Like Tree3Likes
  • 1 Post By Slash
  • 1 Post By Slash
  • 1 Post By Slash
 Old 02-09-2013, 03:16 PM   #1
Slash's Avatar
Posts: 110   (View Stats)
Slash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the worldSlash is the leader of the world
Default First proper log.
Alright its my first time so be easy on me. I'm running Stage 1 OTS with cs SRI and Test Pipe. STOCK HPFP (I know I know.) 3rd gear pull. Anyone see anything wrong with it?
Slash is offline   Reply With Quote
 Old 02-09-2013, 05:09 PM   #2
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Yeah, you need internals. Several drops <1600psi.
The Following 3 Users Say Thank You to Mike@Stratified For This Useful Post:
jseams (02-09-2013), phahengpro (04-21-2013), trf5000 (03-05-2013)
 Old 02-09-2013, 06:08 PM   #3
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
... like into the 1400's at one point and several in the low 1500's.
But you know, according to that tuner in Australia - these cars don't need internals. rofl
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
 Old 02-09-2013, 09:29 PM   #4
Slash's Avatar
Haha yeah. I've got edge emailing me when they get in.
Edit, alright yeah I figured out how to read it myself finally. The drops around 4200 RPM are dangerous as shit. I will be remapping back to stock until I get my hands on internals.
You can actually see it on the VD, I knew I needed to post something up after I swear I felt it hit fuel cut. It felt like traction control going off but in 3rd gear.
 Old 02-17-2013, 11:40 PM   #5
alexryan's Avatar
Posts: 642   (View Stats)
alexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the world
thats a wavy ass power curve lmfao dont go WOT!
//2012 Black Mica Mazdaspeed 3//
//Sure Torq R3//Cobb AccessPort//Autotech Internals//Ultimate Racing Axelback//Resonator Delete//Ebay Catless DownPipe
//TR8L & Protege Garage piping//Devils Own Stage 1//NGK One Step Colder(failed) Denso ITV22//GoFastBits Blow Off Valve//Ksport Coilovers
//GTX 2867r//Protege Garage Externally Gated Manifold//Precision Turbo Wastegate//Bosh 3 Bar Map//HTP 3.5" Full Intake
//Grimmspeed 3 Port//Cobb Wastegate Lockout//Selfmade Screamer Pipe//ACT 6 puck w/ streetlite flywheel
// R3X Tune in Progress (self tune) 310whp 354wtq (CF 1.01) w. DO7 KO4
......GTX2867r 22psi: 357whp 353wtq (CF1.01)
Needs installing: JBR BSD kit, OCC
alexryan is offline   Reply With Quote
 Old 02-27-2013, 06:43 PM   #6
Slash's Avatar
Well I've recently installed the HPFP and some other little goodies(See Sig) This log should look a little better.
This is on the Highest OTS Stage 2 Map I had on my AP. Only thing it calls for that I'm missing is the DP. Is that going to be an issue besides robbing power? The log looks good to me but I'm obviously no expert.
AT Internals/Cobb AP/NGK LTR7IX/CS SRI/CS TIP/CS TP/CX Racing FMIC/Cobb XLE 50-50/JBR Rmm and Weight/Hankook Ventus v12/18x8.5 Rota Grids
13.39 at 103.35 in the 1320. Allegedly ~290WHP/~370WTQ
Tuned by The FREEK
 Old 02-28-2013, 10:02 AM   #7
alexryan's Avatar
you have the racepipe, thats all you need for the stage 2. the full dp adds maybe 5 or 10 hp but its nothing too crazy; you just are running higher wgdc than someone like myself who has a full dp and is running wgdc of like 40 to hit 20psi, and you need 60 to hit 18/19.
log looks good, fp is holding nicely, maf cal is needed and i would suggest getting a tune to help keep your boost more steady and to get more POWA
You have some random kr under 1.0 so thats noting to worry about at this point, your timing is too low to cause real kr, most likely its something loose in the engine bay or just some bumps in the road.
 Old 02-28-2013, 10:08 AM   #8
Slash's Avatar
Awesome, I'm so relieved to hear. I was so sick of babying her for the last 3 months. The power is much smoother now. If anyone doubts the effects of the stock hpfp please feel free to direct them to my logs.
Tuned by The FREEK
 Old 02-28-2013, 09:23 PM   #9
alexryan's Avatar
trust me, there are thousands of threads about this on the fuel pump and thousands of logs, your just one in a shit ton lol my log when my fp failed was scary, 700psi fp at wot 0.0
 Old 03-05-2013, 02:25 PM   #10
Slash's Avatar
Well I threw in some Ngk plugs and it seems to have cured my random KR. The PO was running Autolite XP's gapped to .022-.030 depending on the plug... I'm disappointed I waited this long to check it.
