![]() | | #41 | ![]() |
| Not Ranked : 0 score Just an FYI for any dummies out there like me, when @TiGraySpeed6; provided his excel example and included =J2*I2^K2 where J = base, I = MAF volts from ATR, and K2 = power, this equation has to be entered exactly this way in Excel or the computation is wrong. I was doing I2*J2^K2 and my numbers were wrong (of course because its the base to power). Use a row of @TiGraySpeed6;'s and/or @rfinkle2;'s data to verify the equation and numbers in your own spreadsheet as a check before running your own data, i.e. run a row of their data in your equation and make sure the numbers match theirs. I did this to figure out what I did wrong.
| The Following User Says Thank You to dale_gribble For This Useful Post: | TiGraySpeed6 (02-14-2013) |
![]() | | #42 | ![]() |
| Not Ranked : 0 score I'll make a thread about it maybe, but I found the reman had poorer granularity and flat spots in its response through the voltage range. Even on my initial comparisons, the Mazda OEM MAF responds more linearly across its response range and even has better voltage range response given the same airflow. Of course I don't flow any more, but now the sensor responds from 0-4.3v whereas the reman only responded from 0-4.1v in my car. Doesn't sound like much but this gives more granularity in the MAF sensor calibration table and will probably give me a much flatter AFR curve.
| The Following 3 Users Say Thank You to dale_gribble For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
.2 is still like about 4.88 percent.... Plenty of error/room to screw things up.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" | |
| The Following 2 Users Say Thank You to CosmicArkie For This Useful Post: | dale_gribble (02-15-2013), sidekick (02-15-2013) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score This should be added to the KB and stickied. @Raider;
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #45 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008
Rep Power: 2548 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
-David@COBB | |
| The Following 11 Users Say Thank You to Cobb Tuning For This Useful Post: | ASHMS3 (02-22-2013), atvfreek (02-15-2013), BlueStreak (02-20-2013), dale_gribble (02-15-2013), lilred (02-15-2013), ms3blackmica (02-15-2013), rfinkle2 (02-15-2013), sidekick (02-15-2013), tbot (02-15-2013), TiGraySpeed6 (02-15-2013), Twofer (02-19-2013) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score This should go without saying, but for any n00bs attempting this, make sure your datalog is free of any KR before attempting this calibration. KR = added fuel = richer AFR = skewed MAF cal curve. This process assumes a 0 KR datalog as a benchmark so you are calibrating the correct MAF curve.
| The Following 5 Users Say Thank You to dale_gribble For This Useful Post: | bob^3 (04-18-2013), ms3blackmica (02-16-2013), rfinkle2 (02-16-2013), TiGraySpeed6 (02-16-2013), Twofer (02-19-2013) |
![]() | | #47 | ![]() |
| Not Ranked : 0 score @rfinkle2; I decided to try your method to dial in the MAF cal when the car is in CL and using LTFTs for correction. Instead of using the target AFRs for the OL calibration portion as the correction factor for the MAF g/s, I used the LTFTs as the correction factor for the MAF g/s and plotted that against MAF voltage to create the curve. So, I created a column beside MAF Airflow (g/s) entitled Mass Airflow (g/s) CORRECTED. I multiplied the Mass Airflow (g/s) column by the LTFT % correction to arrive at the Mass Airflow (g/s) CORRECTED number. I ran this calculation through the entire range of closed loop MAF readings. I then plotted the corrected Airflow (g/s) column against the MAF voltage and came up with a curve. I applied this curve to the applicable voltage range section of the MAF cal per your guidance, plugged it into ATR and boom, perfect CL maf cal.
| The Following 7 Users Say Thank You to dale_gribble For This Useful Post: | Axel907 (02-20-2013), jrotaryb (10-21-2013), kidlifecrisis (05-08-2013), ms3blackmica (02-19-2013), rfinkle2 (02-19-2013), sidekick (02-19-2013), Sys7em1c (02-22-2013) |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Very cool. |
![]() | | #49 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Wow this makes this process so much easier. I may employ this to tighten my maf cal up. |
| The Following User Says Thank You to Mistersix For This Useful Post: | rfinkle2 (02-20-2013) |
![]() | | #50 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Any MSF tuners backed up and have a meth car in need of tuning? I'm having too much fun with this!
__________________ www.tunedbynishan.com |
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | rfinkle2 (02-20-2013), TiGraySpeed6 (02-20-2013) |
![]() | | #51 | ![]() |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | ms3blackmica (02-20-2013), TiGraySpeed6 (02-20-2013) |
![]() | | #52 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score Damnit, Rob. Just take my keys, my car and my laptop and do your thing. Don't come back to me until it's done.
