Like Tree7Likes
  • 2 Post By adlpb
  • 1 Post By adlpb
  • 2 Post By adlpb
  • 1 Post By kritz
  • 1 Post By SLOWHATCH
 Old 11-22-2011, 06:29 AM   #1
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Default Going over ~19psi, SWAS issues
I've been in the process of tuning my car with fink for the past month or so. We got to the point where we were making considerably more power than the OTS stg2 map. This is when boost was turned up past 19 (20 to be exact) and timing was played with. We started seeing crazy AFR's. Going lean to the high 12's during the initial WOT run, and then going down to the low 10's. We first thought it was a boost leak/dirty MAF.
Cleaned my MAF, and turned down boost and the issue went away. But after increasing power again, same issues. Per finkle's advice, I unplugged my SWAS sensor and voila, issues gone. Apparently, when I was making more power, the wheelspin was making my steering wheel move so slightly to trigger the SWAS shit sensor.
If your tune is making power past the 300's (mine is in the 330's whp in VD), I highly recommend you disable SWAS. Only downside for 11'+ tech package users is that it will disable AFS, and will have the AFS light blinking in addition to the 2 others that are on for non-tech users. But it makes a world of a difference during turns.
Also, since we have electric power steering pumps, it seems to kill power steering during low speed (parking) turns. But nothing a bit of muscle can't handle.
SWAS disable is also essential for Auto-x ers. Just don't take a turn too fast while giving it gas or you'll understeer like crazy.
EDIT: Some asked me for a picture of the sensor. It is the one that has a red plastic color on the bottom. You will see 3 harnesses on the right side of the area you are working in. Unplug this one.
Photo credit to ckmazdaspeed3
rfinkle2 and sorpano like this.
The Following 8 Users Say Thank You to adlpb For This Useful Post:
aggierandy (04-08-2013), Broxer (11-22-2011), myt_tuf1 (11-22-2011), MZR165 (11-22-2011), Payne Racing 67 (11-22-2011), rfinkle2 (11-22-2011), rghispanic88 (11-22-2011), RodneyAE (11-22-2011)
 Old 11-22-2011, 07:43 AM   #2
@adlpb,@SLOWHATCH,@kritz,@Broxer,@XLT_66
Thanks to adlpb and @Pedal-Force... (as well as ckmazdaspeed3 for the pic)
how to also install a toggle switch.
http://www.mazdaspeedforum.org/forum/foru...ml#post1132628
I need to do this asap.
adlpb (11-22-2011), Broxer (11-22-2011), SLOWHATCH (11-22-2011)
 Old 11-22-2011, 07:54 AM   #3
adlpb's Avatar
Groans: 669
@adlpb..
Thanks to @Pedal-Force...
I was thinking of that during my drive to work this morning. I imagine I "bypass" button/switch from the SWAS to the console wouldn't be too hard to do. Something to work on during the Thanksgiving break for sure. Hey Rob if you get it done before me, take some pics.
The Following 3 Users Say Thank You to adlpb For This Useful Post:
Broxer (11-22-2011), rfinkle2 (11-22-2011), SLOWHATCH (11-22-2011)
 Old 11-22-2011, 08:31 AM   #4
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
I want to pick up a switch from Mazda that will mount next to my DSC disable switch and wire it to the SWAS interupt. Gotta look for the part number. I have to take a look at the DSC sw to see if there is any unused terminals on that sw.
@rfinkle2,@adlpb,@Broxer,@XLT_66
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
 Old 11-22-2011, 08:56 AM   #5
adlpb's Avatar
Groans: 669
I imagine doing something like this guy did with his meth on/off switch.
rfinkle2 and kritz like this.
The Following 5 Users Say Thank You to adlpb For This Useful Post:
BeeZaa (11-22-2011), kgb (08-13-2013), kritz (11-22-2011), rfinkle2 (11-22-2011), SLOWHATCH (11-22-2011)
 Old 11-22-2011, 09:13 AM   #6
adlpb's Avatar
Groans: 669
@kritz I'm looking for specific buttons to be purchased (ie DSC button) but I can only see the entire assembly being sold in one piece. If you can find individual buttons let me know. Otherwise, the idea of the metal switch on the right (pictured above) is not bad, although it doesn't look very well. I can also suggest a plastic button glued to the under side of the steering wheel if you are concerned about making permanent holes to the side cluster for re-sale purposes.
The Following 2 Users Say Thank You to adlpb For This Useful Post:
kritz (11-22-2011)
 Old 11-22-2011, 09:17 AM   #7
kritz's Avatar
Groans: 95
@adlpb, @rfinkle2
I'll do some searching maybe source it from a salvage yard. I'll let you know and see how many I can find. I would like to have it have an OEM look, perhaps the Canadian sw for heated seats would be another option.
