curve. (@ least on gen2 cars)
Your decay rate is a bit long too.
 Old 09-14-2011, 10:25 AM   #7
blakkat's Avatar
well he doesnt have the gen2 atr so we've been doing things over the phone. basically im targeting 18.5 psi, with an 11.9 afr. since we've started tuning. we've modified wgdc to hit my target boost, and this is what my timing table looks like,
37.50 37.50 46.70 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00 55.00
24.50 31.90 39.70 39.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00
26.00 32.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00 40.00
23.00 31.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00 37.00
15.90 20.50 26.50 29.00 30.50 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00 32.00
11.50 15.50 20.50 24.50 26.75 29.00 29.00 29.00 29.00 29.00 29.00 29.00 29.00 29.00
10.16 13.25 15.40 20.70 23.35 26.00 26.00 26.00 26.00 26.00 26.00 26.00 26.00 26.00
8.82 11.00 13.19 15.30 18.15 21.00 21.88 22.75 23.00 23.00 23.00 23.00 23.00 23.00
7.48 8.75 10.97 12.43 15.41 18.40 18.80 19.50 20.50 20.50 20.50 20.50 20.50 20.50
6.14 6.50 8.76 10.64 13.31 14.00 16.50 17.69 18.78 20.00 20.00 20.00 20.00 20.00
4.56 5.50 6.87 8.23 12.40 13.00 15.00 16.40 17.60 18.50 18.50 18.50 18.50 18.50
2.97 5.03 7.09 9.14 11.20 12.00 13.25 15.26 16.76 18.00 18.00 18.00 18.00 18.00
1.38 3.54 5.69 7.85 10.00 11.50 12.25 13.68 16.00 16.00 16.00 16.50 17.00 17.50
-0.21 2.04 4.30 6.55 8.80 10.00 11.50 12.49 14.00 15.00 15.50 16.00 16.00 17.00
-1.80 0.30 2.40 4.50 6.60 9.00 10.75 11.38 13.00 14.00 15.00 15.50 15.50 16.00
-2.80 -0.70 1.40 3.50 5.60 8.00 9.50 10.50 12.50 13.50 14.50 15.00 15.00 15.50
-3.80 -1.22 1.35 3.92 6.50 7.50 9.00 10.00 11.50 12.50 13.50 14.00 14.50 15.00
-4.80 -2.35 0.10 2.55 5.00 6.00 7.75 9.50 10.50 11.50 12.50 13.50 14.50 14.50
-5.80 -3.47 -1.15 1.18 3.50 6.00 7.50 9.00 10.00 11.00 12.00 12.50 13.50 14.50
-6.80 -4.27 -1.73 0.80 3.33 5.00 6.50 8.50 9.50 10.50 11.50 12.00 12.50 13.50
-7.80 -5.06 -2.31 0.43 3.17 4.50 6.50 8.50 9.00 10.00 11.00 11.50 12.00 13.31
-8.80 -5.85 -2.90 0.05 3.00 4.00 5.25 6.50 7.00 8.00 9.00 11.14 11.79 13.13
-9.80 -6.84 -3.88 -0.91 2.05 3.10 4.05 5.00 6.50 7.50 8.50 10.79 11.57 12.94
-10.80-7.73-4.65 -1.58 1.50 2.80 3.65 4.50 6.00 7.20 8.30 10.43 11.36 12.75
-11.80-8.68-5.55 -2.43 0.70 2.30 3.70 4.50 5.63 6.90 8.10 10.07 11.14 12.56
-12.80-9.65-6.49 -3.34 -0.18 1.79 3.75 4.50 5.25 6.60 7.90 9.71 10.93 12.38
-13.00-10.05-7.10-4.14-1.19 0.77 2.72 4.00 4.88 6.30 7.70 9.36 10.71 12.19
-14.00-11.05-8.10-5.14-3.00 -1.00 2.00 3.50 4.50 6.00 7.50 9.00 10.50 12.00
thanks guys
Mods:
The Following User Says Thank You to blakkat For This Useful Post:
rfinkle2 (09-14-2011)
 Old 09-14-2011, 10:24 AM   #8
wolly6973's Avatar
Groans: 386
Looks like the timing is pretty conservative though.
I would definitely give everything in the engine bay a once over to make sure nothing is loose.
Does the kr always happen in the same rpm range, or do you get it up top as well?
The Following User Says Thank You to wolly6973 For This Useful Post:
 Old 09-14-2011, 10:27 AM   #9
I see that, and was having a kr issue with running such retarded timing also.
