 Old 03-18-2016, 07:36 AM   #1
TORQUERULES's Avatar
Posts: 283   (View Stats)
Default Upgrade to bigger intake--Order new tune or recalibrate myself?
I have two Stage 3 Stratified tunes (93 octane and E85 mix) and a Corksport Stage II intake. I would like to upgrade to a 3.5" Corksport or JBR intake and was wondering if I should just spend the $25 per tune and have Stratified update them for me, or would using Accesstuner Race and recalibrating myself (Corksport for instance gives a great tutorial) be good enough?
Opinions?
Thanks for the input.
BTW, its not about the money at all and Stratified is fantastic at what they do, but I also do not mind doing it myself and learning more about the Cobb software.
2017 Mazda CX-3 Meteor Gray
Last edited by TORQUERULES; 03-18-2016 at 07:37 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-18-2016, 08:04 AM   #2
Police - Grammarhead
Vansquish's Avatar
Unless you're running something significantly larger than a K04, there's really not much point in having an intake with an ID of 3". You'll lose MAF sensor granularity, and your car's drivability at low load/low revs will suffer.
Think of it this way:
Stock Intake: 2.5" ID --> 4.91 sq.in. cross section.
Aftermarket : 3.0" ID --> 7.07 sq.in. cross section.
JBR TRU-3.5": --> 3 ---> 9.62 sq.in. cross section.
That's a 44% increase for a 3.0"ID, and a 96% increase for a 3.5", but the K04 can only efficiently make use of a little over 300g/s of air. On the stock intake the top end of the MAF curve (5.0V) sits at about 366g/s. On a JBR 3.0" intake, that would be about 500g/s, and on the 3.5", it would be nearly 680g/s.
Finchee (03-21-2016), robbspeed (03-18-2016)
 Old 03-18-2016, 08:45 AM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
^This
Also, I doubt that you can change the MAF cal. since most tuners lock their maps.
2018 Audi RS3
2007 Acura TSX 6MT
Vansquish (03-18-2016)
 Old 03-18-2016, 09:01 AM   #4
It's actually better to do the $25 retune since you can't change the locked tune anyways.
And I run a 3.5" JBR right meow. I don't have any drivability issues at low revs/idle. I like to go to straight to the "end game" intake since I'll be upgrading the turbo later on.
sent from my Nexus 6P
The Following 5 Users Say Thank You to MS3Shadow For This Useful Post:
robbspeed (03-18-2016), Shwa (03-18-2016), speedfreak44 (03-18-2016), TORQUERULES (03-18-2016), Vansquish (03-18-2016)
 Old 03-18-2016, 09:16 AM   #5
speedfreak44's Avatar
Posts: 1,391   (View Stats)
What ms3shadow said
The line up:
 Old 03-18-2016, 09:18 AM   #6
sh4d0w's Avatar
Posts: 565   (View Stats)
Groans: 45
Groaned at 7 Times in 4 Posts
^ what he said
2010 Black MS3
 Old 03-18-2016, 10:08 AM   #7
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I would absolutely go with a bigger intake no matter what turbo is on. There are gains to be had even on a k04. And you wont need to change the intake when/if you go with a bigger turbo.
The cs + k04 setup makes alot of spool-up noise, so going to a silicone intake will make it less noisy. My gtx + cpe intake was far less noisy than k04 + cs s2. But the gtx is also a much quiter turbo, sadly. I'm throwing in my new Freektune 4" metal intake now which should hopefully result in more flow and noise, also looks better.
Less resistance in the intake tract could make your turbo overboost slightly at spool-up, so a small calibration might be needed but you'll find that out quickliy
Go for it
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 03-18-2016, 11:01 AM   #8
I am going to go to a BNR S3 later, so I thought I would upgrade intakes now to get ahead of the game. I figured that the $25 update was the way to go, but it never hurts asking everyone what their experience has been.
Thanks.
 Old 03-18-2016, 11:56 AM   #9
gdawg25's Avatar
Posts: 248   (View Stats)
Thanks.
When selecting your intake make sure you take in to consideration the inlet size of the turbo you think you will upgrade to. I know you said S3, however if you are like me, you will change your mind 1000x about your turbo choice. Honestly, I would hold off on the larger intake until you upgrade the turbo. That way you know for sure what intake will work with your turbo selection.
The Following User Says Thank You to gdawg25 For This Useful Post:
 Old 03-18-2016, 12:33 PM   #10
Groans: 33
That's only an issue if he goes with a silicone intake
Mazdaspeed6 -06
290 AWHP / K04
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
gdawg25 (03-18-2016), TORQUERULES (03-18-2016)
 Old 03-18-2016, 12:55 PM   #11
Thumbs up
I didn't plan on full silicone. I want to be able to change the adapter at the turbo end. That way upgrading turbos will not require yet ANOTHER intake.
Sound advice, its just hard when you have a little money burning a hole in your pocket. Lol.
Last edited by TORQUERULES; 03-18-2016 at 12:55 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-18-2016, 08:45 PM   #12
The jbr silicone 3" will fit over a s3. I ordered my s2 worried it wouldn't stretch to the s3 size but slipped over the s2 without a hitch. 3" is more than enough. Ask your mom
The line up:
 Old 03-19-2016, 01:07 AM   #13
OfficerMazda's Avatar
Posts: 19   (View Stats)
OfficerMazda will become famous soon enoughOfficerMazda will become famous soon enough
My mom said 3'' is fine...
Give credit when credit is due.
OfficerMazda is offline   Reply With Quote
What order is best to upgrade 2012 Mazdaspeed 3? Spense214 Mazdaspeed3/6 General Discussion 31 03-18-2016 04:36 PM
Todd - Tune Order 1165 - can't get a hold of you! Lex Stratified Automotive Controls 2 05-21-2014 12:19 PM
bigger tip and intake? cocoleveo7686 MazdaSpeed 6 - Engine, Transmission & Driveline 14 03-13-2014 05:59 PM
CorkSport Max Flow High Pressure Fuel Pump Upgrade Pre-Order CorkSport CorkSport 193 02-16-2014 05:48 PM
HPFP Upgrade with no tune. theurgy MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 19 10-02-2012 06:07 PM
Page generated in 0.40323 seconds with 28 queries
