 Old 06-18-2013, 09:40 PM   #1
bsapoznik's Avatar
Posts: 14   (View Stats)
bsapoznik is an unknown quantity at this point
Question my datalog
Hey guys I just want to make sure that my car is running good.
I did the pulled like COBB said, on 4th at about 2500rpm to redline
I flashed the stage 1 sri+tih on 93
Could anyone let me know please?
thank you
bsapoznik is offline   Reply With Quote
 Old 06-18-2013, 09:53 PM   #2
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Looks normal - you do need a MAF cal.
This is also very helpful.
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
The Following User Says Thank You to Hush For This Useful Post:
Vansquish (06-18-2013)
 Old 06-18-2013, 10:02 PM   #3
Police - Grammarhead
Vansquish's Avatar
What mods do you have? Your HPFP actual pressure is pretty high, but that's better than having it be low. In any case, it looks like you're doing alright from the quick glance that I gave your log. You've got reasonably good AFR through most of the pull, decent boost (~16.5psi), and I don't really see any other issues.
Now, what you really need is a tune by one of our e-tuners to really let the inner beast in your car fly.
If you've got aftermarket HPFP internals (and maybe a downpipe), get in touch with @Lex; @rfinkle2; @atvfreek; @Bucker; @RichieRichness; or some of their friends.
rfinkle2 (06-19-2013), RichieRichness (06-21-2013)
 Old 06-18-2013, 10:09 PM   #4
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
Add @RichieRichness; to the list of e tuners that rock. Go fast or go home.
On deck: VG Sharkfin Antenna
The Following 2 Users Say Thank You to jk_ms3 For This Useful Post:
RichieRichness (06-21-2013), Vansquish (06-18-2013)
 Old 06-18-2013, 10:37 PM   #5
bsapoznik's Avatar
I have Sure sri+tip (i know I've seen the post at the home page) and autotech fuel pump internals, im planning on getting a dp next, but dont know which one, people said to buy them on ebay, but i feel iffy about it.
 Old 06-18-2013, 10:43 PM   #6
Vansquish's Avatar
Ebay DPs are just fine. They usually have decent welds and produce immediate gains. Be mindful of the fact that if you live in a state where emissions testing is done, a DP is going to put you out of spec and you'll fail the sniffer.
 Old 06-18-2013, 10:55 PM   #7
jk_ms3's Avatar
Groans: 40
Read. I think that there's even a thread that's current called "My eBay Downpipe" or something like that. But whatever it is, there's a ton of threads about this very topic. Fwit, I know a few people who swear by the eBay dp. There's one small issue with them, easily discovered (with the fix) when you use the search button.
 Old 06-19-2013, 06:39 AM   #8
Check this document out when you get a chance. It is written by Cobb and is a good set of guidelines for their ots maps.
first datalog HELP!!!!! Javis MazdaSpeed 3/6 - ECU Computer Tuning 7 02-25-2013 02:30 PM
AP datalog backward_0 2010 MS3 - ECU Computer Tuning 9 06-18-2011 01:12 PM
My first Datalog...... MS6FL MazdaSpeed 3/6 - ECU Computer Tuning 5 05-16-2011 03:10 PM
SURE Datalog bayarea_pat MazdaSpeed 3/6 - ECU Computer Tuning 11 04-10-2011 04:52 PM
The $255.00 Datalog bergj1986 MazdaSpeed 3/6 - ECU Computer Tuning 6 12-16-2010 07:38 AM
Page generated in 0.29127 seconds with 25 queries
