![]() Join Date: Jan 2012 Location: Deptford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 87
(Thread Starter) | Not Ranked : 0 score If the logs check out ok and I go ahead and order a boost leak tester, where should it be attached. I've heard some people say right at the top of the TIP (right where the intake would connect)- other say right at the turbo compressor. If I do have to order (or make one) I want to make sure I have the right size as the turbo and opposite side of the tip are different sizes. Thanks in advance everyone! PS All the logs were 4th gear pulls, at sea level, approximately 72 degrees out.
__________________ 2012 Cadilac CTS-V coupe 2014 Corvette Stingray |
![]() Join Date: Nov 2010 Location: Portsmouth, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,341
| Not Ranked : 0 score This is with a Stage 2 OTS map? I suspect you're hitting your load limits, which is the reason you're not seeing 18psi. You can see your throttle plate closing to stay under the requested load. You can learn how to raise the load limits in ATR to reach desired boost, or have one of the e-tune guys do it for you. I don't think you have a boost leak. -good luck
__________________ 2010 Mazdaspeed 3 | Black Mica COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs |
| The Following User Says Thank You to speed14 For This Useful Post: | Bubba Ho-Tep (04-23-2012) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 53 Times in 27 Posts
| Not Ranked : 0 score Increase your WGDC 500 rpms before the area where you see your boost not reaching the boost targets. For amount of increase, try calculating a % based on the boost your getting vs target boost. For example, @ 3000 rpm, lets say you're getting 14 psi, and you're targeting 18 psi, (1- (14/18))*100 = 22%, so increase WGDC by 22% @ 2500 rpms. To be more conservative, you might want to try 1/2 that so 11% to see if your car is adjusting how it should. If anyone disagrees with my method, please correct me. IMPORTANT: You should also be going WOT @ ~ 2500 RPMS till 6500 rpms. Don't adjust your map until you post a proper WOT log or 2. If you adjust your map based on your current logs, there could be issues.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid |
| The Following 2 Users Say Thank You to WillyH For This Useful Post: | Bubba Ho-Tep (04-23-2012), fortressofcomfort (04-23-2012) |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
| Not Ranked : 0 score OP - was your DSC and AC turned off?
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
| The Following User Says Thank You to bigriver For This Useful Post: | Bubba Ho-Tep (04-23-2012) |
![]() I'm going to install a Cobb TIP soon and reflash with the Stage2 (w/ tip) as the Tip I had previously (from another company) wasn't molded properly. The fitment wasn't even close. I'll most definitely have to get an e-tune/protune. Btw, if I WERE to check for a boost leak should I be connecting the tester to the tip or the turbo itself? Also should I pressurize the system to around the same PSI the tune is asking for 18-19psi or more?
My hats are off to you guys- this stuff is so perplexing to me. I absolutely love cars but apparently am quite a newb when it comes to anything more technical than basic hardware installs. Yes and yes sir! Thanks!
__________________ 2012 Cadilac CTS-V coupe 2014 Corvette Stingray | ||
| Not Ranked : 0 score This may help and save you some monies. comprehensive tuning link list "If I understand correctly you are talking about using the ATR software to increase the Wastegate Duty Cycle to allow the turbo to produce more boost?" Yes, more boost to hit boost targets.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid Last edited by WillyH; 04-23-2012 at 11:53 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to WillyH For This Useful Post: | Bubba Ho-Tep (04-23-2012) |
| Not Ranked : 0 score I think the Cobb tuning notes say there is a boost target error factor of +/- 1.5 psi with the ots maps.
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score For starters, you should start logging @ 2800-3000 RPMs. You're cheating yourself out of 1k RPMs for the turbo to spool. Take some logs starting there and see where you're at. You may just have to make small tweaks to the WGDC tables or the TRL by gear tables.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | Bubba Ho-Tep (04-23-2012) |
| Not Ranked : 0 score Just putting this out there, but if you're already hitting your load targets, there's no amount of WGDC you can add that will increase your boost. The only thing that will happen if you continue to raise WGDC on this map is when you go WOT, you will see a spike above the requested load on spool-up since the ECU uses the WGDC tables and ramp limits as a starting point, then LEC will kick in as you exceed your load targets and cut WGDC to bring you back to meet your requested load targets. If you wan't some proof, i looked at the 4th gear load targets for a stage 2 map and your logs are dead on with the requested loads. In summary, all this means is your car does not need to hit 18psi to meet the load targets of a stage 2 OTS map. Time to get tuning!
| The Following 3 Users Say Thank You to speed14 For This Useful Post: |
Btw, I requested my link for ATR and got an email only a few hours later. I went to install it but quickly realized it's ONLY for Windows. Their AP Manager software is PC or Mac compatible but not the ATR unfortunately.