Also today for shits n giggles I disconnected the SWAS, it feels like it made it a little quicker off the line. Or is that just my ass dyno and I can stop being a ricer and plug it back in to cure the dummy lights?
Tuned by The FREEK
 Old 03-05-2013, 06:19 PM   #11
alexryan's Avatar
the log looks awesome, is that modified from OTS? your afr's look very nice and the boost is pretty stable. You can gain a lot more power from some timing increase as you are only running 8*. there is a never ending fight about the whole swas thing so im not too sure. what i am sure of is that if you got a tune you will be shitting your pants if you think this map is fast.
 Old 03-05-2013, 08:52 PM   #12
Slash's Avatar
That's an unmodified OTS. atvfreek will be starting on my tune tomorrow
jseams likes this.
Tuned by The FREEK
The Following 2 Users Say Thank You to Slash For This Useful Post:
alexryan (03-05-2013), jseams (03-05-2013)
 Old 03-16-2013, 10:36 AM   #13
Slash's Avatar
Well my tune is over, all went VERY smooth. Here's the numbers, this is straight 93 pump gas no meth with stock catted dp.
The FREEK is a freek he was able to push almost 30 hp out of my car with just a tune, and the power under the curve is completely reformed.
Tuned by The FREEK
The Following 3 Users Say Thank You to Slash For This Useful Post:
atvfreek (03-17-2013), Hush (03-16-2013), Pointless (04-21-2013)
 Old 03-16-2013, 02:38 PM   #14
The Nut's Avatar
Posts: 1,571   (View Stats)
Gorgeous fucking Tq & HP curves @atvfreek;!
Real nice boost target acheivement, very smooth. My car is driving me bonkers.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 03-16-2013, 02:53 PM   #15
Slash's Avatar
The car is completely transformed and he did it in 5 revisions! His base map was a huge improvement to start and only got better from there would recommend to anyone.
The Nut likes this.
Tuned by The FREEK
alexryan (03-16-2013), atvfreek (03-17-2013)
 Old 03-16-2013, 03:44 PM   #16
The Nut's Avatar
Yeah, I have a bad feeling I'm not gonna get much further with mine without an I.C. & TP.
 Old 03-17-2013, 06:56 AM   #17
Slash's Avatar
I've been lucky enough to have a local guy upgrading everything so I've been picking up his old parts for a very nice price. I'm buying his GTX3076R next month but it's not going on my car until I have some added fuel supply, and a Guardian Angel.
Tuned by The FREEK
alexryan (03-22-2013), atvfreek (03-17-2013)
 Old 04-21-2013, 03:33 PM   #18
Slash's Avatar
UPDATE: Justin is a fucking monster case in point. He made my car a fucking RACECAR!
I honestly have LESS than $1500 in mods thanks to you guys on here and your classifieds. I could of never imagined this car going that fast, I'm still on stock Downpipe, exhaust, suspension, and motor mounts. This car will run a 12 on KO4 without a doubt in my head. Thank you everyone for giving me the car to prove my driving skills and get noticed!
Hoyoman likes this.
Tuned by The FREEK
 Old 04-21-2013, 03:53 PM   #19
JgamB's Avatar
Posts: 2,566   (View Stats)
Nice pass - how many miles are on those Hankooks? They seem to catch a lot of flak around here but I thought they provided pretty good straight line stick, and a 2.1 60ft isn't bad at all.
 Old 04-21-2013, 04:56 PM   #20
Slash's Avatar
Miles are really unknown but I'd imagine less than 5k. I bought them used, and the grip today was fantastic. My 60's were consistent and actually got better even though they never prepped besides the initial time. All my runs were 13.3-13.6, I'm not slipping the clutch at all, that is a full on dump. I slipped it the first time and got confident enough to let her dump and never looked back. I'm also FFS into 2nd as well. These tires did fantastic. I never got beat off the line once and I raced a nitrous foxbody and 3 shelby mustangs. I actually beat a 2013 TWICE and have proof!
Notice the number 86
Tuned by The FREEK
 Old 04-21-2013, 05:29 PM   #21
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Great runs. Gt500 must be worst driver.
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
Is this the proper part that I need? Caligula MazdaSpeed 6 - Engine, Transmission & Driveline 3 08-17-2012 05:49 PM
What you need for a proper build Hamilton69 2010 MS3 - Big Turbo Builds 2 01-04-2012 12:15 AM
Proper wastegate? TheNewGuy MazdaSpeed 3/6 - Turbo Induction 8 11-08-2010 07:08 AM
What is proper AFR for MS3? Matrix311 MazdaSpeed 3/6 - ECU Computer Tuning 13 12-08-2008 10:06 AM
Page generated in 0.43024 seconds with 27 queries
