![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I have installed Bnr s1 and Hpfp. ECU is tuned by local disi tuner but I'm not sure that map is good. I'm loosing boost at middle throttle position.. At WOT everything is fine. Thanks for help in advance. Last edited by thomas3567; 03-24-2019 at 08:49 AM. |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Can you edit that log for us? What would be useful is a strip showing only wide open throttle from 3,000 rpm to redline with no lift throttle. Boost at mid throttle is going to be lower.
| First Datalog (AP) | 2eatV8everyday | 2010 MS3 - ECU Computer Tuning | 8 | 09-10-2012 03:13 PM |
| First datalog | razorscs | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-24-2012 03:51 PM |
| Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque | Haltech | Automotive News | 0 | 08-03-2010 07:30 AM |
| Tell me about my datalog | SPD6Tuner | MazdaSpeed 3/6 - ECU Computer Tuning | 39 | 08-31-2009 01:58 PM |
| Cant datalog with AP | SharkDiver | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 02-16-2009 03:36 PM |
