  • 1 Post By dsmguy
 Old 08-10-2014, 03:22 PM   #1
TheProYodler's Avatar
Posts: 117   (View Stats)
TheProYodler is a splendid one to beholdTheProYodler is a splendid one to beholdTheProYodler is a splendid one to beholdTheProYodler is a splendid one to beholdTheProYodler is a splendid one to beholdTheProYodler is a splendid one to beholdTheProYodler is a splendid one to behold
Default Not hitting my target boost
Alright, here's my problem: I'm running a stage 1 corksport/tih with the stock cdfp, but I'm not hitting my target boost (I'm on the latest firmware, and latest version of the map.) I usually max out at 14.5psi rarely, and hold at 12-13. I'm extremely new to tuning so I really have no idea what's going on, but I've done some looking around the forums, and if I have learned anything it's that I can use ATR to do stuff. Yeah!
I really want to peak boost at around 16.5-17psi, and hold at 1-2psi under that. Since 14.5psi is 12.1% off of 16.5, could I use ATR to raise the waste gate duty cycle by 12%? I can do a wide open throttle log if needed (3rd/rth gear.) I feel like I can just keep doing trial and error until I get the correct boost cycle that I want, thoughts?
This is my first post, so be gentle. I'm not ready for complete destruction yet.
EDIT: It is decently warm outside (mid 80's-low 90's) Elevation is roughly 300 feet.
Alright, I've posted my logs down below for everyone to take a look at.
TheProYodler is offline   Reply With Quote
 Old 08-10-2014, 03:31 PM   #2
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
I don't know much (ie. hardly anything) about tuning with ATR. But, if you don't know that increasing wastegate functions to increase boost (other variables held constant), I wouldn't do anything with ATR. That software is pretty complex, it's like trying to use Photoshop when your experience with photo editing is limited to messing with brightness and contrast settings. You're going to hear this from multiple people, but having your car professionally tuned is singlehandedly the best money you'll spend on it. I'd recommend either having someone e-tune the car, or spend a few weeks reading the tuning how-to guides before making tiny incremental baby steps to see how your changes affect the car.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 08-10-2014, 03:44 PM   #3
Oh, no I get how tuning itself works (for the most part, I am short on terminology and what does what), I'm just new to it. The software looks pretty daunting, but nothing some internet/youtube guides can't fix. As for a pro tune, how much do those usually cost?
Edit: I would go to CP-E to have them tune the car since they're located just outside of DC.
 Old 08-10-2014, 06:48 PM   #4
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
Search the forum for how to run a proper 3rd and 4th gear log and which parameters to monitor. Post the logs. No one will help you without logs.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 08-10-2014, 09:26 PM   #5
Posted my logs up on my first post.
 Old 08-10-2014, 11:12 PM   #6
alexryan's Avatar
Posts: 642   (View Stats)
alexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the worldalexryan is the leader of the world
Theres a few problems:
1. Dont go wot before 2700, please. Its really a big no no with this motor. Some may argue its fine, but i still dont trust it.
2. Your "increasing WGDC by 12% because boost is off by 12%" idea is not correct. WGDC does not have a 1:1 relationship with boost. Its more of a trial and error kind of thing. After you do it a few times, youll get the idea.
3. You most likely have a boost leak. Just double check your clamps and do a boost leak test. If all is well, go ahead and increase duty cycle by 5% and see where that puts you.
//2012 Black Mica Mazdaspeed 3//
//Sure Torq R3//Cobb AccessPort//Autotech Internals//Ultimate Racing Axelback//Resonator Delete//Ebay Catless DownPipe
//TR8L & Protege Garage piping//Devils Own Stage 1//NGK One Step Colder(failed) Denso ITV22//GoFastBits Blow Off Valve//Ksport Coilovers
//GTX 2867r//Protege Garage Externally Gated Manifold//Precision Turbo Wastegate//Bosh 3 Bar Map//HTP 3.5" Full Intake
//Grimmspeed 3 Port//Cobb Wastegate Lockout//Selfmade Screamer Pipe//ACT 6 puck w/ streetlite flywheel
// R3X Tune in Progress (self tune) 310whp 354wtq (CF 1.01) w. DO7 KO4
......GTX2867r 22psi: 357whp 353wtq (CF1.01)
Needs installing: JBR BSD kit, OCC
alexryan is offline   Reply With Quote
The Following User Says Thank You to alexryan For This Useful Post:
TheProYodler (08-11-2014)
 Old 08-11-2014, 12:36 AM   #7
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
What do you mean holding 12-13? You are holding 15 PSI +- .5 perfectly fine. I don't know the boost targets for that particular map, but I believe Stage 1 OTS call for 16.5 +- 1.5 PSI, so you are golden in that aspect.