__________________ '07 CWP MS3 Forged. |
| The Following 4 Users Say Thank You to BlueStreak For This Useful Post: |
![]() | | #53 | ![]() |
| Not Ranked : 0 score @Raider; This thread deserves a sticky. Rob did not have to share his secrets and tricks of which make his tuning skills superior but he does so for benefit of the mazdaspeed community.
| The Following 7 Users Say Thank You to ms3blackmica For This Useful Post: | charlesfist (04-26-2013), Dano (02-22-2013), jrotaryb (10-21-2013), lilred (02-22-2013), rfinkle2 (02-22-2013), sidekick (02-22-2013), TiGraySpeed6 (02-22-2013) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score I made it a knowledgebase article and is a stickie ![]() ![]() ![]() |
| The Following 8 Users Say Thank You to Raider For This Useful Post: | ASHMS3 (02-22-2013), bob^3 (04-18-2013), charlesfist (04-26-2013), mr.speedy3 (03-10-2014), ms3blackmica (02-22-2013), rfinkle2 (02-22-2013), sidekick (02-22-2013), TiGraySpeed6 (02-22-2013) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Woohoo!
| The Following User Says Thank You to ms3blackmica For This Useful Post: | rfinkle2 (02-27-2013) |
![]() | | #56 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
| The Following 4 Users Say Thank You to Mfinlay04 For This Useful Post: |
![]() | | #57 | ![]() |
| Not Ranked : 0 score IMO. STFT is too volatile to be used in this calculation. You can blow on your filter and watch it go up. Lol. Interested to see how yours holds up over time. Tappin
| The Following 2 Users Say Thank You to Dano For This Useful Post: | ms3blackmica (03-01-2013), rfinkle2 (02-27-2013) |
![]() | | #58 | ![]() |
| Not Ranked : 0 score The method that Rob posted in the OP works very very very well for WOT tuning on Gen 1's that are so dependant on the MAF curve being precise. I finally got a chance to use this method on a friends car. After the first WOT log, I did all the gymnastics in Excel and adjusted the MAF curve with the values that were produced. On the next log the car was much closer to target and transitioned from stoich to OL AFR very smoothly. From this point on, all I had to do was add 2% and that was it. Car hits target perfectly. WOT MAF Curve dialed in after 2 adjustments? I'll take it. Thanks again Rob.
__________________ www.tunedbynishan.com Last edited by ms3blackmica; 03-01-2013 at 02:30 PM. |
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | Dano (03-01-2013), TiGraySpeed6 (03-01-2013) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score I cannot get the maf voltages from atr to post vertically in excel. Its making me crazy. I only got one paste>special window and it does nothing. The paste>special>values>transpose window just doesn't exist from me. WTF!!! |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score What happens when you right click in an empty cell? |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Mistersix (03-01-2013) |
![]() | | #61 | ![]() |
| Not Ranked : 0 score In that menu is a paste options menu. when i click paste special i just get the window with (paste as: unicode text, text, csv.) |
![]() | | #62 | ![]() |
| Not Ranked : 0 score What version of Excel are you using?
