 Old 07-05-2018, 11:39 AM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default Tuner for BT and E30?
What tuner do you all recommend I go to for my BNR S3 and E30 tune?
Mods list first:
Corksport HPFP
Corksport SRI
Corksport Stage II TIP
C-PE Gen 2 TMIC
GFB TMS Respons BPV (50/50)
Speed Perf6rmanc3 SP63 3-port BCS
Bosch 3bar MAP
3” Stainless Steel Catless DP
3” Stainless Steel Straight Pipe
BNR S3 BT
Corksport Stage II RMM
I want to get as much power as I can without sacrificing the integrity of the stock block. I do not plan on rebuilding hence the S3 instead of the pricier S4. To reach MBT I want to do an E30 mix, seems a lot less expensive than buying a WMI kit and a lot safer, if I mix correctly.
I currently have a Stratified OTS tune flashed to the car, I am upgrading the turbo this weekend since my K04 blew the hot side oil seals. The boost target was 21 PSI, and the car did haul ass. I mainly chose Stratified because of the things I heard about them and because they offer a crackle tune. But my experience was meh, took them a long time to respond to my emails and the throttle would be a bit weird sometimes.
I am looking at Purple Drank right now, they seem to have the fastest customer service and I really like how they keep the low end torque at bay.
But I want to hear your guys’ experiences, and what company you think I should have my car tuned with.
achulz is offline   Reply With Quote
 Old 07-05-2018, 01:14 PM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Asking which tuner is better is like asking which sport team is the best...at each is own.
For Stratified, keep in mind they may not give the same support for a full custom tune than a low cost ots tune but they seem to know what they do.
Don't expect to use the car with your actual tune once you get the parts installed. You need a revised base tune before making the first ride.....
For best results, a larger intake and TIP with a BT may not be a bad idea...
IMO i like W/M and if you would use it just as a safety to cool down BAT it works. It is when you make an agressive tune for it or use it as a low cost fuel adder that things may go wrong. Peoples get the cheapest kit even if it is for a critical purpose so yes it fail. But you can get an HFS4 and ANL connections for peace of mind.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-05-2018, 01:16 PM   #3
AveryPlaysBass's Avatar
Posts: 293   (View Stats)
AveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond repute
Groaned at 6 Times in 4 Posts
FreekTune and Purple Drank are both excellent.
Idk if they offer crackle tunes tho
[SIGPIC][/SIGPIC]It's OK to cry" - Lil B
2012 MS3 w/Tech Package
Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, JBR Boost Tubes, E-Focus Mount, CS Racepipe, Tuned by FREEKTUNE
Trans: CS insert, CS bushings, Damond Shifter Plate
Suspension: Koni Orange with OEM springs, Konig Controls 17x7 with 225/45 Conti DW's
Appearance: CP-E Relocation Plate, Smoked Taillights, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers
AveryPlaysBass is offline   Reply With Quote
 Old 07-05-2018, 02:05 PM   #4
Solarsurge's Avatar
Posts: 577   (View Stats)
I would suggest hiring a reputable tuner that both supports our platform and is a Cobb certified pro tuner. Despite what many think, a good tuner isn't a magician and doesn't make extra power. They simply tune the car to make as much power as it safely can. (Think of it like torque specs on a bolt. Sure, you can always push it further, and it may seem stronger, but you're compromising the integrity and it can break easier.) So, if you compare one *good* tune vs another it shouldn't have much difference in performance. If it does, either you or the tuner did something wrong.
Looking for a e-tuner Shadow 2010 MS3 - ECU Computer Tuning 1 06-19-2012 06:59 AM
(Q) about HT tuner huffentuff09 MazdaSpeed 3/6 - ECU Computer Tuning 3 12-31-2010 06:44 PM
Page generated in 0.25933 seconds with 23 queries
