Like Tree9Likes
  • 1 Post By G26
  • 2 Post By G26
  • 1 Post By rfinkle2
  • 2 Post By G26
  • 1 Post By adlpb
  • 1 Post By rghispanic88
  • 1 Post By G26
 Old 11-13-2011, 05:56 PM   #1
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Default New logs, stage 2 autotechs installed today.
Heres some logs and graphs of my custom stage 2 tune by me. Installed autotechs and itv-22's today with the help of
@adlpb
@speeed
@rghispanic88
@rfinkle2
Targeting 19psi from 3000-4500rpm, 18.5psi at 5000rpm, 18psi from 5500rpm up. AFR commanded is 11.850. Timing is stage 2 IC upgrade ots.
I am purely boost tuned, i set my car to ignore all load targets.
1st log is 3rd gear, 2nd is 2nd gear, 3rd is 3rd gear.
Bucker likes this.
The Following 2 Users Say Thank You to G26 For This Useful Post:
adlpb (11-14-2011), rfinkle2 (11-14-2011)
 Old 11-13-2011, 06:09 PM   #2
G26
G26's Avatar
Groans: 39
Heres some graphs corresponding to those logs. Red is boost psi, blue is afr.
Just checked my virt dyno #'s.
Same mods pre fp internals/plugs running 16psi, 260hp/295trq.
Now, 289hp, 321trq.
Abysal and rghispanic88 like this.
The Following User Says Thank You to G26 For This Useful Post:
ruthless013 (11-14-2011)
 Old 11-13-2011, 09:15 PM   #3
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
Now, 289hp, 321trq.
your fuel pressure is too high. LOL, you might have left your internals in oil for too long.
Logs look good
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 11-14-2011, 04:00 AM   #4
G26
G26's Avatar
Groans: 39
Logs look good
lol, nice runs last night. It seems you were getting me on the shift, were you ffs?
 Old 11-14-2011, 04:34 AM   #5
As always, logs look great.
Now that you have internals, I think you will really start enjoying the car more @ higher boost levels.
rghispanic88 (11-14-2011)
 Old 11-14-2011, 07:57 AM   #6
Groans: 263
Yes, i was. LOL
but as of right now, you should have been able to keep up if not beat me. i got some kind of issue which im still trying to figure out
2010 Black Mica
 Old 11-14-2011, 08:22 AM   #7
Yes, i was. LOL
What is that RG, a new issue or a possible leak?
 Old 11-14-2011, 09:07 AM   #8
Groans: 263
Sorry for the thread jack G26
Well you told me i might have a possible hardware issue but i havent been able to find anything.
I took off the intercooler, SRI, TIP and checked them but still nothing.
Remember when i sent you that message about the CEL codes i was getting.
P0137- o2 sensor low voltage sensor #2
P0139- o2 sensor slow response sensor #2
P2096- target A/F feedback system too lean
Im beginning to think that it might be my DP, since its giving me the CEL code that a lot of people had issues with. My DP has an extended O2 bung on the lower sensor, so im gonna have a shop weld in another O2 bung close to that one so that the sensor is in the exhaust stream.
2010 Black Mica
 Old 11-14-2011, 09:35 AM   #9
OK Great . LMK when you get things all set hard ware wise.
 Old 11-14-2011, 11:23 AM   #10
Groans: 263
Yeah, I will
2010 Black Mica
 Old 11-14-2011, 11:26 AM   #11
Yeah, I will
Maybe G26 would like to add to your thread when you get things straightened out and we can all collaborate.
rghispanic88 likes this.
 Old 11-14-2011, 12:20 PM   #12
G26
G26's Avatar
Groans: 39
Yes, i was. LOL
I was keeping up, I don't have ffs on, thats where you started to pull away, otherwise you were barely inching away from me. Also, your 2nd o2 sensor shouldn't be affecting performance at all. That is strictly for checking if the cat is in place.
I'm going to flash a new map with some wgdc tweaks after i drive a little more to settle my fuel trims (which are still pretty good at +/- 2 lol, and then I will start messing with timing, since I'm running ots timing tables.
Sure.
Some observations from my 40 mile commute this morning.
The engine runs somewhat smoother, probably due to the new plugs.
Also, no extra noise from the fuel pump, sounds exactly like stock.
You can also see from my graphs, boost is very stable and consistent 2 port all the way @rfinkle2 lol.
rghispanic88 and rfinkle2 like this.
Last edited by G26; 11-14-2011 at 12:26 PM. Reason: MSF Database - Automerged Doublepost
rfinkle2 (11-14-2011), rghispanic88 (11-14-2011)
 Old 11-14-2011, 02:52 PM   #13
Groans: 263
Wrong my friend. according to this thread
here is what was found
Cruising, or closed loop AFR's, and the especially trims are affected by the narrow band O2 sensor. The reason these guys were having such a problem was because the 2nd O2 sensor would never properly heat up, so, in turn the ecu kept pushing more fuel to try and heat up the high flow, or non-existent cat, this is one of the reasons the idle and cruising AFR were always so rich, and why they were also reporting terrible gas mileage.
the rear o2 is also responsible for keeping your afr's right and fuel trims...your mpg is prob a lot worse right now, and fuel trims are way off from running super rich.
Check Engine Light (P2098)
The second O2 which came faulty in CP-e and UR DPs would throw a CEL code which could be fixed by adding an O2 bung that would place the O2 sensor closer to the exhaust stream and heat up properly.
For sure, we both live about 20 mins from each other and could help each other out.
