 Old 07-07-2018, 07:11 AM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default Tune with WG Spring Pressure
Hey, installing my Corksport turbo this weekend since I blew my K04. I am currently on a Stratified OTS tune at 21 PSI, but I know I need to retune the car for the new turbo. I read that I can unplug the BCS for the time being so that it just runs on wastegate spring pressure. Can I continue to use the same tune or should I flash a Cobb OTS tune?
Mods:
Corksport Stage II SRI
Corksport HPFP Internals
3” Catless DP
3” Straight Pipe
Corksport TMIC
Corksport Dual VTA BPV (I can set it back to full recirc)
With the tune I plan on getting a Corksport 3-port BCS. But right now I just want to get the car back to driving while I wait on the tune.
achulz is offline   Reply With Quote
 Old 07-07-2018, 08:32 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Get a pro e-tune, the ots tunes don't play well with bigger turbos
 Old 07-07-2018, 10:35 AM   #3
achulz's Avatar
If you actually read my post you would see that I am getting a pro tune, I just want to be able to drive the car in the mean time.
 Old 07-08-2018, 08:42 AM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Running spring pressure should be fine.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
How to run on wastegate spring pressure? tom10122 MazdaSpeed 3/6 - Turbo Induction 3 07-23-2017 07:05 AM
EWG spring pressure speed3sailor Mazdaspeed3/6 General Discussion 3 11-11-2014 08:36 AM
Max boost pressure 12 psi (WG spring) Mary MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 03-22-2014 12:57 PM
EWG Spring Pressure on base ECU map wake2011 2010 MS3 - Engine, Transmission & Driveline 9 08-14-2013 04:07 PM
Page generated in 0.30132 seconds with 22 queries