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Mistersix (03-01-2013) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score excel 2010? Whatever windows seven comes with i guess. |
| The Following User Says Thank You to Mistersix For This Useful Post: | rfinkle2 (03-01-2013) |
![]() | | #64 | ![]() |
| Not Ranked : 0 score I can make a video on how to do it if you want @Mistersix;
![]() | | #65 | ![]() |
| Not Ranked : 0 score All was smooth up until this mystery menu that everybody else seems to have. Is my version old or something? Basically i wanted to try this out in anticipation of upgrading to a bigger intake. So i loaded an ots maf cal up and grabbed a log. Unfortunately its only a 3rd gear pull, but its just for practice anyways. The snip below is where i'm at. I've been searching threw the helpfile but it says exactly what you guys already said on the first page. But that box is just not there. Its fucking with me i swear. |
![]() | | #66 | ![]() |
![]() | | #67 | ![]() |
| Not Ranked : 0 score The voltages i copied from atr paste horizontally in starting in the box i highlighted all the way to the left. Like that. With respect to the last few. without that special paste function they wont go vertical? 3.05 3.09 3.13 3.16 3.20 3.24 3.28 3.32 3.36 3.40 3.44 3.48 3.52 3.55 3.59 3.63 3.67 3.71 3.75 3.79 3.83 3.87 3.91 3.95 3.98 4.02 4.06 4.10 4.14 4.18 4.22 4.26 4.30 4.34 4.38 4.41 4.45 4.49 4.53 4.57 4.61 4.65 4.69 4.73 4.77 4.80 4.84 4.88 4.92 4.96 5.00 |
![]() | | #68 | ![]() |
You should be able to find both the value and transpose option buttons. | |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Go ahead and paste it horizontally in an open area Then highlight the values and copy again Select the top cell where you want to paste vertically, and then you can use the right click menu and the transpose button or the paste button drop down on the home menu and choose the transpose button
| The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #70 | ![]() |
| Not Ranked : 0 score That little box does indeed pop up after i paste. But all that is in it is a paste icon and (use text import wizard). I messed around with that to no avail. |
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
Time to dole out some thanks. | |
| The Following 2 Users Say Thank You to Mistersix For This Useful Post: | ms3blackmica (03-01-2013), rfinkle2 (03-01-2013) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score I have twice as many volt cells as the other cells. Guess you really need a 4th gear pull to do this right. I'll try to get a 4th gear tomorrow and try again. I'm still not clear on what to do beyond this point. I really wanna learn to use this though. As i said about upping to a bigger intake and once summer settles in i plan to go back to the eth as well so i'll need to maf cal for that. And this seems like it beats doing maf cal the old way, point by point. btw, what does the arrow pointing up mean? =J2*I2^K2 |
![]() | | #74 | ![]() |
![]() Join Date: May 2009 Location: Tallmadge, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score Thanks Rob! This is awesome, got my MAF cal perfect now! @Mistersix, your curve seems to be opposite of what you should see because it's plotting the graph over wrong data, AFRs to be exact. You need to graph the curve against the Maf V reading from the log. You can either delete other columns you no longer need, or copy/paste data in a new book.
__________________ ::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 ::: ::: DIZZY TUNED by Boost_creep ::: |
| The Following User Says Thank You to blackrs99 For This Useful Post: | rfinkle2 (03-03-2013) |
![]() | | #75 | ![]() |
In text: 2^2 is said "2 raised to the power of 2" aka "2 squared". Also = 4. Honestly guys, a very good maf cal can be done by self adjusting the breakpoints, and by using the technique in the helpfile. This is just one thing that had always bugged me when sending "squiggly" maf curves to people. As long as the logged values are within a few .10ths of what you are commanding in the fueling tables on your car... this is completely unnecessary. Mistersix, post all of your questions if you need a hand. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Mistersix (03-03-2013), ms3blackmica (03-03-2013) |
![]() | | #76 | ![]() |
| Not Ranked : 0 score Here are templates for correcting both CL and OL.
| The Following 3 Users Say Thank You to sidekick For This Useful Post: |
![]() | | #77 | ![]() |
| Not Ranked : 0 score Super cool templates. Just not real sure how to get the copied voltage values from atr to equal the number of cells in excel. |
![]() | | #78 | ![]() |
| Not Ranked : 0 score I've just been using the range of MAF voltages I saw in the log. They don't need to line up.
| The Following User Says Thank You to sidekick For This Useful Post: | Mistersix (03-04-2013) |
![]() | | #79 | ![]() |
| Not Ranked : 0 score Correct- the logged voltages don't need to match the ATR values. They're only used to get the corrected MAF values, which are then used to feed the chart. The chart gives you the values to work against the actual ATR MAF Volt values.
![]() | | #80 | ![]() |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score I have just tried it,very cool.....
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | rfinkle2 (03-21-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/using-excel-dial-your-maf-curve-meth-137570/ | ||||
| Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 10-24-2014 03:02 AM | |
| Meth and MAF cal | This thread | Pingback | 08-02-2013 05:40 AM | |
| Hard cut/jerking + other issues - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-18-2013 11:21 AM | |
| WOT MAF/AFR correction worksheet - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-10-2013 03:25 PM | |
| Beaner time! - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 02-10-2013 08:34 AM | |
| Trying to dial in this tune | Guerra88 | 2010 MS3 - ECU Computer Tuning | 23 | 05-24-2012 10:50 PM |
| Help me dial in my 3076. :) | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 63 | 09-04-2011 09:45 AM |
| dial in on proposed thought of egr delete... | burntmushu | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 08-09-2011 09:01 PM |
| cpe stand back users and meth | phillyb | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 04-24-2009 12:06 PM |
