Like Tree5Likes
  • 1 Post By erod
  • 1 Post By thatguy0o0
  • 2 Post By Coffeespeed
  • 1 Post By Jeff23spl
 Old 01-15-2019, 08:14 PM   #1
erod's Avatar
Posts: 8   (View Stats)
erod will become famous soon enougherod will become famous soon enough
Default Thoughts on Stratified flash tune?
Wondering if anyone is currently using Stratified and your thoughts.
Put a post on a FB MazdaSpeed3 page and no one really had anything good to say about them.
Hope I didn’t waste $225.
Already purchased a flash tune with one revision for E30. My mod list below:
Cobb AP
Cobb TIP
Cobb SRI
Cobb BPV
Autotech HPFP
CorkSport TMIC
CorkSport catless race pipe
thatguy0o0 likes this.
erod is offline   Reply With Quote
 Old 01-16-2019, 06:22 AM   #2
thatguy0o0's Avatar
Posts: 148   (View Stats)
thatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond repute
They are a little slow to respond to emails but I have no issues with them. My mods are in my sig.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
1992 Jeep Cherokee 202,000 miles (salt/snow work horse)
2009 Toyota Rav 4 (wife has to drive something practical)
2012 Yamaha R1 Full Two Brothers exhaust & ECU flash
thatguy0o0 is offline   Reply With Quote
 Old 01-16-2019, 07:22 AM   #3
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
Slower response time from them working on newer platforms.... but back in time they knew pretty well the speed platform.
But you should not expect much at first place with a generic flash tune. each car is different especially after years of use. To make a generic tune, they need to take a good one and step back a bit on few things to make sure it would work with a wider range of cars. So it may work very good if you are at one end of the group or it may work a bit poorly if you are at the other side...or just average too...
So yes a flash tune isn't that wonderfull but it remain the same for all company.
There is nothing like a specific tune revised for your car behaviors.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-17-2019, 06:34 AM   #4
thatguy0o0's Avatar
Stratified normally does the custom tunes for bigger turbos. When they do the flash tune they get a list of your current mods and build a base tune around them and that base map comes with a complimentary MAF adjustment. For a few bucks more they will do datalog refinements, which is esentially the same thing that everyone else is doing. It is nothing like an OTS tune and it is far from generic.
Edit to say: as far as working on new platforms...maybe but they have a guy dedicated to the mazdaspeed platform. Nolan Wong is the guy's name. Seems like a good dude that knows a lot about these cars and tuning, again I have no issues with stratified. I was just saying they were slow to respond to emails because they are busy and not to expect a same day turnaround on most stuff unless it is an emergency.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
 Old 01-17-2019, 07:53 AM   #5
Jeff23spl's Avatar
Originally Posted by thatguy0o0 View Post
Stratified When they do the flash tune they get a list of your current mods and build a base tune around them and that base map comes with a complimentary MAF adjustment. For a few bucks more they will do datalog refinements, which is esentially the same thing that everyone else is doing. It is nothing like an OTS tune and it is far from generic.
IS The complimentary maf adjustement under the form of datalog and a personalized re-tune or just a based tune made with the intake part # without feedback?
Because if they preset the tune for the parts you have without closing the loop with datalogging the real car and update, the only difference from a Cobb OTS it is the brand name...
IMO, the OP should at least get the refinement option you are talking about.
Every part of the car makes some error value in the loop especially with aftermarket install and wear over time....Don't expect 2 cars with the same mods to react the same.
One can have half clogged intake valves and the other may not...
One may have some oil going back into the intake to reduce octane and support less timing than another one.
IT can be timing chain job that shifted 1 deg or a loose chain that affect it too.
A dirty intake filter.
Partially clogged cat running a smoking turbo for a while.
etc etc...
Wife drive 2010 CX7
 Old 01-18-2019, 10:48 PM   #6
thatguy0o0's Avatar
etc etc...