__________________ 2012 Cadilac CTS-V coupe 2014 Corvette Stingray | ||||
For the record, on stage 1, I was able to go up to 21 psi. If he is boost tuning, and the load tables are zeroed out, i dont think load has anything to do with boost. Correct me if im wrong.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid | |
| The Following 2 Users Say Thank You to WillyH For This Useful Post: | SofaKingAwesome (04-25-2012), TheProYodler (01-20-2016) |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| Not Ranked : 0 score Well if he cant get ATR loaded then he cant do shit to his map. And wont be able to get e-tuned either. First course of business would be to get ATR on some kind of computer and then you can start adjusting. Pretty sure he isnt leaking, wouldnt his wgdc start freaking out and wouldnt his boost go up and down? It def looks like he's hitting his load limit. Which is pretty simple to work around. I would do that first before working wgdc's. He'll end up raising them then doing the load then over shoot his target. |
| The Following 2 Users Say Thank You to dantes5823 For This Useful Post: | fortressofcomfort (04-26-2012), speed14 (04-25-2012) |
Even having my load dynamics tables zeroed out, my car was still limited by the TRLxgear tables, as i believe is the same thing happening to the OP. really think it depends on the ECU as some cars do not have this problem. Only after i raised the TRLxgear values to unachievable levels (ie 2.5 or higher) i was able to reach my boost targets and make adjustments by simply raising/loweing WGDC.
__________________ 2010 Mazdaspeed 3 | Black Mica COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs | |
| The Following 2 Users Say Thank You to speed14 For This Useful Post: | SofaKingAwesome (04-25-2012), WillyH (04-25-2012) |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
Groaned at 20 Times in 12 Posts
| Not Ranked : 0 score Make sure all the Throttle Requested Load - x gear tables (look in Throttle area of ATR)are set to something like 2.5 from 2500rpms and up Also make sure your Load Error Comp table under Wastegate Dynamics is all zeros. Like Dantes5823 said, if you don't have ATR then you are SOL now and down the road when you WILL want to get an etune. The OTS maps are merely starting points for REALLY getting your car running good (the difference, for me, from going from a stage 1 Cobb map to my own eTune with help from lots of great guys see sig was 12whp and 67lb/ft at the wheels; sounds funny but its easy to make torque increases on these cars and much harder to make peak hp increases because K04). Try running nearly 106mph in the 1/4 mile with an intake and OTS Stage 1 tune lol. Remember, Cobb has to take into account the worst running car possible when they release a map, otherwise lawsuit or at least dissatisfied customers and loss of sales. I just realized in my sig that I've had help from SEVERAL different tuning teams. This is great. Not only do I benefit from the collective knowledge and argument between teams, but they can all learn something, maybe sometimes a little thing, because they are all tuning the same exact car. Win/Win.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
(Thread Starter) | Not Ranked : 0 score I just wanted to take the time to thank you all for the input. I really appreciate it. I've decided to schedule a pro tune at at local Cobb certified pro-tune shop. I'm sure the legendary e-tuners are amazing but I'd rather do the pulls on a dyno. Doing the few hwy pulls I've done so far ranked really high on the pucker factor with the chance of an officer hiding around every corner. I'll document my experience; fyi I'm using RT Tuning in Lansdale, PA. Probably purchase and have the new Cobb cat-back installed the same day.
Groans: 890
Sent from my PG86100 using Tapatalk 2
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/not-hitting-stage-2-boost-targets-boost-111639/ | ||||
| Not hitting targets | This thread | Refback | 06-08-2013 12:17 AM | |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| not hitting boost targets | exentix | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 04-13-2012 05:57 PM |
| Not hitting boost targets | jvella22 | Mazdaspeed3/6 General Discussion | 2 | 04-08-2012 08:26 PM |
| OTS Map Not Hitting Boost Targets | kahunab14 | MazdaSpeed 3/6 - ECU Computer Tuning | 53 | 02-18-2012 10:30 AM |
| Not hitting boost targets again (AP).. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 28 | 08-01-2011 05:35 PM |
