Like Tree12Likes
 Old 06-08-2012, 01:02 PM   #1
StayBroke's Avatar
Posts: 2,075   (View Stats)
Default ecu relocation bracket
Ok i made a ecu relocation bracket!.
The Following 26 Users Say Thank You to StayBroke For This Useful Post:
AZSPEED3 (06-08-2012), dereeek (06-12-2012), faeker (08-31-2013), fishin53 (06-09-2012), fywdyl (06-11-2012), getthatmfer (05-07-2013), Hamilton69 (06-08-2012), helmetface (06-08-2012), JacksonMS30 (06-12-2012), JTMS3 (06-10-2012), kritz (06-12-2012), lilred (06-08-2012), m249saw (06-08-2012), Mchart (08-04-2012), melbaro (06-08-2012), ms3blackmica (09-01-2013), NoRegrets (06-08-2012), phate (06-12-2012), Raider (06-08-2012), rghispanic88 (06-08-2012), Scoobs (06-08-2012), Seatime3 (06-09-2012), Sid3wayS (06-08-2012), skeurton (06-08-2012), The Nut (06-02-2013), trf5000 (06-08-2012)
 Old 06-08-2012, 01:07 PM   #2
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
I see these going fast with the new jbr intake also just hitting market
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
The Following User Says Thank You to Hamilton69 For This Useful Post:
rfinkle2 (06-13-2012)
 Old 06-08-2012, 01:07 PM   #3
I love it. I'll take one. LMK how much.
StayBroke (06-08-2012)
 Old 06-08-2012, 01:09 PM   #4
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Hope it isn't grounded.
 Old 06-08-2012, 01:13 PM   #5
StayBroke's Avatar
Will do..ill check next week to see how much the metal will cost me..
Mine is stainless but i am not making them in that, its just what i had laying around.
and why is that...called people and they said it was fine if it was...
@rfinkle2, what do you think about that(grounding issue).
Last edited by StayBroke; 06-08-2012 at 01:13 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to StayBroke For This Useful Post:
Scoobs (06-08-2012)
 Old 06-08-2012, 01:16 PM   #6
Snotrocket's Avatar
Posts: 900   (View Stats)
1 for me if reasonably priced...
2010 MS3 Black
395whp/386wtq
 Old 06-08-2012, 01:17 PM   #7
StayBroke's Avatar
Well i need to no on this ground issue, if it is an issue??
 Old 06-08-2012, 01:18 PM   #8
Enki is extremely bright and I believe was working on a similar project in the past.
What do I think? I think that if it is grounded and cannot be, there are easy fixes.
 Old 06-08-2012, 01:30 PM   #9
StayBroke's Avatar
Ok i thought of a fix.....be back in 30 min with Teflon Nuts and Bolts, and Rubber washers umk.
 Old 06-08-2012, 01:59 PM   #10
Ok, so you do have a kickass product, @StayBroke. But to sell here, you need to follow fs rules. I'd like you to check the group buy rules if you can make these in 45 days, ok? Pm me with any questions. This is for your protection and msf members as well.
dereeek (06-12-2012), Mizzle (08-11-2012), StayBroke (06-08-2012)
 Old 06-08-2012, 02:05 PM   #11
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I likes where you mounted the grimmspeed.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
dereeek (06-12-2012), StayBroke (06-09-2012)
 Old 06-08-2012, 02:16 PM   #12
Scoobs's Avatar
Posts: 750   (View Stats)
Nice, well if you build it they will sell!
Sold
New
Wife's car
The Following User Says Thank You to Scoobs For This Useful Post:
 Old 06-08-2012, 02:22 PM   #13
Enki's Avatar
Because the stock battery box and mounting hardware for the ECU is *not* grounded, I used all nylon hardware on my setup (see below).
Thread:
http://www.mazdaspeedforum.org/forum/foru...ocation-92280/
Relevant image:
http://www.mazdaspeedforum.org/forum/foru...-installed.jpg (linked for size)
It may not be an issue, but I'll be damned if I'm going to risk something that critical to the operation of my vehicle because I assumed it would be OK.
Easter Bunny (07-03-2012), Raider (06-08-2012), smoogs12 (06-08-2012), StayBroke (06-09-2012)
 Old 06-08-2012, 02:29 PM   #14
StayBroke's Avatar
Just used nylon nuts and bolts.....check with meter and it is no longer grounded.
Thanks for the heads up.
 Old 06-08-2012, 02:32 PM   #15
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
@Enki, what kinda battery are you using in that pic, and did you build the box for the battery as part of the ecu relocate as well?
Damond Built Speed 6
 Old 06-08-2012, 02:37 PM   #16
StayBroke's Avatar
Not grounded anymore....
rfinkle2 and bhamitgeek like this.