I switched to a base map given to me with much more aggressive timing, and have been able to add a few degrees with no knock to boot (straight pump 93 octane.)
 Old 09-14-2011, 10:28 AM   #10
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I can help you too, brother. Gen 2 on 50/50 e85/93. Let me know. feel free to email.
wsbucker@gmail.com
403whp/451ft/lb Dry Shot
 Old 09-14-2011, 10:31 AM   #11
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
I can't believe that this can be real KR. How can 2 gallons eliminate all KR on mine, and yet he can run around a 50/50 mix and have so much?
Also, I don't think that the kr is consistent. It never seems to be around the same number or at the same place. And the fact that adding timing did not exacerbate it, makes me skeptical.
Can injector seals fail on such a lightly modded car?
Just my two cents.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 09-14-2011, 10:32 AM   #12
wolly6973's Avatar
Groans: 386
I was getting kr in the same region as you a while back also.
I added a few gallons of e85 and pulled a TON of timing and nothing helped.
Once I put the timing back to OTS values, it was pretty much gone except for a really small count every once in a while at spool up.
 Old 09-14-2011, 10:33 AM   #13
Ask Phate to knock your decay rate down some.
The new datalogging rate makes it look like way more knock than is truly present.
wolly6973 (09-14-2011)
 Old 09-14-2011, 10:57 AM   #14
Bucker's Avatar
Groans: 451
im talking with blakkat now. Ill be sending him some revisions via excel including reducing decay rate and making sure his OL/CL transitions are on point.
The Following 2 Users Say Thank You to Bucker For This Useful Post:
rfinkle2 (09-14-2011), wolly6973 (09-14-2011)
 Old 09-14-2011, 10:38 AM   #15
bewsted's Avatar
Posts: 2,456   (View Stats)
I'd bet on engine noise....
You have motor moounts?
You need to change try scaling your offset a bit....This is something that you really need to let someone who knows what they are doing mess with....
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
 Old 09-14-2011, 10:40 AM   #16
blakkat's Avatar
yes i have a jbr rmm, shit man this is getting complicated, theres no way i can do this without fucking something up
Mods:
 Old 09-14-2011, 10:41 AM   #17
wolly6973's Avatar
Groans: 386
You coming to the meet out in DeKalb tonight?
We can mess with it there.
 Old 09-14-2011, 10:41 AM   #18
blakkat's Avatar
i live there man hahaha
@finkle, the only ic maps i see are all stage 2
Mods:
 Old 09-14-2011, 10:48 AM   #19
That may be so, but you don't have to use the boost portion, just the ignition tables.
 Old 09-14-2011, 10:45 AM   #20
bewsted's Avatar
I mean i'm not guarenteeing that it is engine noise but it does happen....
EWG K04...GETSUM!
 Old 09-14-2011, 11:01 AM   #21
bewsted's Avatar
ol copy to cl call it a day
EWG K04...GETSUM!
 Old 09-14-2011, 11:05 AM   #22
Bucker's Avatar
Groans: 451
What? I am talking about exit delays and max load stuff lol.
 Old 09-14-2011, 11:04 AM   #23
BTW, I have to thank @atvfreek and @XLT_66's dyno thread for waking me up as to timing.
atvfreek (09-14-2011)
 Old 09-14-2011, 11:21 AM   #24
I just looked @ that last log, and there is definitely something other than timing going on there.
 Old 09-14-2011, 11:22 AM   #25
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I run four degrees more timing than that at redline, and higher timing just about everywhere else...on nothing but 93 pump gas.
IMO you really need an EGT if your going to play with timing... Adding or subtracting 2 degrees may net 0 butt dyno gains, but raise or lower your egt's 200 degress. Low timing or very high timing will raise EGT's, and can cause KR..
Looking at those logs, the first thing I would do is bump up the knock sensor offset above 5K. KR of .06, .1, .2 above that rpm are almost certainly just engine noise..
bewsted likes this.
The Following 5 Users Say Thank You to SSinstaller For This Useful Post:
atvfreek (09-14-2011), bewsted (09-14-2011), Bucker (09-14-2011), rfinkle2 (09-14-2011), wolly6973 (09-14-2011)
 Old 09-14-2011, 11:30 AM   #26
bewsted's Avatar
that is my guess too
EWG K04...GETSUM!