2010 Black Mica
Last edited by rghispanic88; 11-14-2011 at 02:52 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 11-14-2011, 06:03 PM   #14
G26
G26's Avatar
Groans: 39
Virt dyno corresponding to Datalog 1, don't know what happened with my peak hp dropping off around 5k rpm.
@rghispanic88
@rfinkle2
rfinkle2 (11-15-2011), rghispanic88 (11-14-2011)
 Old 11-14-2011, 06:13 PM   #15
Groans: 263
very nice
2010 Black Mica
 Old 11-14-2011, 06:14 PM   #16
G26
G26's Avatar
Groans: 39
very nice
Ty, once I start messing with timing, hopefully I can get some more up top.
 Old 11-14-2011, 07:02 PM   #17
Groans: 263
oh yeah, that will make a big difference
2010 Black Mica
The Following 2 Users Say Thank You to rghispanic88 For This Useful Post:
harryclay (11-16-2011), rfinkle2 (11-15-2011)
 Old 11-15-2011, 03:35 AM   #18
You guys are dead on concerning the timing.
Unfortunately, there is not a whole lot left in our motor with the k04 after 5000 rpms.
 Old 11-15-2011, 07:04 AM   #19
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
@G26 your logs look great man, glad I could help out with the installation.
@rghispanic88 All your problems started when you touched those internals with your bare hands. You cursed your MS3 brah.
 Old 11-15-2011, 02:43 PM   #20
Groans: 263
LOL. no it was after. the last thing i changed was the BOV and now i have a forge and still got the same results.
i also had a couple of CELs due to the catless DP but i fixed it today by welding another O2 bung.
i just took some logs and i still got the same results.
2010 Black Mica
 Old 11-15-2011, 03:16 PM   #21
G26
G26's Avatar
Groans: 39
So, is having a catless dp bad?
 Old 11-15-2011, 04:36 PM   #22
Groans: 263
No, its not bad
2010 Black Mica
 Old 11-15-2011, 06:44 PM   #23
G26
G26's Avatar
Groans: 39
New Logs.
Have about 200 miles on the new internals, and they are running great. Holding 1750-1900psi, commanding 1749psi. 400-430psi at idle.
Made a few small wgdc tweaks and boost error tweaks since the last logs. Also increased timing by 1* up top.
@rghispanic88
@rfinkle2
@adlpb
DL4 is 3rd gear, dl5 is 2nd.
rghispanic88 (11-15-2011)
 Old 11-15-2011, 07:04 PM   #24
adlpb's Avatar
Groans: 669
New Logs.
Looking pretty good. Your AFR's are crazy steady
SLOWHATCH (11-15-2011)
 Old 11-15-2011, 07:11 PM   #25
Groans: 263
looks good.
perhaps you can increase timing a bit more.
try doing 4th gear logs. do it on the way to work. i do it on my way to school and i always have fun and get there early.
2010 Black Mica
rfinkle2 (11-16-2011)
 Old 11-15-2011, 07:28 PM   #26
G26
G26's Avatar
Groans: 39
Hah hell yeah they are, along with boost.
looks good.
Yeah, I'm going to increase timing a little more. I might do some 4th gear logs soon.
Last edited by G26; 11-15-2011 at 07:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-15-2011, 07:46 PM   #27
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I second adlpb. Afr's are definitely steady as can be, keep up the good work.
 Old 11-16-2011, 05:02 AM   #28
Meticulous, as always.
Doesn't get any better than that.
 Old 11-17-2011, 06:32 PM   #29
G26
G26's Avatar
Groans: 39
Switched all my values over to a new v210 map. Heres 2 3rd gear logs for ur pleasure.
One weird thing I noticed on log 6, is that when i hit max load (2.2), fuel psi holds right at 1750 for a few cells, then as my load comes down a little, it shoots it back up to 1800-1900psi.
Also, it doesn't seem to be following my timing table. Seems my car doesn't like to pay attention to what I tell it to do.
@rfinkle2
 Old 11-18-2011, 05:09 AM   #30
@rfinkle2
Pump pressures vary pretty widely, usually about + / - 100 psi (sometimes more).
@G26 As for not following the tables, the ecu interpolates between cells, so if you have a 1* in the 2 load / 3000 rpm column, and 3* in the 2load 3500 rpm column, the ecu will pass through (i.e. use) 2*.
If you are getting kr @ 3250 rpms, 2.0 load, you will probably need to back timing off @ 3500 rpms, because the ecu is trying to get to your 3500 rpm timing target, and passing through spark advance that is too far advanced in order to get there.
 Old 11-18-2011, 07:29 AM   #31
G26
G26's Avatar
Groans: 39
Hmm the timing is ots, and in the table it is like +2-4 around where I'm getting the KR, should I make it closer to what I am logging?
 Old 11-18-2011, 07:33 AM   #32
My post above was not specific to your tune.
How far off is the timing you are running vs. what you see in the tables?
Did some new logs today. Something looks off. cyber-ms3 MazdaSpeed 3/6 - ECU Computer Tuning 19 10-24-2011 12:35 PM
Autotechs installed EvilMonkey 2010 MS3 - Engine, Transmission & Driveline 0 06-12-2011 10:21 AM
New Logs since going stage 2 bwspeed MazdaSpeed 3/6 - ECU Computer Tuning 4 06-10-2011 11:45 AM
First Stage 2+ logs Todd98SE 2010 MS3 - ECU Computer Tuning 29 04-20-2011 02:32 PM
First stage 1 logs, now stage 2?? Instrument_Guy 2010 MS3 - ECU Computer Tuning 11 04-20-2011 11:03 AM
Page generated in 0.52594 seconds with 25 queries