Also, please upgrade your fuel pump before you attempt to run more boost. Some cells under HPFP Act. Pressure are in the low 1600's already, it will only go down once you up the boost. It's cheap insurance so get it.
The Following User Says Thank You to ArmanRus For This Useful Post:
 Old 08-11-2014, 06:32 AM   #8
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
I wouldn't trust it with an OTS tune that has 100% WGDC down low. With a tune you can limit the torque, so even in the off chance, you have too many drinks at the bar and need someone else to drive your car home and they feel like pinning it from 1k you'll be fine.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following User Says Thank You to chaser27 For This Useful Post:
 Old 08-11-2014, 07:51 AM   #9
Thanks for the replies everyone! Really helpful. An Autotech HPFP is on the list as my next mod, but being a college student I'm broke. Basically have enough money to pay for gas, insurance, and repairs. I checked to see if there were any leaks, but there didn't appear to be any (I just went around tightening bolts and checking joints--I'm too poor to afford a compressor to pressurize my system, so I'm hoping I got a leak closed if there was one.)
Down below I've attached the current WGDC table for my map.
So I should look at my logs to see when I'm making max boost, and then multiply those cells in ATR by a factor of 1.05, right?
Edit: I should note at this point, is adding 1.5-2psi max boost really going to make that much of a difference in power? Oh and while I'm doing this should I also do a WOT MAF CAL since I already have the log? I'm thinking I should aim for 11.6 air to fuel.
 Old 08-11-2014, 08:47 AM   #10
ArmanRus's Avatar
Groans: 42
No, ypu don't multiply by 1.05. You add 5% so that 40% will be 45%. Do those in the RPMs that you are not hitting your target boost.
 Old 08-11-2014, 08:57 AM   #11
Ah ok, so you're adding not multiplying, thanks for that.
 Old 08-11-2014, 09:04 AM   #12
chaser27's Avatar
Groans: 42
See replies in red.
Originally Posted by TheProYodler View Post
I'm too broke... yada yada yada
A new engine cost a lot more than $350 HPFP internals
Your WGDC map is one of the many reasons I don't like the OTS maps. If you know how a waste gate actuator and EBCS work, you would understand this. Spring pressure alone is going to get you to ~9 psi IIRC on the K04. It isn't a direct 1:1 thing like AFR calculations or something.
It could, depending on rpm, compressor efficiency, etc. More airflow, more fuel being burnt. Use spark advance, vvt, AFT, etc. to optimize how that fuel is being used. I'm getting the feeling you should NOT be doing this yourself until you've read a lot more. Not trying to be a dick, just trying to make sure you don't blow something up
Get your MAF set up BEFORE trying to push for power.
This is a normal target for our cars.
ECU: self-tuned
 Old 08-11-2014, 09:18 AM   #13
Originally Posted by chaser27 View Post
See replies in red.
Thanks for this. I'm not planning on racing my car, so if I'm not going to 'feel' the power difference, then I don't really care about doing it. I have a tendency to just "chase numbers."
 Old 08-11-2014, 09:53 AM   #14
UPDATE: So I increased my WGDC by 5 (in the cells where I should be producing max boost.) I'm now making 16.3-16.5 max psi and holding in the 15 psi range. I did two more 4th gear logs and I'll post them below.
 Old 08-11-2014, 10:26 AM   #15
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You really should get internals ASAP if you are going to continue to try and push your car harder... Quite a few HPFP cells <1650, and 1 below 1600. You may be "broke" now, but you still have a car. Don't get internals, and you might not have a working car much longer either.
Not getting an upgraded part because you won't "feel" the difference is fucking dumb. You'll feel the difference when you blow your engine.
 Old 08-11-2014, 10:42 AM   #16
Go back and re-read all of my posts. I already want new HPFP internals. Infact, they will be my next mod. Also, I said that if I'm not going to notice the difference of 1-3psi, then why do it if I'm going to risk my internals? I never said anything about not wanting to get a fuel pump.
 Old 08-11-2014, 11:29 AM   #17
chaser27's Avatar
Groans: 42
Yes, but you should get internals BEFORE you start pushing more boost. More boost -> more air -> more fuel. Honestly I haven't looked at any of your logs, because there are too many damn people posting shit like this, but if you are already dropping FP, the last thing you should do is increase boost psi.
