![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
(Thread Starter) | Neutral : +1 score The reason i created these OTS maps for those at high altitude is 90% of the time the standard cobb ots maps wont come close to reaching boost targets, and run very high timing resulting in KR. I wouldn't suggest running these maps without being over at least 3000FT above sea level. I have two maps, a stage 1 map and a stage 2 map. The stage one map is for a stock HPFP and the stage 2 maps are for upgraded HPFP's. You mods will depend if you run on the low end of the boost targets or the high end. I don't have all of them done. but here is the first handful. these ones are done because of who helped me work on them. I will keep adding more maps as i have time, but this is how you install them onto your car. 1: You need to request and download Access Tuner Race from this link: Accesstuner Race Request Form 2: Download the appropriate map listed below 3: Open the map in ATR on your PC 4: Go to file --> Save Map 5: Upload the newly re-saved map to your accessport via Accessport Manager 6: Flash to your car DISCLAIMER: Downloading and using these maps are AT YOUR OWN RISK. Neither MSF or I will not be held accountable if anything were to happen to your car after installing one of these maps. Listed below the maps have the stage 1 or 2 listed along with the type of intake they are meant for in the name. If you have any questions about which map you should run or just about the maps in general post here and mention me.
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 Last edited by Raider; 12-16-2015 at 06:40 AM. |
| The Following 24 Users Say Thank You to snailD For This Useful Post: | 802MS3 (10-26-2014), Agent_Orange (10-18-2014), ArcticSpeed3 (10-26-2014), ArmanRus (10-21-2014), Biobandit (12-31-2015), breakfstincluded (10-18-2014), Cevaes_64 (10-20-2014), cfbisel (12-15-2015), Cheapspeed (10-24-2014), CosmicArkie (11-06-2014), Easter Bunny (10-18-2014), Jeremy M (10-20-2014), JgamB (10-24-2014), MBalik (10-18-2014), memin (10-25-2014), Micha (10-25-2014), ms6mil (10-20-2014), Snyeed (10-26-2014), speed23 (10-18-2014), Tacheny (11-23-2014), Yatta (10-21-2014), yukaia (10-26-2014), Zdraveca (04-14-2015), [R]usty (10-24-2014) |
(Thread Starter) | Not Ranked : 0 score Saved for more maps... DISCLAIMER: Downloading and using these maps are AT YOUR OWN RISK. Neither MSF or I will not be held accountable if anything were to happen to your car after installing one of these maps.
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 Last edited by snailD; 04-25-2017 at 11:47 PM. |
| The Following 7 Users Say Thank You to snailD For This Useful Post: | Biobandit (12-31-2015), Easter Bunny (10-18-2014), Jeremy M (10-20-2014), Micha (10-25-2014), Snyeed (10-26-2014), Tacheny (12-16-2015), warjunkies (06-24-2015) |
![]() Join Date: Jul 2014 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score What do you have boost targets set at?! And you should make a economy map for us built guys who aren't stock and can't run the stock eco map! |
| Not Ranked : 0 score Very nice of you to go through all of this trouble.
| The Following 5 Users Say Thank You to Easter Bunny For This Useful Post: | 802MS3 (10-26-2014), Agent_Orange (10-18-2014), Cevaes_64 (10-20-2014), chaser27 (12-08-2014), snailD (10-18-2014) |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| The Following 2 Users Say Thank You to Agent_Orange For This Useful Post: | Easter Bunny (10-18-2014), snailD (10-18-2014) |
you are already tuned, just keep your foot out of it! lol. i could make an extreme eco map, idk we will see. as of now all the info to make an eco map is in the thread gas mileage tuning. no worries man its all about helping when i can. this place has done a lot for me
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | ||
| The Following 3 Users Say Thank You to snailD For This Useful Post: |
![]() Join Date: Jun 2014 Location: Logan, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Will you be posting 2010 maps for cobb intake? Or would it be fine to run the 2011+ map?
__________________ 2010 Mazda Speed3- Mods: Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell Next up: tune. |
(Thread Starter) | Not Ranked : 0 score stay posted, it wont work on a 2010. check back often for updates
| The Following User Says Thank You to snailD For This Useful Post: | Easter Bunny (10-18-2014) |
![]() Join Date: Nov 2010 Location: Breckenridge CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| Not Ranked : 0 score yea i live at 10000 ft and run stock map but want to install the archived CPE CAI map.... is there any chance u would want to do a write up on what is required to adapt the car to this high altitude, I have an AP and looking through all the maps the Baro pressure sensor seems to have no impact, and the graph is a straight line.... what tables would u suggest copying from ur map to the one with the MAF calibrated for my intake? sorry if I ask too much but winter is coming and I would like to not see my trims always be 16+ LTFT and 4-10- STFT just boucing around like crazy
__________________ Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray! Cpe: FMIC, CAI, TIP, HPFP, bone engine mount Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar Turbine Tech: Extra front motor mount, both diff mounts +bushings EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk, AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto. 17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand |
(Thread Starter) | Not Ranked : 0 score also i would love to hear feedback if anyone has run one of these
| Not Ranked : 0 score Any stage 2 2010 maps?