The Following 3 Users Say Thank You to kritz For This Useful Post:
adlpb (11-22-2011), rfinkle2 (11-22-2011), SLOWHATCH (11-22-2011)
 Old 11-22-2011, 09:53 AM   #8
kritz's Avatar
Groans: 95
Well just got off the line with Compass Mazda, the heated seat option is a no go, it is not an on/off sw but an adjustable knob type. The other option would be getting a DSC sw assb and surgicaly removing the sw and transplanting it next to the original DSC but that is not an option for you folks with the Tech model. going to look in the Digigkey catalog to see if there is anything there.
@adlpb,@rfinkle2
http://www.digikey.com/?WT.mc_id=Bra...6cfcs506128092
adlpb (11-22-2011)
 Old 11-22-2011, 10:10 AM   #9
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Only thing I am concerned about is the loss of power steering. Is that the only thing is affects negatively for non techs?
 Old 11-22-2011, 10:16 AM   #10
adlpb's Avatar
Groans: 669
That and the 2 lights that are on the dashboard.
To be honest with you, the power steering is there, I only noticed I had to give it a BIT more force during parking, and very minimal. I've driven cars with absolutely no power steering and I can tell you that this is like butter, even with SWAS off. Give it a try for yourself, it literally takes 5minutes to do this mod - all you need is a screwdriver and a 10mm wrench for the battery.
 Old 11-22-2011, 10:20 AM   #11
G26
G26's Avatar
Groans: 39
Eh, I think I'll wait till a better fix comes out hopefully with the AP.
 Old 11-22-2011, 12:48 PM   #12
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Thanks for the info guys, I'm heading out of town for Thanksgiving but I'll definately give this a shot. My previous car had no power steering so we'll see how this goes.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 4 Users Say Thank You to Broxer For This Useful Post:
adlpb (11-22-2011), kritz (11-22-2011), rfinkle2 (11-22-2011)
 Old 11-22-2011, 01:18 PM   #13
TsaktuO's Avatar
Posts: 20   (View Stats)
TsaktuO is a glorious beacon of lightTsaktuO is a glorious beacon of lightTsaktuO is a glorious beacon of lightTsaktuO is a glorious beacon of lightTsaktuO is a glorious beacon of lightTsaktuO is a glorious beacon of light
What about using the AFS button for SWAS interrupt (at least for tech pkg guys)?
TsaktuO is offline   Reply With Quote
 Old 11-22-2011, 01:26 PM   #14
2011speed's Avatar
Posts: 1,497   (View Stats)
vdyno says im just about 300whp, and the only time i had issues with swas was when my wheel was like even 1 degree turned, or if i rip on it shortly after my wheel is turned.
Are you having these issues in third gear aswell?
FreeKtuned
fitty fitty
The Following User Says Thank You to 2011speed For This Useful Post:
 Old 11-22-2011, 01:39 PM   #15
adlpb's Avatar
Groans: 669
Yeah all my logs are 3rd gear and the issues began happening after my VD recorded >310 ish whp. If you go through a small bump when doing a log and your wheel just turns a slight bit, the SWAS will mess around with your AFR's.
Not that I use the button, but I think it would be easier to just make a bypass from the SWAS to an outer source rather than have to rewire both the SWAS and the AFS button at the same time. You would also lose functionality of the button itself. But it's a good idea nonetheless.
Last edited by adlpb; 11-22-2011 at 01:39 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-22-2011, 04:04 PM   #16
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I barely notice the "loss" of power steering if at all. I noticed it maybe once or twice and I guess now I'm used to it.
I don't think you loose ps completely either. I think the benefits, at least for me, far outweigh the cons. I'm used to the lights by now, they never really bothered me. Plus it's very easy to return to normal if you don't like it or can't deal with the lights.
The Following 3 Users Say Thank You to SLOWHATCH For This Useful Post:
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
Driver311 atp3071r 18-19psi dyno pull driver311 MazdaSpeed 3/6 - Dyno Sheets/Discussions 61 02-04-2011 08:17 AM
Stage2 +SF 93 103lver7a FMIC 19psi - 17.5 pulls mike8748 MazdaSpeed 3/6 - ECU Computer Tuning 14 07-03-2009 12:56 PM
Any prediction on time frame for a S2+SF FT FMIC 19psi map? Death-From-A-Mile
Cobb Access Port/Maps
6 07-19-2008 08:04 AM
Page generated in 0.38931 seconds with 27 queries
