 Old 04-22-2014, 07:24 PM   #1
AshFromCan's Avatar
Posts: 295   (View Stats)
AshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the world
Default Installed new parts, knock
So I put in some autotech internals and a Cobb TIP yesterday and did a fourth gear log today. I'm seeing a bit of sustained knock about halfway through the pull. I'm not sure what it means.
My mods are : Cobb TIP+SF Intake, Autotech internals, Cobb XLE BPV, Cobb OTS map on 91 Octane.
Appreciate any help.
AshFromCan is offline   Reply With Quote
 Old 04-22-2014, 07:27 PM   #2
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
cant help you without logs
nilashish is offline   Reply With Quote
 Old 04-22-2014, 07:29 PM   #3
AshFromCan's Avatar
Oh my bad. I forgot to upload them.
 Old 04-22-2014, 07:43 PM   #4
nilashish's Avatar
Check to see if you have any leaks...I am not expert but your AFRs look a little wonky...that being said the pump is holding pressure just fine...Also not sure about Manitoba gas that could also be the issue. Were you getting knock before the install?
 Old 04-22-2014, 07:46 PM   #5
AshFromCan's Avatar
No I never noticed any leaks on previous logs.
 Old 04-22-2014, 07:54 PM   #6
nilashish's Avatar
Yeah the AFRs could just be the OTS map. Ill let someone more experienced chime in...
 Old 04-22-2014, 09:50 PM   #7
btstarcher's Avatar
Posts: 4,852   (View Stats)
Does it do it all the time? If you can't replicate it, it might just be noise.
SnailTune in progress
 Old 04-23-2014, 10:10 AM   #8
El Beaner's Avatar
Posts: 4,262   (View Stats)
Did you have TCS and SWAS turned off(Genpu)?
I narrowed down some random KR like that in logs and found out it was cause I didn't turn it off(during Tuning I turned it off, but forgot when I decided to do some newer logs).
I thought it was due to bad gas, but subsequent logs I remembered to turn it off an it didn't happen again.
SOLD 2012 LSM Tech - 11/17/17
 Old 04-23-2014, 10:20 AM   #9
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
This guy.
If you can repeat it, try new gas as well. Some places just have shitty batches.
Silver 2007 Speed3 GT
 Old 04-23-2014, 10:26 AM   #10
a143gsxr's Avatar
Posts: 42   (View Stats)
a143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nice
I have seen gas fluctuate and cause this from tank to tank. I try and stick with the same or known good stations. Also i'm not certain because i don't have all my logs in front of me but your boost air intake temp looks like it climbs a bit fast and correlates to this knock. could be something to do with it as well.
a143gsxr is offline   Reply With Quote
 Old 04-23-2014, 10:34 AM   #11
AshFromCan's Avatar
I always get gas from the same place. I don't know how "good" it is but it's what I always use. I'll check all my tubes and lines, change gas stations and do some more logs and see what happens. I'll try 94 Octane with a difference map too, see what that does.
Thanks for the input.
 Old 04-25-2014, 05:25 PM   #12
AshFromCan's Avatar
I checked my work over and found the clamp holding the TIP to the turbo housing was super loose and the hose was almost coming off. Sorted that out and took some more logs. Looks like that cleared up everything. Thanks again for the help. I'll attach the logs if anyone's interested.
 Old 04-26-2014, 11:55 AM   #13
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Looks good.
Time to free up the exhaust!
AshFromCan (04-26-2014)
 Old 04-25-2014, 06:41 PM   #14
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i know this is an odd question, what is your tire pressure at?
 Old 04-26-2014, 11:27 AM   #15
it's toasted's Avatar
Posts: 114   (View Stats)
it's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud ofit's toasted has much to be proud of
in good spirit.
2011 MazdaSpeed3
|Cobb AP|Cobb RMM|
|Corksport SRI/TIP|Corksport TMIC|
|Autotech internals|FreekTuned |Rally Armor flaps|
it's toasted is offline   Reply With Quote
 Old 04-26-2014, 04:04 PM   #16
AshFromCan's Avatar
Around 35 PSI I'm guessing. Dealer was storing my wheels for me and put them on. I haven't checked the pressure. Stock wheels are tires. Why do you ask?
Originally Posted by it's toasted View Post
in good spirit.
Ok...?
 Old 04-26-2014, 04:37 PM   #17
Ok...?
he was trolling.. I got the same question yesterday. its all fun, take it in stride.
2011 MazdaSpeed3
|Cobb AP|Cobb RMM|
 Old 04-26-2014, 06:32 PM   #18
AshFromCan's Avatar
Lol ok.
Brilliant.
2013 White MS3
Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals|
Supporting |Cobb RMM| |Cobb Shift Weight|
SURE parts installed! sdiegel5 MazdaSpeed 3 - Engine, Transmission & Driveline 37 12-11-2011 05:30 PM
All new parts now installed with pics 327whp Exterior 14 04-04-2011 11:02 AM
I Finally installed RMM plus other parts... pocket aces 2010 MS3 - Engine, Transmission & Driveline 23 04-02-2010 09:53 PM
Cobb AP Installed NO Knock dallasms3gt
Cobb Access Port/Maps
12 04-06-2009 09:08 PM
Page generated in 0.37104 seconds with 29 queries