![]() Join Date: Nov 2013 Location: Englewood Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score +2 on stage 2 for 2010... would give you all sorts of feedback but have nothing to compare too
__________________ HPFP Internals, Corksport SRI+TIP, UR Test pipe, Resonator Delete, UR Axle Back, APv3, JBR RMM. |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score Going to have to scale for CPE intake as well, now where did that excel sheet go
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
(Thread Starter) | Not Ranked : 0 score i'll get to the 2010 stage 2's tonight just copy and paste it from an archived cobb map into mine and click save. easier that way
| Not Ranked : 0 score It'll be cool to see if i can even tell a difference lol
| Raiders Bitch ![]() Join Date: Aug 2013 Location: Flagler Beach, FL
Rep Power: 376 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 464
| Not Ranked : 0 score That's awesome for you to take your time to do this, I live 7ft above sea level, lol so I can't take advantage of this. Nice work
__________________ ![]() '13 CWP Mazdaspeed 3 w/ Technology Package: Cobb Tuning Accessport V3, Autotech HPFP Internals, HTP 3in Intake, Turbosmart Dual Port, Ultimate Racing Test Pipe, CP-e TMIC, Ultimate Racing Catback, DM RMM, DM PMM, CPE Trans Mount, JBR Shifter Bushings, OCC Rice: LED's, Black emblems, Rally Armor mudflaps, OEM Rain Visors, OEM Cargo Tray, Weathertech Floor mats, S204 lip (RIP), PERM shift knob, Cobb Exhaust hangers, Blue Evo X GSR wheels Fluids/other shit: Rotella T6, NGK 1 step colder plugs 235/40 Pilot Super Sports Tuned by Nishan 25% E85 |
(Thread Starter) | Not Ranked : 0 score yea sorry the internet at my place has been fucked and i've got alot of other shit going on. Promise i'll get to the 2010's tonight. i should be done with eveything by 7pm so i can work on these.
| The Following User Says Thank You to snailD For This Useful Post: | Easter Bunny (10-29-2014) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Dont worry about it man. Youre doing this on your own with no money for it you could wait a year and id be stoked lol
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have two of them posted
![]() | | #21 | ![]() |
| Not Ranked : 0 score Woot! Thanks man my roommate has an 08 its cool you posted that too ill get him to try it out!
![]() | | #22 | ![]() |
| Not Ranked : 0 score Just flashed the Snail HA stage 2 map and it kicks ass! Before I was at about 18 to 18.5 psi peak boost on the cobb stage 3 map and now I am holding 18.5 to 19 psi and getting up to 20 psi. On top of the higher boost, first gear has alot more usable power which makes driving the car and launching the car much easier. The power band is alot smoother and the car has way more power. The best part is I have next to no knock once my car got use to the map. With the regular cobb stage 3 map I always had knock of 1 but now I never break .6 This map really brings the car alive! If David can do this much with a cookie cutter OTS map I can't imagine what he would do with a full tune. For sure recommend these maps and Davids tunes. Thanks for hooking everyone up with free ots plus tune. Your the man! My car runs smoother, pulls harder and is even more fun to drive now. Disclaimer: v dyno attached was my first crack at using the program so I think I did it wrong. My cobb ap v dyno measured 292 so the power is close.
| The Following User Says Thank You to blake0521 For This Useful Post: | snailD (10-26-2014) |
![]() | | #23 | ![]() |
![]() thanks for the update
![]() | | #24 | ![]() |
| Not Ranked : 0 score Is that a good or bad thing? hahaha Heres the log if you want to make a v dyno that is actually correct. had two ppl in the car so I put 310 for total weight of people in car. Temp was 58ish ambient according to my car but my temp sensor is jacked since I forgot to relocate it after my fmic install... The only thing that looked shitty was my fuel pressure dipped below 1600 psi a few times. Might be time for new internals soon maybe.
| The Following 2 Users Say Thank You to blake0521 For This Useful Post: | Easter Bunny (10-29-2014), snailD (10-26-2014) |
![]() | | #25 | ![]() |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score So no '09 love?
