 Old 05-27-2015, 09:26 PM   #1
Bug2110's Avatar
Posts: 20   (View Stats)
Bug2110 is infamous around these partsBug2110 is infamous around these parts
Groaned at 34 Times in 3 Posts
Default Freek OTS or full tune
Hay all I have freek ots map right now I need to retune because I added a ets tmic now I have the option to upgrade to a full tune for a little more just not sure if it's really worth it at my mod level I have catless turbo back mazdaspeed cai and tih and internals would a full tune make much of a diffrence at this point
2010 speed 3
Freektune ots, Mazdaspeed cai, htp tih, ETS tmic, 1 step colder NGK plugs, Catless turboxs tp, Catless turboxs DP, CNT racing catback, go fast bits bpv/bov, mishimoto hid kit, eonon 5163 nav system.
Bug2110 is offline   Reply With Quote
 Old 05-27-2015, 09:29 PM   #2
King Scumbag's Avatar
Posts: 2,384   (View Stats)
A full tune is always worth it. Correct me if I'm wrong but doesn't what you payed toward the OTS get discounted off of the full tune?
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 05-27-2015, 09:31 PM   #3
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Short answer, probably will see benefits...
Long answer, depends if you want anything changed from the OTS... Such as power coming on later, detuned 1st and 2nd etc...
You'll probably get some more power, but how much extra, it's hard to say, depends on your fuel
 Old 05-27-2015, 09:31 PM   #4
Bug2110's Avatar
Ya it's ether 75 for retune or 125 to upgrade to a full tune
2010 speed 3
 Old 05-27-2015, 09:33 PM   #5
If you don't plan on doing any more major upgrades any time soon just get the full tune..Yes there will be a difference.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-27-2015, 09:36 PM   #6
Bug2110's Avatar
about customizing the tune I really wouldent do that IDE just go with his recommendations because I don't really know that much about it. Also with fuel corn would be cool but I keep reading that it's nasty shit and clogs our fuel pumps up
Yeah from where I sit now like I don't see myself upgrading any further I think after this all I really have left is big turbo
2010 speed 3
Last edited by Bug2110; 05-27-2015 at 09:36 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-27-2015, 09:36 PM   #7
You obviously need to read more and donate because you must be getting you info from 247.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
HawkeyeGeoff (05-28-2015)
 Old 05-27-2015, 09:38 PM   #8
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
For your level of mods get the full tune. Its a $50 difference and it is definitely worth it. Don't know much about e85 so cant help you there
nilashish is offline   Reply With Quote
 Old 05-27-2015, 09:42 PM   #9
acousticdefbot's Avatar
Posts: 319   (View Stats)
acousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the world
worth it... to me. depends on what you really want from the car.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 05-27-2015, 09:44 PM   #10
Bug2110's Avatar
Ya maybe that is true need to start using search here on the fourm over Google. might get better results
2010 speed 3
 Old 05-27-2015, 11:40 PM   #11
coasttime's Avatar
Posts: 163   (View Stats)
coasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond repute
Groaned at 19 Times in 8 Posts
Why did you upgrading the TMIC? Have you read about them and how they heat soak which means you lose power. I would do some more research and sell the TMIC and go with the FMIC if you don't have enough then save up.
Back to the original question, yes get the full tune. The guys on here tought me a great lesson that i will not forget. Your car is only as goid as the tune.
coasttime is offline   Reply With Quote
 Old 05-28-2015, 02:30 AM   #12
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
This has been pointed out on MANY threads. People upgrade TMIC's because it's cheaper, easier, and just as good (with meth)
I have a corksport TMIC, with Meth, and my spool and throttle response are much better, my BAT's are cooler then those with just a FMIC (and obviously the same as those with a FMIC and meth) and it just generally looks better under the hood (no seeing loads of rat nest wires)
The price you pay for a decent FMIC, you can buy a TMIC with meth.. But in the end, it's all personal preference.
As for OP. As others have said. If your leaving your car that way for a while, go full tune. If not, mod away and then full tune.
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
 Old 05-28-2015, 06:23 AM   #13
Bug2110's Avatar
Yeah I have no intentions of getting a front mount I would like to keep my hood scoop functional with my ets I literally stay 15° Above ambient temperature when boosting so it seems to work well a hell of a lot better then stock also yes when stopped it does heat soak bad but I would think so would a fmic
2010 speed 3
 Old 05-28-2015, 08:26 AM   #14
Lots of decent HP cars still running upgraded top mounts. Upgraded top mounts have been more then once proven that it will lower boost temps. Don't believe everything you hear..
I have a COBB front mount and by boost temps get higher then a few people I know on upgraded top mounts..
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
323whp with a FrEeK TuNe! pwned 2010 MS3 - Dyno Sheets/Discussions 37 06-21-2013 05:55 PM
Start of a FREEK tune... bryansawiseone 2010 MS3 - ECU Computer Tuning 29 10-13-2012 06:02 PM
Page generated in 0.32627 seconds with 26 queries