 Old 09-14-2011, 11:34 AM   #27
atvfreek's Avatar
Posts: 7,787   (View Stats)
I think you are running too little timing for e-85. I've even seen cars on 93 with too little timing have kr issues. Some of the base ots maps have weird ignition tables. What base map did you start with?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Ckmazdaspeed3 (09-14-2011), rfinkle2 (09-14-2011), wolly6973 (09-14-2011)
 Old 09-14-2011, 11:45 AM   #28
Bucker's Avatar
Groans: 451
ok, here are the basic settings that I throw at every map I make for me or anyone else. These are essentially just sensor calibrations and other shit to make it act consistently in most conditions. I have emailed this to blakkat and I figured I would make it available for you losers, too. This is a building block. Fueling/ boost/ timing will be built on top of this as per mods/ owners desires.
I would add timing, blakkat. I know Phate knows what he is doing, but at the same time he isnt going to just toss a 20* timing map on there without working up to it. I run the eth/93 mix with that much timing now with no issues. If you want to step that up, ill give you a modified timing table of mine.
The Following 6 Users Say Thank You to Bucker For This Useful Post:
ahskeetz (09-14-2011), atvfreek (09-14-2011), phate (09-14-2011), rfinkle2 (09-14-2011), SSinstaller (09-14-2011), wolly6973 (09-14-2011)
 Old 09-14-2011, 11:55 AM   #29
Groans: 60
My KR offsets are the same everywhere except >1.5 load at 5000 I use .8 and 5500 .95. My decay rates are set to 100..
The Following User Says Thank You to SSinstaller For This Useful Post:
 Old 09-14-2011, 12:01 PM   #30
Bucker's Avatar
Groans: 451
Yes, like I said this is what I use as a starting point. I am sure that a lower decay rate makes sense as well as the KR offsets, but I have found that these settings work for my needs. Actually, I might lower my decay rates now for myself. Once you have a tune dialed in pretty well thats a good call.
The Following 4 Users Say Thank You to Bucker For This Useful Post:
atvfreek (09-14-2011), rfinkle2 (09-14-2011), SSinstaller (09-14-2011), wolly6973 (09-14-2011)
 Old 09-14-2011, 12:17 PM   #31
Groans: 60
2.0 KR at 100ms decay rate takes 600ms to clear, that's a long time when a third gear pull is ~6.5 seconds. That being said if I was having kr issues I would leave it at 200 just for the added safety..
Bucker likes this.
 Old 09-14-2011, 11:50 PM   #32
blakkat's Avatar
still have steady 3 degrees of kr, fml. looked for loose shit in the engine bay and didnt find anything. im gonna try a stage 0 map after i run out of e85.if kr is still there ill just have to keep searching the engine bay
Mods:
 Old 09-15-2011, 06:35 AM   #33
Bucker's Avatar
Groans: 451
Hey, if you copy your MAF scale over to the stage 0 map you can flash that thing with eth still in the tank. Sorry, should have mentioned that last night.
 Old 09-15-2011, 06:47 AM   #34
wolly6973's Avatar
Groans: 386
Just to keep the thread up to date...
We tried adding timing per the few theories in this thread, and got more kr. So that theory is untrue in this case.
Then we richened up the AFRs from 11.9(was seeing a .3 variance, so up to 12.2) to 11.6, and this did not change anything.
Bucker (09-15-2011)
 Old 09-16-2011, 10:39 AM   #35
blakkat's Avatar
used up all the e85, and ran straight 93, still getting kr around 6, plugs seemed fine, not indicative of 6* of kr. im dumbfounded
Mods:
 Old 09-16-2011, 10:42 AM   #36
Don't run that e-85 based tune on 93 octane if you can help it.
Where are you getting the 6* KR?
If @ wot, take it easy until you get your map straightened out.
 Old 09-16-2011, 10:47 AM   #37
blakkat's Avatar
sorry i should have explained, i switched to a stage 1 stock map
Mods:
 Old 09-16-2011, 10:49 AM   #38
Are the 6* of KR @ wot?
Also, are you using 91 octane or 93?
 Old 09-16-2011, 11:44 AM   #39
wolly6973's Avatar
Groans: 386
He has 93 oct.
Other shots in the dark that were mentioned to me when I had my issues were to check the crank angle sensor to make sure it is seated correctly. If it is a little out of line, it could be showing less timing than you are actually running.
Also, like I mentioned at the meet. Try pulling the IM and making sure the kr sensor is tight. If you want, I can help you with that next week sometime.
rfinkle2 (09-16-2011)
 Old 09-16-2011, 11:58 AM   #40
He has 93 oct.
If Wolly6973 had a look @ your map, and is helping you with your hardware you are in good hands, no doubt.
I ask about the octane because it seems that part throttle knock on the 91 octane maps is common.
Page generated in 0.58209 seconds with 29 queries