I agree that he should go with the refinement because they tune your car specifically and yes the maf cal is through datalog.
erod likes this.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
 Old 01-19-2019, 03:49 PM   #7
Coffeespeed's Avatar
Posts: 17   (View Stats)
Coffeespeed has a spectacular aura aboutCoffeespeed has a spectacular aura about
Default Stratified
I have been working with them for my BNRS4 tune. Nolan Wong has been extremely helpful with all my questions. Responds fairly quick with revisions. I would use them again for tuning.
thatguy0o0 and erod like this.
Coffeespeed is offline   Reply With Quote
 Old 01-20-2019, 07:58 AM   #8
erod's Avatar
Thanks for the info everyone. I'm going to clean my valves then load the tune. I will most likely upgrade the flash tune to a full tune.
 Old 01-20-2019, 06:56 PM   #9
erod's Avatar
What do you guys think of my numbers for the first revision?
Cobb AP, Cobb SRI, Cobb TIP, Cobb BPV, Cobb RMM, Autotech HPFP, CorkSport TMIC, CorkSport Race Pipe No Cat,
E30 etune Stratified
 Old 01-21-2019, 07:01 AM   #10
Jeff23spl's Avatar
please clean your logs, you don't need to duplicate many sensors with voltage and engineer units and you don't need EGR/EVAP and fans status etc...
Erase lines where you cruize or iddle...
Beside that, it's look like a somewhat agressive tune. I bet you feel it when driving ?
Wife drive 2010 CX7
 Old 01-21-2019, 07:09 PM   #11
erod's Avatar
Will do on my next data log post, thanks for the heads up. I did choose the aggressive option, spins the tires in third if I don't ease into it. But my tires are not anything special.
 Old 01-22-2019, 07:30 AM   #12
Jeff23spl's Avatar
Traction and tires are the weakness point of a modded 3. You would need large and gummy tires now. Michelin PSS are good ones...
And if someday you skip ethanol content, granny drive it until you can get some.
Wife drive 2010 CX7
 Old 01-22-2019, 08:54 AM   #13
thatguy0o0's Avatar
I did the aggressive tune as well for a while but it was kind of a pain daily driving it. I went back to the linear tune because it is easier to drive on the low end. Especially this time of year when I don't really drive it that much and when I do it is on snow tires and cold pavement. The low end on that aggressive map is silly though, I might try it again this summer with the PSS on it and see how that goes.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
 Old 01-22-2019, 04:29 PM   #14
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Just for clarity's sake, do note that the tune itself (i.e. fuel/ign/load maps) isn't different between aggressive and linear, the only difference between them is the throttle map which changes throttle response for a given input. I have linear myself for both 92 and E30 flash tunes from Stratified, I imagine the aggressive maps would be more like stock or cobb ots regarding throttle response which isn't my sort of bag.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 01-23-2019, 01:18 PM   #15
Jeff23spl's Avatar
I don't like an aggressive throttle either. I settle down mine from the ots map but the peak boost and max hp can be controlled by your right foot. No need to have the ecu to clamp power during winter...
We drive on snow since november to may in my area and i never did any change to my BT setup exept sometimes shutting down the meth when temp drop below -25-30C. TCS remain active and this alone was enough for me.
Wife drive 2010 CX7
The Stratified Flash Tune (Formerly S-OTS PLUS) Lex Stratified Automotive Controls 312 02-26-2016 12:55 PM
Stratified e85 flash tune log review dinoxor MazdaSpeed 3/6 - ECU Computer Tuning 2 07-22-2015 12:52 PM
Stratified Flash Tune (Formerly S-OTS+) V2.0 Lex Stratified Automotive Controls 66 05-28-2015 04:21 PM
Stratified S-OTS+ vs. Hypertech Flash Tune Review tfusch4 Stratified Automotive Controls 22 03-21-2015 11:46 AM
Stratified E85 Flash Tune (formerly S-OTS+ E85) jtday Stratified Automotive Controls 0 12-15-2014 05:54 PM
Page generated in 0.36742 seconds with 25 queries