The Following 7 Users Say Thank You to StayBroke For This Useful Post:
AZSPEED3 (06-09-2012), Enki (06-08-2012), lilred (06-08-2012), Raider (06-08-2012), rfinkle2 (06-08-2012), Sid3wayS (06-08-2012), smoogs12 (06-08-2012)
 Old 06-08-2012, 02:49 PM   #17
Enki's Avatar
It's a Braille battery and bracket; the bracket has been modified so that the battery can be pulled straight out when the ECU is removed and another holding tab unbolted.
Every bit of information regarding my setup should be in the thread (with pictures).
 Old 06-08-2012, 04:11 PM   #18
The factory ecu is not grounded, so I agree with Enki that it is best to err on the side of caution.
To the best of my knowledge, however, most (including all the Mazda info I can find, lot of rx-7 info available) are grounded.
Better safe than sorry though.
Nylon ftw.
Enki (06-08-2012), StayBroke (06-08-2012)
 Old 06-08-2012, 04:36 PM   #19
StayBroke's Avatar
Yes you are right, i haz da nylon now.
 Old 06-08-2012, 04:40 PM   #20
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Dude, very nice. I would pick one up too if you made them.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ABSpeed3 For This Useful Post:
 Old 06-08-2012, 04:46 PM   #21
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Damn, I can't do this because that's where I have my meth filler spout. Unless I relocate that as well
Sent from my Galaxy Nexus
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
The Following User Says Thank You to f-castrillo For This Useful Post:
StayBroke (06-10-2012)
 Old 06-08-2012, 05:03 PM   #22
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
I see you @HTP viewing this thread. Where is your bracket at? lol
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
The Following User Says Thank You to m249saw For This Useful Post:
 Old 06-09-2012, 12:50 PM   #23
StayBroke's Avatar
There making a new battery box.
 Old 06-09-2012, 02:15 PM   #24
I was looking into getting a smaller battery, maybe a braille.
Anyhow, I could use a single exhaust too. (ahem).
 Old 06-09-2012, 03:35 PM   #25
HTP
HTP's Avatar
Posts: 210   (View Stats)
Pics of said battery box are posted in our forum. We have made other battery box setups for those using the braille or odyssey pc680 batteries, but chose to stick with a full size battery for its CCA abilities. If someone wanted a small battery setup we'd be more than happy to whip one up. I would never relocate to the trunk, adds to much weight, and you'll need a cut-off switch if you ever go to the track and tech catches you.
Matt
Scoobs (06-25-2012)
 Old 06-09-2012, 03:59 PM   #26
SpdDemon89's Avatar
Posts: 216   (View Stats)
SpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the worldSpdDemon89 is the leader of the world
Sign my up for one. maybe then i can put the clamp that came with the intake back on without it grinding into the white plastic...
'12 S3 Black
CS intake+TIP - AT Internals - JBR RMM - UR DP+TP - CPE TMIC - Denso ITV22 - Carseat 25hp shot
SpdDemon89 is offline   Reply With Quote
The Following 2 Users Say Thank You to SpdDemon89 For This Useful Post:
rfinkle2 (06-11-2012), StayBroke (06-10-2012)
 Old 06-09-2012, 07:57 PM   #27
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
Yes indeed, I am interested In one as well.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
The Following User Says Thank You to InFeXIoN For This Useful Post:
 Old 06-10-2012, 02:11 PM   #28
Enter the 36 Chambers
NoRegrets's Avatar
Posts: 612   (View Stats)
looks good.
i might need one since i'm thinking of buying jbr's new 3.5 wp intake....
Tuned by Nishan
SP63 Longblock
The Following User Says Thank You to NoRegrets For This Useful Post:
 Old 06-12-2012, 07:59 AM   #29
I'm glad to see you addressed the grounding issue. You do not want your ECU grounded; the potential for very bad things can result from a grounded ECU. Have your exhaust welded on if you'd like to see what I'm talking about.
Enki (06-12-2012), Mizzle (08-11-2012), StayBroke (06-12-2012)
 Old 06-12-2012, 08:40 AM   #30
StayBroke's Avatar
Yes that issue was fixed and i found out why you dont want it grounded lol. i never ran the car like that but i am using nylon screws now.
And what are you talking about exhaust welded on??
 Old 06-12-2012, 09:48 AM   #31
Enki's Avatar
He means weld on your exhaust with the ecu grounded to find out why you don't want the ecu grounded.
Easter Bunny (07-03-2012), rfinkle2 (06-12-2012), StayBroke (06-12-2012)
 Old 06-12-2012, 10:06 AM   #32
HTP
HTP's Avatar
The ECU is already grounded through the wire harness....ALL ECU's are grounded. There is no continuity from the ECU backing plate to any part inside that ECU. The reason it is not grounded from the factory is because they are using a plastic battery tray to mount it to. That's it. No other fancy reason. And James is right on the part that ANY and EVERY car should not be welded on without disconnecting the battery first.