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score 09s will be next... anyways @blake0521; i re-did your vd for you. it was very cold out, mid 40s it looked and i limited loads to 2.0 in the map. if you look the map kept you from going over 2.0, that boost will drop down a little as it heats up
![]() | | #27 | ![]() |
![]() Join Date: Feb 2014 Location: logan utah
Rep Power: 0 ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score love this map much better then the cobb ots stage 2. would highly recommend david Snail tune. Can't what to get my full tune! Thank for all the hard work david |
| The Following User Says Thank You to white beast For This Useful Post: | snailD (10-26-2014) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score keep in mind, the cobb maps aren't bad, they just aren't good at altitude. so i just want to reiterate that these maps are only for high altitude applications, use the cobb ots maps when you are under 3000ft above sea level.
![]() | | #29 | ![]() |
![]() Join Date: Jan 2013 Location: Alpine, Utah
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Ooh nice,
__________________ MS6 Velocity Red. JBR SRI/TIP, Cobb AP, JBR RMM, JBR PMM, JBR TMM, CP-E Catted DP, CS Catback exhaust, Block8 single gauge pod, TEIN S Tech springs, SPC Adjustable Ball Joints, GFB Respons BOV/BPV, Autotech HPFP Internals, FMIC. |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score yours is probably better still but let me know how it works out
![]() | | #31 | ![]() |
| Not Ranked : 0 score My car really does feel different I wasnt sure if it would be noticeable at all since i had already followed your guide for the throttle response deal but She feels more alive now! Thanks man!
| The Following User Says Thank You to Thatonefriend1 For This Useful Post: | snailD (10-27-2014) |
![]() | | #32 | ![]() |
![]() Join Date: Oct 2014 Location: Denver, Co
| Not Ranked : 0 score i got a stage 2 snaild ots map and talk about POWER!!! coming from the cobb stage 2 ots this map opens up the 2.3. 1st gear is wicked fun and if your not light on that pedal your boostin and gone!! overall great power throughout all gears. cant wait to get fully tuned by snailD. |
| The Following 2 Users Say Thank You to M-Speed-4 For This Useful Post: | snailD (10-28-2014), white beast (10-28-2014) |
![]() | | #33 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hi I was wondering if you have a map for an 07 speed. I've heard good things about snailD tunes and I wanted to try it out. The stage 1 I use from Cobb it's only allowing me to hit 14psi. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score If you can't read the OPs you shouldn't tune.
| The Following User Says Thank You to shamie For This Useful Post: | snailD (10-31-2014) |
![]() | | #35 | ![]() |
![]() Join Date: Oct 2012 Location: Northern Utah
| Not Ranked : 0 score Hey Dave, it's Kyle from up north with Tony. I tried out the "MS6 SNAIL HA OTS STAGE 2 CS" you posted. Thanks a lot for helping me out with this, when I was self-tuning I was thinking the timing was too high as well because I was getting some knock even at basically stock values. My BATs being roughly 150-170 doesn't help of course but I'm still hopeful that this should do well. Too bad I wasn't able to try it out earlier in the summer. After a couple days, I got some knock during a quick WOT pull on the freeway and let off because it hit 2+ kr. I looked at the LTFTs and saw they were at about 2%, 6% and about 12% the further I got up in the learning brackets. I thought this was weird, but at the same time I figured they wouldn't be perfect. I just pasted my old maf cal to it and am going to look again on another warmer day. Mods are CS TIP/SRI, M2 DP, step colder plugs at 0.028", HPFP. Other than that and me not liking the less sensitive throttle, the tune is great. Thank you again. |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Hmm, yeah I haven't ever checked for leaks, and we have had the IC off a few times lol.. Positive trims in vacuum to back up your case. Yeah, hood cowl weather stripping gone, coolant bypass done (which helped), TMIC ducting good, but I don't have the under tray ducting, will that make a big difference in bats? I thought that duct was more for radiator airflow? Thanks for your input! |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score it's design also sucks air out of the back of the engine bay so it doesn't stay trapped and heatsoak everything in the engine bay. it's a pretty key part to overall cooling
![]() | | #39 | ![]() |
| Not Ranked : 0 score Gotcha! I'll look into getting a new one, thanks. I have been dumbfounded At how hit it gets in its stick form for us. Makes sense now |
![]() | | #40 | ![]() |
| Not Ranked : 0 score yea snailD I will def have to check your maps out, my trims arent ALL over, but they are like 10% ish sometimes, anyways trying to replace my trans seals and trans mount bushing and rear endlinks and then I will prolly install the AP again onto the car, just want it running well before I start fucking with it , but I will def give you as much feeback as possible, I have nothing to do but document things
| Kia Sorento spotted high-altitude testing after 'Ring run | Haltech | Automotive News | 0 | 07-07-2014 01:00 PM |
| High Altitude Fuel Cuts | HalfWhit | Gen2 MS3 General Discussion | 5 | 07-14-2013 09:32 PM |
| High Altitude 1/4mi Times | Emoranges | Drag Racing | 6 | 04-14-2010 07:04 AM |
| High Altitude Protune | erod550 | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 02-27-2010 04:22 PM |
