 Old 11-04-2015, 06:50 PM   #1
theandrewlane's Avatar
Posts: 14   (View Stats)
theandrewlane will become famous soon enough
Default New CS HPFP - Map Confusion
Hey guys! So I just picked up a CS HPFP ($330 from my Mazda dealership for some reason) and plan on installing this weekend. I'm currently running a $50 Stratified tune (91 + CS SRI/TIP + ITV22z). I'm a tuning n00b, so please ignore my stupidity - Will my current tune be okay? Is it worth getting another $50 Stratified tune when I plan on installing a CS DP and getting a full e-tune next month?
2013 Black Mica Mazdaspeed 3 w/ Tech Package
Corksport SRI, Corksport TIP, Corksport HPFP, Denso ITV22 Plugz, Cobb AP V3, Stratified Stage 2 91 Flash Tune, Passport X70, Laser Veil G5
theandrewlane is offline   Reply With Quote
 Old 11-04-2015, 06:51 PM   #2
You can get the $25 Touch-up tune that Stratified offers.
http://www.stratifiedauto.com/index....plbus28nhiof72
sent from my Nexus 6P
theandrewlane (11-04-2015)
 Old 11-04-2015, 07:06 PM   #3
Thanks MS3Shadow! For some reason I thought that option was for OTS+ tunes only. Just purchased!
Can I expect any gains from my previous map?
 Old 11-04-2015, 07:07 PM   #4
frothy's Avatar
Posts: 1,067   (View Stats)
Your current map is fine. You don't need to alter your tune at all because of an HPFP upgrade.
If you'll be installing a DP within the next month or so and getting a full tune then anyway, I see little reason to spend money on a tune that will be used short term.
The Following 2 Users Say Thank You to frothy For This Useful Post:
Djohns (11-04-2015), MD1032 (11-04-2015)
 Old 11-04-2015, 10:23 PM   #5
lol so no gainz from a touch up tune with an added HPFP?
 Old 11-04-2015, 10:35 PM   #6
Casanova's Avatar
Posts: 108   (View Stats)
Casanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond reputeCasanova has a reputation beyond repute
Add some stickers and that'll give you 30whp easy.
2013 LSM Mazdaspeed 3
Stock
Casanova is offline   Reply With Quote
The Following User Says Thank You to Casanova For This Useful Post:
MattH (11-04-2015)
 Old 11-04-2015, 10:39 PM   #7
frothy's Avatar
Gains? Sure. Maybe. Possibly.
Upgraded HPFP internals are more of a fail safe mod than something that's gonna boost power on their own.
If I were you, seeing as you've already spent the cash, i'd have Stratified supply you with a tune that incorporates the downpipe you plan on adding in a month.
You'll see more noticeable gains with that map and you'll have an alternative to the E85 map, should you ever want/need it.
 Old 11-05-2015, 12:01 PM   #8
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
I am under the assumption that the gains from upgraded internals comes from the ability to run more than 15/16psi of boost, without fear of the fueling not being able to keep up.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
RMM confusion sharkyboost Gen2 MS3 General Discussion 104 07-22-2015 06:07 PM
Maf cal Confusion neil123456 MazdaSpeed 3/6 - ECU Computer Tuning 3 07-25-2013 12:39 AM
Confusion about map descriptions... JDMJOSH
Cobb Access Port/Maps
0 02-09-2013 10:20 PM
MAF Cal confusion omgheyitskenny MazdaSpeed 3/6 - ECU Computer Tuning 12 05-01-2012 01:38 PM
Page generated in 0.30995 seconds with 24 queries