Matt
 Old 06-12-2012, 11:32 AM   #33
I don't agree with this but I'm not going to derail this thread either. I think the nylon fasteners is the way to go.
Jamie
Enki (06-12-2012), StayBroke (06-12-2012)
 Old 06-12-2012, 12:09 PM   #34
HTP
HTP's Avatar
Jamie
This issue (for some reason) needs a definitive answer. It's not an agree or disagree situation. If you don't agree then post why. I will of course post why I know for a fact that its not grounded with pictures. That will answer the topic of whether or not its grounded. I have repaired these ECU's, not from damage of welding but from an internal short in an O2 sensor blowing out a circuit.
Matt
Broxer (06-12-2012), m249saw (06-12-2012)
 Old 06-12-2012, 12:21 PM   #35
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I made my small battery box and ECU mount a while ago. It never even occurred to me that the ECU was not grounded from the factory, until I stumbled upon this thread.
I was having problem with what I thought was spark blow out, just some slight hesitation at WOT, in fact I could not catch them on a log, it would would just hesitate for a micro second.
After reading this thread, it makes sense to me that there was some reason that Mazda did not ground the ECU through the case. So, I bought some fiber washers and nylon spacers and isolated the ECU. Guess what? The hesitation went away. Is this conclusive proof that this will happen across the board? Well, no, but @HTP think of it this way, if Mazda did it this way, then there almost has to be a reason. Car manufactures spend millions of dollars to perfect and prove their engineering, and well, there is not a company out there that has that kind of resources to devote to engineering.
Take this for what it's worth, my .02 cents, add an vibration isolator for the ECU to your kit, and do not ground the ECU.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
 Old 06-12-2012, 12:40 PM   #36
HTP
HTP's Avatar
As you'll see the only thing that touches the case and the board is a thermal paste that IS NOT electrically conductive. Mazda engineers used the aluminum backing plate as a heat sink.
86AmishMs3 (06-24-2012), El_Diablo (08-31-2013)
 Old 06-12-2012, 12:46 PM   #37
HTP
HTP's Avatar
Our battery kit utilizes a nylon insert in between the ecu and box because I don't expect everybody to agree with me and I'm not gonna beat a dead horse.
Matt
Easter Bunny (07-03-2012), m249saw (07-08-2012), StayBroke (06-12-2012)
 Old 06-12-2012, 02:19 PM   #38
StayBroke's Avatar
Anyways look im half way done @Raider....
Raider, NoRegrets and bhamitgeek like this.
The Following 2 Users Say Thank You to StayBroke For This Useful Post:
Mizzle (08-11-2012), Scoobs (06-25-2012)
 Old 06-13-2012, 05:18 PM   #39
StayBroke's Avatar
Ok so i made it where they will slide about 1/4in further toward the fuse box.....heres what you will have to do(its so easy a cave man could do it). @jdub0802, @rfinkle2, @skeurton, @Ezekiel81923, @Seatime3 ,@SpdDemon89
Notice where i cut the plastic off.
Shipping out tom.......send you all tracking via pm on here.......Look how it clears the htp tip///with my 3in 45 coupler.
@InFeXIoN ...Should clear the jbr i would think.
InFeXIoN likes this.
Last edited by StayBroke; 06-13-2012 at 05:18 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to StayBroke For This Useful Post:
InFeXIoN (06-14-2012), NoRegrets (06-13-2012), Scoobs (06-25-2012)
 Old 06-13-2012, 05:20 PM   #40
Don't sweat a tracking # for me. I know you are good for it.
If not, I'll just blow your car up on the next revision! LOL
bhamitgeek likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Easter Bunny (07-03-2012), InFeXIoN (06-14-2012), Raider (06-13-2012), SLOWHATCH (02-19-2013), StayBroke (06-13-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/ecu-relocation-bracket-115847/
ECU Relocate Bracket This thread Refback 09-28-2012 11:45 AM
• View topic - ECU relocation bracket This thread Refback 07-05-2012 12:40 AM
MAF relocation radioflyer MazdaSpeed 3 - Engine, Transmission & Driveline 19 06-08-2016 06:03 PM
ECU relocation TWOptSL0W MazdaSpeed 3/6 - ECU Computer Tuning 22 08-13-2011 07:20 PM
ECU Relocation? Where? Speedy3 MazdaSpeed 3 - Engine, Transmission & Driveline 15 04-07-2008 10:40 AM
Page generated in 0.61574 seconds with 37 queries
