![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score This is the one thing i couldn't find much on in my searches. I'm looking for more so specifics. Is that literally still considered partial knock and nothing to worry about, or is it a spark plug, clutch, transmission thing. Is there a deeper issue i shouldn't ignore type thing. It's only like .1 - .5 at the most but, still trying to keep this bitch as healthy as possible, usually always 1st to 2nd, 3rd and forth maybe sometimes |
Groans: 211
| Not Ranked : 0 score That's nothing to worry about. However, if you're OCD like me, then start checking motor mounts (are you upgraded?) and for anything loose in the engine bay.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
(Thread Starter) | Not Ranked : 0 score Thanks man! Yeah idk I'm OCD for knock retard that's for sure. I guess I need to relax a little. I never hear any actual knock and I read when you see 6pts while cruising its because ECU pulls timing for gas milage. Another thing I over reacted about. My paranoia stems from not having the money to afford a blown motor haha... No upgrades just a Cobb intake. So when I do my oil change just make sure the motor mounts haven't been knocked loose? |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score The only time you should be OCD about knock is at WOT. You're going to see a wide range of knock at part throttle. For instance, I would see knock as high as 7+ at part throttle and during shifting regularly. Even at WOT, .1-.5 isn't worth looking into. Knock can be caused by more than just a lose motor mount or something. Gas quality is often the culprit (if knock starts to appear out of nowhere) hence why you'll see some tuners/members ask if you can throw some corn into the tank. Any knock over 2 at WOT typically warrants some attention.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
| The Following User Says Thank You to WAMBUSHHHH! For This Useful Post: | Thor Hammer (05-14-2018) |
| Plug and play knock sensor listening harness. Is it really knock? | Turbo_Steve | MazdaSpeed 3/6 - ECU Computer Tuning | 37 | 10-07-2019 03:50 PM |
| Knock Knock Knock..Whose There? (<===total noob) | thomas_cory2000 | MazdaSpeed 3/6 - ECU Computer Tuning | 158 | 06-12-2014 11:57 PM |
| Engine knock low speeds/low gear - false knock? | Jra2011speed3 | 2010 MS3 - ECU Computer Tuning | 5 | 12-13-2013 05:17 PM |
| Knock Retard with Flat Foot Shifting | JFord | Gen2 MS3 General Discussion | 9 | 05-15-2013 01:37 PM |
| Knock while flat foot shifting with AP. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 04-19-2011 08:35 PM |
