Like Tree208Likes
 Old 04-07-2011, 11:24 AM   #1
@ your service sir...link from dj to come...
italics from atr helpfile:
This comparison only relates if you have an intake system that is other than stock; if your dictated A/F is 11.0 and you measure 12.0 in the exhaust stream, then you will want to add (+) grams/sec for the MAF voltage that corresponds for that RPM and load point. The specific adjustment for the above situation should be multiplying the corresponding MAF flow grams/sec by 1.0909 = 12/11. You should be measuring very close to the same Lambda (A/F Ratio) in your exhaust stream that you have dictated in your Fuel OL/WOT Commanded EQ (No Knock) table. Your trim values will always adjust back and forth (+/-); let them, that is what they are supposed to do. You should not have to modify the MAF Calibration table if you have a stock vehicle. We highly suggest you do not spend excessive time tuning your MAF Calibration table just so the A/F output matches exactly what is dictated in the Primary Fuel table.
You will chase your tail getting it spot on then you will fill up at a different gas station that will have a different quality fuel and the targets may be slightly
off.
Could not find exact post from DJ (aka dustin)
but, thanks to @dougefresh_ for this great thread...
HOW TO CALIBRATE YOUR MAF! With An Example
JLACO11 likes this.
indianaryan (04-07-2011), Nataphen (04-07-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/gen-2-cobb-atr-discussion-77176/
Potential new mk2 3mps owner ? Mazda MPS Owners Club This thread Refback 10-10-2013 11:17 AM
Stage 2 questions - Page 2 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 07-23-2013 10:49 AM
First Data Log W/ AP - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 03-05-2013 07:23 AM
Cobb AP - Great unit but order woes - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 01-22-2013 08:31 PM
Cobb AP - Great unit but order woes - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-31-2011 06:19 PM
First Data Log W/ AP - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 06-22-2011 09:23 AM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Fueling/AFR Discussion dadasracecar Mazdaspeed3/6 General Discussion 13 12-24-2008 09:56 AM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 1.26094 seconds with 22 queries
