Like Tree13Likes
 Old 05-12-2019, 09:12 PM   #121
6kipps's Avatar
Posts: 86   (View Stats)
6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all
I started tuning my fuel tables based on the concepts snailD a while back to restore some of my fuel economy after moving past the stock setup. Here's one of the tables:
Fuel CL Commanded EQ (Base) Gen2.xlsx
Perhaps this may help stimulate some ideas as you continue to tune. I applied this conceptually across my fueling tables, taking care to make sure there was some consistency between each one.
Hope this helps!
2013 MS3: COBB AP v3, CS SRI/TIP, CP-E TMIC, UR TP, CS HPFP, CS BPV, JBR OCC, COBB shift weight, Conti DWS, some rice...
6kipps is offline   Reply With Quote
 Old 08-22-2019, 12:08 AM   #122
snailD's Avatar
Posts: 3,039   (View Stats)
Originally Posted by ysaliens View Post
I'm interested in that. Anyone know how I can contact @snailD?
Not sure how to mention and his inbox is full
Hi guys, been a long time....
The map I had on my car, which it is still running with the new owners in the form I built it had both power and fuel economy combined. I cannot make maps anymore, I lost the computer to do so.... The big this is optimizing the low load situations like stated and leaving the high load stuff for power optimization. If you read in that thread I only really noticed drivability issues and not much on fuel economy when trying to drag out lean AFRs into mid load situations. Lean it out and add some timing for low load, then leave the mid range and high load alone. The car would get 30-34 mpg highway and high 20s city depending on conditions. email me at dfairclothms3@gmail.com if you have any other questions
memin likes this.
The Following 2 Users Say Thank You to snailD For This Useful Post:
memin (08-23-2019), Vansquish (08-22-2019)
 Old 08-23-2019, 07:42 PM   #123
memin's Avatar
Posts: 994   (View Stats)
@snailD you need to start tuning again!!Your tunes were the best one by far!!!!!!!!!!!!!
The Following User Says Thank You to memin For This Useful Post:
snailD (08-27-2019)
 Old 08-27-2019, 09:43 PM   #124
snailD's Avatar
stoked you liked them and I'm happy I was able to help so many people in this platform. I have so much respect for the people here over the years and all the stuff I learned. At the moment, I'm deep into doing dumb things with mr2's. This is my latest car I just did a little video overview on.
https://youtu.be/3wMPsVcr1pA
Kia Sorento spotted high-altitude testing after 'Ring run Haltech Automotive News 0 07-07-2014 01:00 PM
High Altitude Fuel Cuts HalfWhit Gen2 MS3 General Discussion 5 07-14-2013 09:32 PM
High Altitude 1/4mi Times Emoranges Drag Racing 6 04-14-2010 07:04 AM
High Altitude Protune erod550 MazdaSpeed 3/6 - ECU Computer Tuning 3 02-27-2010 04:22 PM
Page generated in 0.25456 seconds with 23 queries