ECU: self-tuned
 Old 08-11-2014, 11:34 AM   #18
Yeah, it's a calculated risk I'm taking. No, I don't want to blow out my fuel pump. I'm only trying to boost up to what the stage 1 map was designed to deliver (16.5psi +/-1.5psi.) If I were to buy the Autotech fuel pump internals, would it be worth paying a shop to install it for me (called in for a price and they said $225 for labor?) I only ask this because the install does look pretty difficult, and messing it up would be pretty disastrous.
 Old 08-11-2014, 11:53 AM   #19
chaser27's Avatar
Groans: 42
You should double check those calculations... $350 vs $6k. I had fuel pressure dropping with just an intake and a slightly aggressive tune.
ECU: self-tuned
 Old 08-11-2014, 12:00 PM   #20
dsmguy's Avatar
Posts: 38   (View Stats)
dsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud ofdsmguy has much to be proud of
You're not going to "blow out your fuel pump." You're going to "blow out your motor." People are only being harsh because there are always people on here zoom zoom boomin, and they don't want to see you be one of them.
dsmguy is offline   Reply With Quote
 Old 08-11-2014, 12:06 PM   #21
You know what, fuck it... I can live without a TV in my dorm. I'm buying these internals.
The Following 3 Users Say Thank You to TheProYodler For This Useful Post:
chaser27 (08-11-2014), it's toasted (08-12-2014), kolosok17 (08-11-2014)
 Old 08-11-2014, 01:00 PM   #22
chaser27's Avatar
Groans: 42
Not sure where you are from, but get with your local Nator. Meet some cool people, hang out and I'm sure they can help you out with any questions you have in that install. Save more moniez.
ECU: self-tuned
 Old 08-11-2014, 01:16 PM   #23
dsmguy's Avatar
That's the spirit! You'll enjoy boost more than Teen Mom, I promise.
Ozynigma likes this.
The Following User Says Thank You to dsmguy For This Useful Post:
 Old 08-11-2014, 02:26 PM   #24
UPDATE: Autotech HPFP internals have been ordered.
The Following 4 Users Say Thank You to TheProYodler For This Useful Post:
ArmanRus (08-11-2014), chaser27 (08-11-2014), it's toasted (08-12-2014), Snip (08-11-2014)
 Old 08-11-2014, 08:31 PM   #25
chaser27's Avatar
Groans: 42
I feel like I did my good deed for the day.
ECU: self-tuned
 Old 08-11-2014, 08:47 PM   #26
ArmanRus's Avatar
Groans: 42
You should have donated $25 and then bought the brand new ones in the for sale section for $300. Two birds with one stone.
Now you can run 20 PSI. That will definitely make a difference.
 Old 08-11-2014, 09:02 PM   #27
Emew's Avatar
Posts: 217   (View Stats)
Btw the support you're getting right now is unbelievable. I took the long hard route of learning thanks to some gurus here or there and with a lot of recommendations. The nature of this forum is to rape your butthole, call you a brownie, get their dick more brown, and then leave the thread. The fact you're getting all this support with no backlash and hate is astonishing.
Listen to what they've said as a lot of them are dead on correct and as stated before, avoid increasing boost beyond OTS stage 1 until you get those internals installed. If you view the pre-reqs Cobb lists with the various maps you'll see that stage 2 comes with a 17.5 PSI target tapering to 16.5 and has a requirement of HPFP(CDFP) internals for the map. I know you're eager to make power but as others have stated, knowledge is key here, you should feel as though you're risking your motor with every uncertain change you make in ATR.
Flow Student
The Following 2 Users Say Thank You to Emew For This Useful Post:
chaser27 (08-12-2014), Snip (08-12-2014)
Not hitting boost target (~10-11psi) yangx405 2010 MS3 - Turbo Induction 8 08-08-2014 08:05 PM
Not hitting target Boost. PLZ HELP mgramata MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-22-2014 09:01 PM
Not hitting target boost btrend MazdaSpeed 3/6 - Troubleshoot/Diagnostics 34 04-14-2013 09:28 PM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
AP stage 2 not hitting target psi and stuttering in 4th balkanbase MazdaSpeed 3/6 - ECU Computer Tuning 7 12-06-2010 01:50 PM
Page generated in 0.47044 seconds with 29 queries
